Commit 99beb4d7 authored by Alban Bellot's avatar Alban Bellot
add symetric norm
parent fb5753a9
......@@ -68,6 +68,45 @@ static int (*conversionTable[3][3][6])(pastix_spm_t*) = {
* @ingroup pastix_spm
* spmInit - Init the spm structure given as parameter
* @param[in,out] spm
* The sparse matrix to init.
void
spmInit( pastix_spm_t *spm )
spm->mtxtype = PastixGeneral;
spm->flttype = PastixComplex64;
spm->fmttype = PastixCSC;
spm->gN = 0;
spm->n = 0;
spm->gnnz = 0;
spm->nnz = 0;
spm->gNexp = 0;
spm->nexp = 0;
spm->gnnzexp = 0;
spm->nnzexp = 0;
spm->dof = 1;
spm->dofs = NULL;
spm->colptr = NULL;
spm->rowptr = NULL;
spm->loc2glob = NULL;
spm->values = NULL;
......@@ -41,6 +41,7 @@ struct pastix_spm_s {
if > 0, constant degree of freedom
otherwise, irregular degree of freedom (refer to dofs) */
pastix_int_t *dofs; /*< Number of degrees of freedom per unknown (NULL, if dof > 0) */
pastix_int_t *colptr; /*< List of indirections to rows for each vertex */
pastix_int_t *rowptr; /*< List of edges for each vertex */
pastix_int_t *loc2glob; /*< Corresponding numbering from local to global */
......@@ -139,11 +139,10 @@ z_spmMaxNorm( const pastix_spm_t *spm )
pastix_complex64_t *valptr = (pastix_complex64_t*)spm->values;
double tmp, norm = 0.;
for(i=0; i <spm->nnz; i++, valptr++) {
for(i=0; i < spm->nnzexp; i++, valptr++) {
tmp = cabs( *valptr );
norm = norm > tmp ? norm : tmp;
return norm;
......@@ -171,17 +170,22 @@ z_spmMaxNorm( const pastix_spm_t *spm )
double
z_spmInfNorm( const pastix_spm_t *spm )
pastix_int_t col, row, i, baseval;
pastix_int_t col, row, i, j, k, ii, jj, baseval;
pastix_int_t dofi, dofj;
pastix_int_t *dofs=spm->dofs;
double norm = 0.;
double *sumcol;
MALLOC_INTERN( sumcol, spm->gN, double );
memset( sumcol, 0, spm->gN * sizeof(double) );
MALLOC_INTERN( sumcol, spm->gNexp, double );
memset( sumcol, 0, spm->gNexp * sizeof(double) );
baseval = spmFindBase( spm );
switch( spm->fmttype ){
case PastixCSC:
/* Original */
for( col=0; col < spm->gN; col++ )
for( i=spm->colptr[col]-baseval; i<spm->colptr[col+1]-baseval; i++ )
......@@ -189,8 +193,10 @@ z_spmInfNorm( const pastix_spm_t *spm )
sumcol[spm->rowptr[i]-baseval] += cabs( valptr[i] );
/* Add the symmetric/hermitian part */
if ( (spm->mtxtype == PastixHermitian) ||
(spm->mtxtype == PastixSymmetric) )
......@@ -201,6 +207,55 @@ z_spmInfNorm( const pastix_spm_t *spm )
sumcol[col] += cabs( valptr[i] );
/* Dofs */
for( i=0; i < spm->n; i++ )
dofi = ( spm->dof > 0 ) ? spm->dof : dofs[i+1] - dofs[i];
for(k=spm->colptr[i]; k < spm->colptr[i+1]; k++)
j = spm->rowptr[k - baseval] - baseval;
dofj = ( spm->dof > 0 ) ? spm->dof : dofs[j+1] - dofs[j];
row = dofs[j];
for(ii=0; ii < dofi; ii++)
for(jj=0; jj < dofj; jj++, valptr++)
sumcol[row + jj] += cabs( *valptr );
for(i=0; i < spm->n; i++)
col = dofs[i];
for(jj=0; jj < dofj; jj++,valptr++)
if(i != j)
sumcol[col + ii] += cabs( *valptr );
break;
......@@ -250,7 +305,7 @@ z_spmInfNorm( const pastix_spm_t *spm )
return PASTIX_ERR_BADPARAMETER;
for( i=0; i<spm->gN; i++)
for( i=0; i<spm->gNexp; i++) //gNexp
if(norm < sumcol[i])
......@@ -286,34 +341,70 @@ z_spmInfNorm( const pastix_spm_t *spm )
double
z_spmOneNorm( const pastix_spm_t *spm )
double norm = 0.;
double *sumrow;
pastix_int_t* dofs=spm->dofs;
MALLOC_INTERN( sumrow, spm->gN, double );
memset( sumrow, 0, spm->gN * sizeof(double) );
MALLOC_INTERN( sumrow, spm->gNexp, double );
memset( sumrow, 0, spm->gNexp * sizeof(double) );
case PastixCSC:
sumrow[col] += cabs( valptr[i] );
col = dofs[i];
dofi = ( spm->dof > 0 ) ? spm->dof : dofs[i+1] - spm->dofs[i];
dofj = ( spm->dof > 0 ) ? spm->dof : dofs[j+1] - spm->dofs[j];
sumrow[col + ii] += cabs( *valptr );
for( i=spm->colptr[col]-baseval+1; i<spm->colptr[col+1]-baseval; i++ )
sumrow[spm->rowptr[i]-baseval] += cabs( valptr[i] );
row = dofs[j];
if(i != j)
sumrow[row + jj] += cabs( *valptr );
......@@ -365,7 +456,7 @@ z_spmOneNorm( const pastix_spm_t *spm )
if(norm < sumrow[i])
