Commit c47785f3 authored by PRUVOST Florent's avatar PRUVOST Florent
Get rid of xsltproc because ctest now has an option for junit reports
parent 34e01580
...@@ -7,8 +7,6 @@ Find: ...@@ -7,8 +7,6 @@ Find:
paths: paths:
- build - build
reports: reports:
junit: report.xml junit: build/report.xml
script: script:
- modules/find/tests/run_ctest.sh - modules/find/tests/run_ctest.sh
after_script:
- xsltproc -o report.xml /home/gitlab/ctest-to-junit.xsl build/Testing/**/Test.xml
#!/bin/bash #!/bin/bash
set -ex
# env. var. CI_PROJECT_DIR required cmake -B build -S ./modules/find/tests \
[ -z "$CI_PROJECT_DIR" ] && echo "Variable CI_PROJECT_DIR must be set to execute this script." && exit 1 -DENABLE_CTEST=ON \
-DLAPACKE_COMPONENTS="TMG" \
mkdir -p build -DQUARK_COMPONENTS="HWLOC" \
cd build -DCMAKE_PREFIX_PATH="$PARSEC_DIR"
ctest --test-dir build --no-compress-output --verbose --output-junit report.xml
cmake $CI_PROJECT_DIR/modules/find/tests -DENABLE_CTEST=ON -DLAPACKE_COMPONENTS="TMG" -DQUARK_COMPONENTS="HWLOC" -DCMAKE_PREFIX_PATH="$PARSEC_DIR"
ctest --no-compress-output -T Test -V
