Commit 147fb2de authored by PRUVOST Florent's avatar PRUVOST Florent
change the .pc files to consider, use the newest version possible
parent 82511e1d
...@@ -3,7 +3,7 @@ ...@@ -3,7 +3,7 @@
# @copyright (c) 2009-2014 The University of Tennessee and The University # @copyright (c) 2009-2014 The University of Tennessee and The University
# of Tennessee Research Foundation. # of Tennessee Research Foundation.
# All rights reserved. # All rights reserved.
# @copyright (c) 2012-2015 Inria. All rights reserved. # @copyright (c) 2012-2017 Inria. All rights reserved.
# @copyright (c) 2012-2016 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved. # @copyright (c) 2012-2016 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
...@@ -39,7 +39,7 @@ ...@@ -39,7 +39,7 @@
# STARPU_INCLUDE_DIRS_DEP - starpu + dependencies include directories # STARPU_INCLUDE_DIRS_DEP - starpu + dependencies include directories
# STARPU_LIBRARY_DIRS_DEP - starpu + dependencies link directories # STARPU_LIBRARY_DIRS_DEP - starpu + dependencies link directories
# STARPU_LIBRARIES_DEP - starpu libraries + dependencies # STARPU_LIBRARIES_DEP - starpu libraries + dependencies
# STARPU_VERSION_STRING - A human-readable string containing the version of the package found # STARPU_VERSION - A human-readable string containing the version of the package found
# STARPU_VERSION_MAJOR - The major version of the package found # STARPU_VERSION_MAJOR - The major version of the package found
# STARPU_VERSION_MINOR - The minor version of the package found # STARPU_VERSION_MINOR - The minor version of the package found
# The user can give specific paths where to find the libraries adding cmake # The user can give specific paths where to find the libraries adding cmake
...@@ -55,7 +55,7 @@ ...@@ -55,7 +55,7 @@
# Copyright 2012-2013 Emmanuel Agullo # Copyright 2012-2013 Emmanuel Agullo
# Copyright 2012-2013 Mathieu Faverge # Copyright 2012-2013 Mathieu Faverge
# Copyright 2012 Cedric Castagnede # Copyright 2012 Cedric Castagnede
# Copyright 2013 Florent Pruvost # Copyright 2013-2017 Florent Pruvost
# Distributed under the OSI-approved BSD License (the "License"); # Distributed under the OSI-approved BSD License (the "License");
# see accompanying file MORSE-Copyright.txt for details. # see accompanying file MORSE-Copyright.txt for details.
...@@ -211,11 +211,18 @@ find_package(PkgConfig QUIET) ...@@ -211,11 +211,18 @@ find_package(PkgConfig QUIET)
if(PKG_CONFIG_EXECUTABLE AND NOT STARPU_GIVEN_BY_USER) if(PKG_CONFIG_EXECUTABLE AND NOT STARPU_GIVEN_BY_USER)
pkg_search_module(STARPU_SHM libstarpu) set (STARPU_VERSION_LIST "1.3;1.2;1.1;1.0")
foreach(_version ${STARPU_VERSION_LIST})
pkg_search_module(STARPU_SHM starpu-${_version})
if (STARPU_SHM_FOUND)
set(STARPU_VERSION "${_version}" CACHE INTERNAL "StarPU version found")
break()
endif()
endforeach()
set(STARPU_INCLUDE_DIRS "${STARPU_SHM_STATIC_INCLUDE_DIRS}") set(STARPU_INCLUDE_DIRS "${STARPU_SHM_STATIC_INCLUDE_DIRS}")
set(STARPU_LIBRARY_DIRS "${STARPU_SHM_STATIC_LIBRARY_DIRS}") set(STARPU_LIBRARY_DIRS "${STARPU_SHM_STATIC_LIBRARY_DIRS}")
if(STARPU_LOOK_FOR_MPI AND MPI_FOUND) if(STARPU_LOOK_FOR_MPI AND MPI_FOUND)
pkg_search_module(STARPU_MPI libstarpumpi) pkg_search_module(STARPU_MPI starpumpi-${STARPU_VERSION})
endif() endif()
if (NOT STARPU_FIND_QUIETLY) if (NOT STARPU_FIND_QUIETLY)
if (STARPU_SHM_FOUND AND STARPU_SHM_LIBRARIES) if (STARPU_SHM_FOUND AND STARPU_SHM_LIBRARIES)
...@@ -231,39 +238,41 @@ if(PKG_CONFIG_EXECUTABLE AND NOT STARPU_GIVEN_BY_USER) ...@@ -231,39 +238,41 @@ if(PKG_CONFIG_EXECUTABLE AND NOT STARPU_GIVEN_BY_USER)
list(GET STARPU_VERSION_STRING_LIST 1 STARPU_VERSION_MINOR) list(GET STARPU_VERSION_STRING_LIST 1 STARPU_VERSION_MINOR)
else() else()
message(STATUS "${Magenta}Looking for STARPU - not found using PkgConfig." message(STATUS "${Magenta}Looking for STARPU - not found using PkgConfig."
