GitLab
Explore
Primary navigation
Search or go to…
spm
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container Registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
spm
9892a02a
9892a02a
8 years ago
Mathieu Faverge
Downloads
Patches
Add support for CSR and IJV in spm2dense function
53f0b886
z_spm_2dense.c
+315
-1
315 additions, 1 deletion
z_spm_2dense.c
315 additions
1 deletion
z_spm_2dense.c
315
9892a02a
@@ -25,7 +25,7 @@
#include
"z_spm.h"
pastix_complex64_t
z_spm2dense
const
pastix_spm_t
spm
z_spm
CSC
2dense
const
pastix_spm_t
spm
pastix_int_t
i
j
lda
baseval
pastix_complex64_t
A
valptr
@@ -172,6 +172,320 @@ z_spm2dense( const pastix_spm_t *spm )
return
A
pastix_complex64_t
z_spmCSR2dense
const
pastix_spm_t
spm
pastix_int_t
i
j
lda
baseval
pastix_complex64_t
A
valptr
pastix_int_t
colptr
rowptr
assert
spm
fmttype
PastixCSR
assert
spm
flttype
PastixComplex64
lda
spm
gNexp
A
pastix_complex64_t
malloc
lda
lda
sizeof
pastix_complex64_t
memset
A
lda
lda
sizeof
pastix_complex64_t
baseval
spmFindBase
spm
i
j
colptr
spm
colptr
rowptr
spm
rowptr
valptr
pastix_complex64_t
spm
values
* Constant degree of fredom of 1
if
spm
dof
switch
spm
mtxtype
#if defined(PRECISION_z) || defined(PRECISION_c)
case
PastixHermitian
for
i
i
spm
n
i
rowptr
for
j
rowptr
j
rowptr
j
colptr
valptr
if
i
colptr
baseval
/* Make sure the matrix is hermitian */
A
i
lda
i
creal
valptr
I
else
A
i
lda
colptr
baseval
conj
valptr
A
colptr
baseval
lda
i
valptr
break
#endif
case
PastixSymmetric
for
i
i
spm
n
i
rowptr
for
j
rowptr
j
rowptr
j
colptr
valptr
A
i
lda
colptr
baseval
valptr
A
colptr
baseval
lda
i
valptr
break
case
PastixGeneral
default:
for
i
i
spm
n
i
rowptr
for
j
rowptr
j
rowptr
j
colptr
valptr
A
i
lda
colptr
baseval
valptr
* General degree of freedom (constant or variable)
else
pastix_int_t
k
ii
jj
dofi
dofj
col
row
pastix_int_t
dofs
spm
dofs
switch
spm
mtxtype
case
PastixHermitian
for
i
i
spm
n
i
rowptr
dofi
spm
dof
spm
dof
dofs
i
dofs
i
row
dofs
i
for
k
rowptr
k
rowptr
k
colptr
j
colptr
baseval
dofj
spm
dof
spm
dof
dofs
j
dofs
j
col
dofs
j
for
ii
ii
dofi
ii
for
jj
jj
dofj
jj
valptr
A
col
ii
lda
row
jj
valptr
A
row
jj
lda
col
ii
conj
valptr
break
#endif
case
PastixSymmetric
for
i
i
spm
n
i
rowptr
dofi
spm
dof
spm
dof
dofs
i
dofs
i
row
dofs
i
for
k
rowptr
k
rowptr
k
colptr
j
colptr
baseval
dofj
spm
dof
spm
dof
dofs
j
dofs
j
col
dofs
j
for
ii
ii
dofi
ii
for
jj
jj
dofj
jj
valptr
A
col
ii
lda
row
jj
valptr
A
row
jj
lda
col
ii
valptr
break
case
PastixGeneral
