Commit 2a75a750 authored by RAMET Pierre's avatar RAMET Pierre Committed by Mathieu Faverge
scal multi RHS
parent 299d548f
......@@ -26,6 +26,7 @@
#include "p_spm.h"
#include <cblas.h>
#include <lapacke.h>
#if !defined(DOXYGEN_SHOULD_SKIP_THIS)
......@@ -1184,7 +1185,7 @@ spmCheckAxb( pastix_int_t nrhs,
void
spmScalMatrix(const double alpha, pastix_spm_t* spm)
spmScalMatrix(double alpha, pastix_spm_t* spm)
switch(spm->flttype)
......@@ -1225,7 +1226,7 @@ spmScalMatrix(const double alpha, pastix_spm_t* spm)
void
spmScalVector(const double alpha, pastix_spm_t* spm, void *x)
spmScalVector(double alpha, pastix_spm_t* spm, void *x)
......@@ -1246,6 +1247,57 @@ spmScalVector(const double alpha, pastix_spm_t* spm, void *x)
* @brief Scale a dense matrix corresponding to a set of RHS (wrapper to LAPACKE_xlascl)
* A = alpha * A
* @param[in] flt
* Datatype.
* @param[in] m
* Number of rows of the matrix A.
* @param[in] n
* Number of columns of the matrix A.
* @param[in] alpha
* The scaling parameter.
* @param[inout] A
* The matrix of RHS to scal.
* @param[in] lda
* Defines the leading dimension of A when multiple right hand sides
* are available. lda >= m.
void
spmScalRHS(pastix_coeftype_t flt, double alpha, pastix_int_t m, pastix_int_t n, void *A, pastix_int_t lda)
switch(flt)
case PastixPattern:
break;
case PastixFloat:
LAPACKE_slascl_work(LAPACK_COL_MAJOR, 'G', 0, 0, 1., alpha, m, n, A, lda);
break;
case PastixComplex32:
LAPACKE_clascl_work(LAPACK_COL_MAJOR, 'G', 0, 0, 1., alpha, m, n, A, lda);
break;
case PastixComplex64:
LAPACKE_zlascl_work(LAPACK_COL_MAJOR, 'G', 0, 0, 1., alpha, m, n, A, lda);
break;
case PastixDouble:
default:
LAPACKE_dlascl_work(LAPACK_COL_MAJOR, 'G', 0, 0, 1., alpha, m, n, A, lda);
......@@ -92,8 +92,9 @@ void spmGenFakeValues( pastix_spm_t *spm );
double spmNorm( pastix_normtype_t ntype, const pastix_spm_t *spm );
int spmMatVec( pastix_trans_t trans, const void *alpha, const pastix_spm_t *spm, const void *x, const void *beta, void *y );
void spmScalMatrix( const double alpha, pastix_spm_t *spm );
void spmScalVector( const double alpha, pastix_spm_t *spm, void *x );
void spmScalMatrix( double alpha, pastix_spm_t *spm );
void spmScalVector( double alpha, pastix_spm_t *spm, void *x );
void spmScalRHS( pastix_coeftype_t flt, double alpha, pastix_int_t m, pastix_int_t n, void *A, pastix_int_t lda );