"\n Perhaps you should add the directory containing libstarpu.pc" "\n Perhaps you should add the directory containing libstarpu.pc"
"\n to the PKG_CONFIG_PATH environment variable.${ColourReset}") "\n to the PKG_CONFIG_PATH environment variable.${ColourReset}")
endif() endif()
if (STARPU_LOOK_FOR_MPI) if (STARPU_LOOK_FOR_MPI)
if (STARPU_MPI_FOUND AND STARPU_MPI_LIBRARIES) if (STARPU_MPI_FOUND AND STARPU_MPI_LIBRARIES)
message(STATUS "Looking for STARPU MPI - found using PkgConfig") message(STATUS "Looking for STARPU MPI - found using PkgConfig")
else() else()
message(STATUS "${Magenta}Looking for STARPU MPI - not found using PkgConfig." message(STATUS "${Magenta}Looking for STARPU MPI - not found using PkgConfig."
" Perhaps you should add the directory containing libstarpumpi.pc to" " Perhaps you should add the directory containing libstarpumpi.pc to"
" the PKG_CONFIG_PATH environment variable.${ColourReset}") " the PKG_CONFIG_PATH environment variable.${ColourReset}")
endif() endif()
endif() endif()
endif()
if (STARPU_FIND_VERSION_EXACT) # check if the version found respects the minimum required
if( NOT (STARPU_FIND_VERSION_MAJOR STREQUAL STARPU_VERSION_MAJOR) OR if (STARPU_FIND_VERSION_EXACT)
NOT (STARPU_FIND_VERSION_MINOR STREQUAL STARPU_VERSION_MINOR) ) if( NOT (STARPU_FIND_VERSION_MAJOR STREQUAL STARPU_VERSION_MAJOR) OR
if(STARPU_FIND_REQUIRED AND NOT STARPU_FIND_QUIETLY) NOT (STARPU_FIND_VERSION_MINOR STREQUAL STARPU_VERSION_MINOR) )
message(FATAL_ERROR if(NOT STARPU_FIND_QUIETLY)
"STARPU version found is ${STARPU_VERSION_STRING}" message(WARNING
" when required is ${STARPU_FIND_VERSION}") "STARPU version found is ${STARPU_VERSION}"
endif()
endif() endif()
endif() else()
else() # if the version found is older than the required then error
# if the version found is older than the required then error if( (STARPU_FIND_VERSION_MAJOR STRGREATER STARPU_VERSION_MAJOR) OR
if( (STARPU_FIND_VERSION_MAJOR STRGREATER STARPU_VERSION_MAJOR) OR (STARPU_FIND_VERSION_MINOR STRGREATER STARPU_VERSION_MINOR) )
(STARPU_FIND_VERSION_MINOR STRGREATER STARPU_VERSION_MINOR) ) if(NOT STARPU_FIND_QUIETLY)
if(STARPU_FIND_REQUIRED AND NOT STARPU_FIND_QUIETLY) message(WARNING
message(FATAL_ERROR "STARPU version found is ${STARPU_VERSION}"
"STARPU version found is ${STARPU_VERSION_STRING}" " when required is ${STARPU_FIND_VERSION} or newer")
" when required is ${STARPU_FIND_VERSION} or newer") endif()
endif() endif()
endif() endif()
endif() endif()
if(STARPU_MPI_LIBRARIES) if(STARPU_MPI_LIBRARIES)
...@@ -343,33 +352,33 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -343,33 +352,33 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
