Commit 7c595bca authored by PRUVOST Florent's avatar PRUVOST Florent
add detection of dlascl also when testing lapacke with lapack
parent 5dac8d38
...@@ -131,6 +131,9 @@ if (LAPACK_FOUND) ...@@ -131,6 +131,9 @@ if (LAPACK_FOUND)
unset(LAPACKE_WORKS CACHE) unset(LAPACKE_WORKS CACHE)
check_function_exists(LAPACKE_dgeqrf LAPACKE_WORKS) check_function_exists(LAPACKE_dgeqrf LAPACKE_WORKS)
mark_as_advanced(LAPACKE_WORKS) mark_as_advanced(LAPACKE_WORKS)
unset(LAPACKE_WITH_LASCL CACHE)
check_function_exists(LAPACKE_dlascl_work LAPACKE_WITH_LASCL)
mark_as_advanced(LAPACKE_WITH_LASCL)
set(CMAKE_REQUIRED_LIBRARIES) set(CMAKE_REQUIRED_LIBRARIES)
if(LAPACKE_WORKS) if(LAPACKE_WORKS)
...@@ -436,7 +439,7 @@ if (LAPACK_FOUND) ...@@ -436,7 +439,7 @@ if (LAPACK_FOUND)
endif() endif()
unset(LAPACKE_WITH_LASCL CACHE) unset(LAPACKE_WITH_LASCL CACHE)
check_function_exists(LAPACKE_dlascl LAPACKE_WITH_LASCL) check_function_exists(LAPACKE_dlascl_work LAPACKE_WITH_LASCL)
mark_as_advanced(LAPACKE_WITH_LASCL) mark_as_advanced(LAPACKE_WITH_LASCL)
