Commit 92d76dc6 authored by Mathieu Faverge's avatar Mathieu Faverge
RP: Modify the precision generation rules to make it possible to use multiple dictionnaries
parent 92987016
1 merge request!68Precision rules: Make sure we can use a list of dictionnaries as expected and enables protected names
......@@ -38,9 +38,13 @@ set(RP_DEFAULT_DICTIONNARY ${MORSE_CMAKE_MODULE_PATH}/precision_generator/subs.p
if( NOT DEFINED RP_${CMAKE_PROJECT_NAME}_DICTIONNARY )
message( WARNING "RulesPrecisions included before RP_${CMAKE_PROJECT_NAME}_DICTIONNARY was defined (Only the default one is used)" )
set( RP_DICTIONNARIES ""
CACHE INTERNAL "List of Dictionnaries to use for precision generation" )
else()
set(RP_${CMAKE_PROJECT_NAME}_DICTIONNARY ${RP_${CMAKE_PROJECT_NAME}_DICTIONNARY}
CACHE INTERNAL "Dictionnary used for precision generation" )
set( RP_DICTIONNARIES ${RP_${CMAKE_PROJECT_NAME}_DICTIONNARY}
endif()
# Default Precisions
......@@ -193,6 +197,7 @@ MACRO(precisions_rules_py)
message( DEBUG "[RP] PRECISIONPP_arg ${PRECISIONPP_arg}")
message( DEBUG "[RP] PRECISIONPP_prefix ${PRECISIONPP_prefix}")
message( DEBUG "[RP] PREC_RULE_PRECISIONS ${PREC_RULE_PRECISIONS}")
message( DEBUG "[RP] DICTIONNARIES ${RP_DICTIONNARIES}")
set(options_list "")
foreach(prec_rules_PREC ${PREC_RULE_PRECISIONS})
......@@ -205,8 +210,8 @@ MACRO(precisions_rules_py)
endforeach()
set( gencmd ${Python3_EXECUTABLE} ${RP_CODEGEN} -c -f "${sources_list}" -p "${options_list}" -s "${CMAKE_CURRENT_SOURCE_DIR}" -b "${CMAKE_CURRENT_BINARY_DIR}" ${PRECISIONPP_arg} ${PRECISIONPP_prefix} )
if( DEFINED RP_${CMAKE_PROJECT_NAME}_DICTIONNARY )
set( gencmd ${gencmd} -D "${RP_${CMAKE_PROJECT_NAME}_DICTIONNARY}" )
if( DEFINED RP_DICTIONNARIES )
set( gencmd ${gencmd} -D "${RP_DICTIONNARIES}" )
endif()
message( DEBUG "[RP] gen command ${gencmd}")
......@@ -224,8 +229,8 @@ MACRO(precisions_rules_py)
set(_dependency_OUTPUT "${CMAKE_MATCH_3}")
set(pythoncmd ${Python3_EXECUTABLE} ${RP_CODEGEN} -g -f ${CMAKE_CURRENT_SOURCE_DIR}/${_dependency_INPUT} -b "${CMAKE_CURRENT_BINARY_DIR}" -p ${_dependency_PREC} ${PRECISIONPP_arg} ${PRECISIONPP_prefix})
set( pythoncmd ${pythoncmd} -D "${RP_${CMAKE_PROJECT_NAME}_DICTIONNARY}" )
set( pythoncmd ${pythoncmd} -D "${RP_DICTIONNARIES}" )
endif()
string(STRIP "${_dependency_OUTPUT}" _dependency_OUTPUT)
......@@ -252,7 +257,7 @@ MACRO(precisions_rules_py)
ADD_CUSTOM_COMMAND(
OUTPUT ${_dependency_OUTPUT}
COMMAND ${CMAKE_COMMAND} -E remove -f ${_dependency_OUTPUT} && ${pythoncmd} && chmod a-w ${_dependency_OUTPUT}
DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/${_dependency_INPUT} ${RP_CODEGEN} ${RP_${CMAKE_PROJECT_NAME}_DICTIONNARY} ${RP_DEFAULT_DICTIONNARY} )
DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/${_dependency_INPUT} ${RP_CODEGEN} ${RP_DICTIONNARIES} ${RP_DEFAULT_DICTIONNARY} )
set_source_files_properties(${_dependency_OUTPUT} PROPERTIES COMPILE_FLAGS ${_compile_flags} GENERATED 1 IS_IN_BINARY_DIR 1 )
else( generate_out )
set_source_files_properties(${_dependency_OUTPUT} PROPERTIES COMPILE_FLAGS ${_compile_flags} GENERATED 0 )