foreach(starpu_hdr ${STARPU_hdrs_to_find}) foreach(starpu_hdr ${STARPU_hdrs_to_find})
set(STARPU_${starpu_hdr}_INCLUDE_DIRS "STARPU_${starpu_hdr}_INCLUDE_DIRS-NOTFOUND") set(STARPU_${starpu_hdr}_INCLUDE_DIRS "STARPU_${starpu_hdr}_INCLUDE_DIRS-NOTFOUND")
find_path(STARPU_${starpu_hdr}_INCLUDE_DIRS find_path(STARPU_${starpu_hdr}_INCLUDE_DIRS
NAMES ${starpu_hdr} NAMES ${starpu_hdr}
HINTS ${STARPU_INCDIR}) HINTS ${STARPU_INCDIR})
endforeach() endforeach()
else() else()
if(STARPU_DIR) if(STARPU_DIR)
HINTS ${STARPU_DIR} HINTS ${STARPU_DIR}
PATH_SUFFIXES "include" PATH_SUFFIXES "include"
"include/starpu/1.0" "include/starpu/1.0"
"include/starpu/1.1" "include/starpu/1.1"
"include/starpu/1.2" "include/starpu/1.2"
"include/starpu/1.3") "include/starpu/1.3")
else() else()
HINTS ${_inc_env} HINTS ${_inc_env}
PATH_SUFFIXES PATH_SUFFIXES
"starpu/1.0" "starpu/1.0"
"starpu/1.1" "starpu/1.1"
"starpu/1.2" "starpu/1.2"
"starpu/1.3") "starpu/1.3")
endif() endif()
endif() endif()
...@@ -390,8 +399,8 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -390,8 +399,8 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
string(REGEX REPLACE string(REGEX REPLACE
"(.*)define([ \t]*)${_PACKAGE}_MINOR_VERSION([ \t]*)([0-9]+)(.*)" "(.*)define([ \t]*)${_PACKAGE}_MINOR_VERSION([ \t]*)([0-9]+)(.*)"
"\\4" ${_PACKAGE}_VERSION_MINOR "${_file}") "\\4" ${_PACKAGE}_VERSION_MINOR "${_file}")
set(${_PACKAGE}_VERSION_STRING set(${_PACKAGE}_VERSION
"${${_PACKAGE}_VERSION_MAJOR}.${${_PACKAGE}_VERSION_MINOR}" CACHE PATH "StarPU version found in starpu_config.h") "${${_PACKAGE}_VERSION_MAJOR}.${${_PACKAGE}_VERSION_MINOR}" CACHE INTERNAL "StarPU version found")
#message(STATUS "${_PACKAGE}_VERSION_MAJOR = -${${_PACKAGE}_VERSION_MAJOR}-") #message(STATUS "${_PACKAGE}_VERSION_MAJOR = -${${_PACKAGE}_VERSION_MAJOR}-")
#message(STATUS "${_PACKAGE}_VERSION_MINOR = -${${_PACKAGE}_VERSION_MINOR}-") #message(STATUS "${_PACKAGE}_VERSION_MINOR = -${${_PACKAGE}_VERSION_MINOR}-")
...@@ -403,40 +412,40 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -403,40 +412,40 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
GET_VERSION("STARPU" "${STARPU_starpu_config.h_INCLUDE_DIRS}/starpu_config.h") GET_VERSION("STARPU" "${STARPU_starpu_config.h_INCLUDE_DIRS}/starpu_config.h")
if (STARPU_VERSION_MAJOR AND STARPU_VERSION_MINOR) if (STARPU_VERSION_MAJOR AND STARPU_VERSION_MINOR)
if (STARPU_FIND_VERSION_EXACT) if (STARPU_FIND_VERSION_EXACT)
if (STARPU_FIND_VERSION_MAJOR AND STARPU_FIND_VERSION_MINOR) if (STARPU_FIND_VERSION_MAJOR AND STARPU_FIND_VERSION_MINOR)
if( NOT (STARPU_FIND_VERSION_MAJOR STREQUAL STARPU_VERSION_MAJOR) OR if( NOT (STARPU_FIND_VERSION_MAJOR STREQUAL STARPU_VERSION_MAJOR) OR