default:
for
i
i
spm
n
i
rowptr
dofi
spm
dof
spm
dof
dofs
i
dofs
i
row
dofs
i
for
k
rowptr
k
rowptr
k
colptr
j
colptr
baseval
dofj
spm
dof
spm
dof
dofs
j
dofs
j
col
dofs
j
for
ii
ii
dofi
ii
for
jj
jj
dofj
jj
valptr
A
col
ii
lda
row
jj
valptr
return
A
pastix_complex64_t
z_spmIJV2dense
const
pastix_spm_t
spm
pastix_int_t
i
j
k
lda
baseval
pastix_complex64_t
A
valptr
pastix_int_t
colptr
rowptr
assert
spm
fmttype
PastixIJV
assert
spm
flttype
PastixComplex64
lda
spm
gNexp
A
pastix_complex64_t
malloc
lda
lda
sizeof
pastix_complex64_t
memset
A
lda
lda
sizeof
pastix_complex64_t
baseval
spmFindBase
spm
i
j
colptr
spm
colptr
rowptr
spm
rowptr
valptr
pastix_complex64_t
spm
values
if
spm
dof
switch
spm
mtxtype
case
PastixHermitian
for
k
k
spm
nnz
k
rowptr
colptr
valptr
i
rowptr
baseval
j
colptr
baseval
if
i
j
A
i
lda
i
creal
valptr
I
else
A
j
lda
i
valptr
A
i
lda
j
conj
valptr
break
#endif
case
PastixSymmetric
for
k
k
spm
nnz
k
rowptr
colptr
valptr
i
rowptr
baseval
j
colptr
baseval
A
j
lda
i
valptr
A
i
lda
j
valptr
break
case
PastixGeneral
default:
for
k
k
spm
nnz
k
rowptr
colptr
valptr
i
rowptr
baseval
j
colptr
baseval
A
j
lda
i
valptr
else
pastix_int_t
k
ii
jj
dofi
dofj
col
row
pastix_int_t
dofs
spm
dofs
switch
spm
mtxtype
case
PastixHermitian
for
k
k
spm
nnz
k
rowptr
colptr
i
rowptr
baseval
j
colptr
baseval
dofi
spm
dof
spm
dof
dofs
i
dofs
i
row
dofs
i
dofj
spm
dof
spm
dof
dofs
j
dofs
j
col
dofs
j
for
jj
jj
dofj
jj
for
ii
ii
dofi
ii
valptr
if
col
jj
row
ii
A
col
jj
lda
row
ii
creal
valptr
I
else
A
col
jj
lda
row
ii
valptr
A
row
ii
lda
col
jj
conj
valptr
break
#endif
case
PastixSymmetric
for
k
k
spm
nnz
k
rowptr
colptr
i
rowptr
baseval
j
colptr
baseval
dofi
spm
dof
spm
dof
dofs
i
dofs
i
row
dofs
i
dofj
spm
dof
spm
dof
dofs
j
dofs
j
col
dofs
j
for
jj
jj
dofj
jj
for
ii
ii
dofi
ii
valptr
A
col
jj
lda
row
ii
valptr
A
row
ii
lda
col
jj
valptr
break
case
PastixGeneral
default:
for
k
k
spm
nnz
k
rowptr
colptr
i
rowptr
baseval
j
colptr
baseval
dofi
spm
dof
spm
dof
dofs
i
dofs
i
row
dofs
i
dofj
spm
dof
spm
dof
dofs
j
dofs
j
col
dofs
j
for
jj
jj
dofj
jj
for
ii
ii
dofi
ii
valptr
A
col
jj
lda
row
ii
valptr
return
A
pastix_complex64_t
z_spm2dense
const
pastix_spm_t
spm
switch
spm
fmttype
case
PastixCSC
return
z_spmCSC2dense
spm
case
PastixCSR
return
z_spmCSR2dense
spm
case
PastixIJV
return
z_spmIJV2dense
spm
return
NULL
void
z_spmDensePrint
pastix_int_t
m
pastix_int_t
n
pastix_complex64_t
A
pastix_int_t
lda
This diff is collapsed.
Loading
Save comment