NOT (STARPU_FIND_VERSION_MINOR STREQUAL STARPU_VERSION_MINOR) ) NOT (STARPU_FIND_VERSION_MINOR STREQUAL STARPU_VERSION_MINOR) )
if(STARPU_FIND_REQUIRED AND NOT STARPU_FIND_QUIETLY) if(NOT STARPU_FIND_QUIETLY)
message(FATAL_ERROR message(WARNING
"STARPU version found is ${STARPU_VERSION_STRING} " "STARPU version found is ${STARPU_VERSION} "
"when required is ${STARPU_FIND_VERSION}") "when required is ${STARPU_FIND_VERSION}")
endif() endif()
endif() endif()
endif() endif()
else() else()
# if the version found is older than the required then error # if the version found is older than the required then error
if( (STARPU_FIND_VERSION_MAJOR STRGREATER STARPU_VERSION_MAJOR) OR if( (STARPU_FIND_VERSION_MAJOR STRGREATER STARPU_VERSION_MAJOR) OR
(STARPU_FIND_VERSION_MINOR STRGREATER STARPU_VERSION_MINOR) ) (STARPU_FIND_VERSION_MINOR STRGREATER STARPU_VERSION_MINOR) )
"when required is ${STARPU_FIND_VERSION} or newer") "when required is ${STARPU_FIND_VERSION} or newer")
endif() endif()
endif() endif()
endif() endif()
endif() endif()
else() else()
if(STARPU_FIND_REQUIRED AND NOT STARPU_FIND_QUIETLY) if(STARPU_FIND_REQUIRED)
message(FATAL_ERROR message(FATAL_ERROR
"STARPU version has not been found using starpu_config.h" "STARPU version has not been found using starpu_config.h"
" located in ${STARPU_starpu_config.h_INCLUDE_DIRS}") " located in ${STARPU_starpu_config.h_INCLUDE_DIRS}")
endif() endif()
endif() endif()
else() else()
"starpu_config.h has not been found while required to get StarPU version") "starpu_config.h has not been found while required to get StarPU version")
endif() endif()
endif() endif()
...@@ -458,33 +467,33 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -458,33 +467,33 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
else() else()
else() else()
endif() endif()
endif() endif()
...@@ -499,24 +508,24 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -499,24 +508,24 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
list(APPEND STARPU_INCLUDE_DIRS "${STARPU_${starpu_hdr}_INCLUDE_DIRS}" ) list(APPEND STARPU_INCLUDE_DIRS "${STARPU_${starpu_hdr}_INCLUDE_DIRS}" )
else () else ()
if(NOT STARPU_FIND_QUIETLY) if(NOT STARPU_FIND_QUIETLY)
message(STATUS "Looking for starpu -- ${starpu_hdr} not found") message(STATUS "Looking for starpu -- ${starpu_hdr} not found")
endif() endif()
if(starpu_hdr STREQUAL "starpu_mpi.h") if(starpu_hdr STREQUAL "starpu_mpi.h")
if(NOT STARPU_FIND_REQUIRED_MPI) if(NOT STARPU_FIND_REQUIRED_MPI)
message(STATUS "Looking for starpu -- ${starpu_hdr} not required") message(STATUS "Looking for starpu -- ${starpu_hdr} not required")
endif() endif()
else() else()
endif() endif()
elseif( (starpu_hdr STREQUAL "starpu_cuda.h") OR (starpu_hdr STREQUAL "starpu_scheduler.h") ) elseif( (starpu_hdr STREQUAL "starpu_cuda.h") OR (starpu_hdr STREQUAL "starpu_scheduler.h") )
if(NOT STARPU_FIND_REQUIRED_CUDA) if(NOT STARPU_FIND_REQUIRED_CUDA)
endif() endif()
else() else()
endif() endif()
endif() endif()
endif () endif ()
mark_as_advanced(STARPU_${starpu_hdr}_INCLUDE_DIRS) mark_as_advanced(STARPU_${starpu_hdr}_INCLUDE_DIRS)
...@@ -546,15 +555,15 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -546,15 +555,15 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
list(APPEND _lib_env "${ENV_STARPU_DIR}/lib") list(APPEND _lib_env "${ENV_STARPU_DIR}/lib")
else() else()
if(WIN32) if(WIN32)
string(REPLACE ":" ";" _lib_env "$ENV{LIB}") string(REPLACE ":" ";" _lib_env "$ENV{LIB}")
else() else()
if(APPLE) if(APPLE)
string(REPLACE ":" ";" _lib_env "$ENV{DYLD_LIBRARY_PATH}") string(REPLACE ":" ";" _lib_env "$ENV{DYLD_LIBRARY_PATH}")
else() else()
string(REPLACE ":" ";" _lib_env "$ENV{LD_LIBRARY_PATH}") string(REPLACE ":" ";" _lib_env "$ENV{LD_LIBRARY_PATH}")
endif() endif()
list(APPEND _lib_env "${CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES}") list(APPEND _lib_env "${CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES}")
list(APPEND _lib_env "${CMAKE_C_IMPLICIT_LINK_DIRECTORIES}") list(APPEND _lib_env "${CMAKE_C_IMPLICIT_LINK_DIRECTORIES}")
endif() endif()
endif() endif()
list(REMOVE_DUPLICATES _lib_env) list(REMOVE_DUPLICATES _lib_env)
...@@ -563,37 +572,37 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -563,37 +572,37 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
# create list of libs to find # create list of libs to find
set(STARPU_libs_to_find "starpu-${STARPU_VERSION_STRING}") set(STARPU_libs_to_find "starpu-${STARPU_VERSION}")
set(STARPU_SHM_libs_to_find "starpu-${STARPU_VERSION_STRING}") set(STARPU_SHM_libs_to_find "starpu-${STARPU_VERSION}")
if (STARPU_LOOK_FOR_MPI OR MPI_FOUND) if (STARPU_LOOK_FOR_MPI OR MPI_FOUND)
list(INSERT STARPU_libs_to_find 0 "starpumpi-${STARPU_VERSION_STRING}") list(INSERT STARPU_libs_to_find 0 "starpumpi-${STARPU_VERSION}")
set(STARPU_MPI_libs_to_find "${STARPU_libs_to_find}") set(STARPU_MPI_libs_to_find "${STARPU_libs_to_find}")
endif() endif()
# call cmake macro to find the lib path # call cmake macro to find the lib path
if(STARPU_LIBDIR) if(STARPU_LIBDIR)
foreach(starpu_lib ${STARPU_libs_to_find}) foreach(starpu_lib ${STARPU_libs_to_find})
set(STARPU_${starpu_lib}_LIBRARY "STARPU_${starpu_lib}_LIBRARY-NOTFOUND") set(STARPU_${starpu_lib}_LIBRARY "STARPU_${starpu_lib}_LIBRARY-NOTFOUND")
find_library(STARPU_${starpu_lib}_LIBRARY find_library(STARPU_${starpu_lib}_LIBRARY
NAMES ${starpu_lib} NAMES ${starpu_lib}
HINTS ${STARPU_LIBDIR}) HINTS ${STARPU_LIBDIR})
else() else()
PATH_SUFFIXES lib lib32 lib64) PATH_SUFFIXES lib lib32 lib64)
else() else()
HINTS ${_lib_env}) HINTS ${_lib_env})
endif() endif()
endif() endif()
...@@ -603,49 +612,49 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -603,49 +612,49 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
if (STARPU_${starpu_lib}_LIBRARY) if (STARPU_${starpu_lib}_LIBRARY)
get_filename_component(${starpu_lib}_lib_path ${STARPU_${starpu_lib}_LIBRARY} PATH) get_filename_component(${starpu_lib}_lib_path ${STARPU_${starpu_lib}_LIBRARY} PATH)
# set cmake variables (respects naming convention) # set cmake variables (respects naming convention)
foreach(starpu_shm_lib ${STARPU_SHM_libs_to_find}) foreach(starpu_shm_lib ${STARPU_SHM_libs_to_find})
if(starpu_shm_lib STREQUAL starpu_lib) if(starpu_shm_lib STREQUAL starpu_lib)
list(APPEND STARPU_SHM_LIBRARIES "${STARPU_${starpu_lib}_LIBRARY}") list(APPEND STARPU_SHM_LIBRARIES "${STARPU_${starpu_lib}_LIBRARY}")
endif() endif()
if (STARPU_LOOK_FOR_MPI AND MPI_FOUND) if (STARPU_LOOK_FOR_MPI AND MPI_FOUND)
foreach(starpu_mpi_lib ${STARPU_MPI_libs_to_find}) foreach(starpu_mpi_lib ${STARPU_MPI_libs_to_find})
if(starpu_mpi_lib STREQUAL starpu_lib) if(starpu_mpi_lib STREQUAL starpu_lib)
list(APPEND STARPU_MPI_LIBRARIES "${STARPU_${starpu_lib}_LIBRARY}") list(APPEND STARPU_MPI_LIBRARIES "${STARPU_${starpu_lib}_LIBRARY}")
endif() endif()
endif () endif ()
list(APPEND STARPU_LIBRARY_DIRS "${${starpu_lib}_lib_path}") list(APPEND STARPU_LIBRARY_DIRS "${${starpu_lib}_lib_path}")
else (STARPU_${starpu_lib}_LIBRARY) else (STARPU_${starpu_lib}_LIBRARY)
message(STATUS "Looking for starpu -- lib ${starpu_lib} not found") message(STATUS "Looking for starpu -- lib ${starpu_lib} not found")
endif() endif()
if(starpu_lib STREQUAL "starpumpi-${STARPU_VERSION_STRING}" AND if(starpu_lib STREQUAL "starpumpi-${STARPU_VERSION}" AND
NOT STARPU_FIND_REQUIRED_MPI) NOT STARPU_FIND_REQUIRED_MPI)
# if MPI optional, not a problem: no NOTFOUND in list of MPI LIBRARIES # if MPI optional, not a problem: no NOTFOUND in list of MPI LIBRARIES
message(STATUS "Looking for starpu -- lib ${starpu_lib} not required") message(STATUS "Looking for starpu -- lib ${starpu_lib} not required")
endif() endif()
else() else()
# for any other lib, add NOTFOUND in the proper list of LIBRARIES # for any other lib, add NOTFOUND in the proper list of LIBRARIES
set(STARPU_SHM_LIBRARIES "${STARPU_${starpu_lib}_LIBRARY}") set(STARPU_SHM_LIBRARIES "${STARPU_${starpu_lib}_LIBRARY}")
endif() endif()
list(APPEND STARPU_MPI_LIBRARIES "${STARPU_${starpu_mpi_lib}_LIBRARY}") list(APPEND STARPU_MPI_LIBRARIES "${STARPU_${starpu_mpi_lib}_LIBRARY}")
endif() endif()
endif () endif ()
endif() endif()
endif (STARPU_${starpu_lib}_LIBRARY) endif (STARPU_${starpu_lib}_LIBRARY)
...@@ -662,7 +671,7 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -662,7 +671,7 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
if (STARPU_SHM_LIBRARIES AND STARPU_LIBRARY_DIRS AND STARPU_INCLUDE_DIRS) if (STARPU_SHM_LIBRARIES AND STARPU_LIBRARY_DIRS AND STARPU_INCLUDE_DIRS)
set(STARPU_SHM_FOUND TRUE) set(STARPU_SHM_FOUND TRUE)
set(STARPU_MPI_FOUND TRUE) set(STARPU_MPI_FOUND TRUE)
endif() endif()
endif() endif()
...@@ -704,142 +713,142 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -704,142 +713,142 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
set(CMAKE_REQUIRED_FLAGS) set(CMAKE_REQUIRED_FLAGS)
foreach(libdir ${STARPU_LIBRARY_DIRS}) foreach(libdir ${STARPU_LIBRARY_DIRS})
if (libdir) if (libdir)
list(APPEND REQUIRED_LIBDIRS "${libdir}") list(APPEND REQUIRED_LIBDIRS "${libdir}")
endif() endif()
set(REQUIRED_LIBS "${STARPU_LIBRARIES}") set(REQUIRED_LIBS "${STARPU_LIBRARIES}")
# HWLOC # HWLOC
if (HWLOC_FOUND AND STARPU_LOOK_FOR_HWLOC) if (HWLOC_FOUND AND STARPU_LOOK_FOR_HWLOC)
if (HWLOC_INCLUDE_DIRS) if (HWLOC_INCLUDE_DIRS)
list(APPEND REQUIRED_INCDIRS "${HWLOC_INCLUDE_DIRS}") list(APPEND REQUIRED_INCDIRS "${HWLOC_INCLUDE_DIRS}")
endif() endif()
if (HWLOC_LIBRARY_DIRS) if (HWLOC_LIBRARY_DIRS)
list(APPEND REQUIRED_LIBDIRS "${HWLOC_LIBRARY_DIRS}") list(APPEND REQUIRED_LIBDIRS "${HWLOC_LIBRARY_DIRS}")
endif() endif()
foreach(lib ${HWLOC_LIBRARIES}) foreach(lib ${HWLOC_LIBRARIES})
if (EXISTS ${lib} OR ${lib} MATCHES "^-") if (EXISTS ${lib} OR ${lib} MATCHES "^-")
list(APPEND REQUIRED_LIBS "${lib}") list(APPEND REQUIRED_LIBS "${lib}")
else() else()
list(APPEND REQUIRED_LIBS "-l${lib}") list(APPEND REQUIRED_LIBS "-l${lib}")
endif() endif()
endif() endif()
# MPI # MPI
if (MPI_FOUND AND STARPU_LOOK_FOR_MPI) if (MPI_FOUND AND STARPU_LOOK_FOR_MPI)
if (MPI_C_INCLUDE_PATH) if (MPI_C_INCLUDE_PATH)
list(APPEND REQUIRED_INCDIRS "${MPI_C_INCLUDE_PATH}") list(APPEND REQUIRED_INCDIRS "${MPI_C_INCLUDE_PATH}")
endif() endif()
if (MPI_C_LINK_FLAGS) if (MPI_C_LINK_FLAGS)
if (${MPI_C_LINK_FLAGS} MATCHES " -") if (${MPI_C_LINK_FLAGS} MATCHES " -")
string(REGEX REPLACE " -" "-" MPI_C_LINK_FLAGS ${MPI_C_LINK_FLAGS}) string(REGEX REPLACE " -" "-" MPI_C_LINK_FLAGS ${MPI_C_LINK_FLAGS})
endif() endif()
list(APPEND REQUIRED_LDFLAGS "${MPI_C_LINK_FLAGS}") list(APPEND REQUIRED_LDFLAGS "${MPI_C_LINK_FLAGS}")
endif() endif()
list(APPEND REQUIRED_LIBS "${MPI_C_LIBRARIES}") list(APPEND REQUIRED_LIBS "${MPI_C_LIBRARIES}")
endif() endif()
# MAGMA # MAGMA
if (MAGMA_FOUND AND STARPU_LOOK_FOR_MAGMA) if (MAGMA_FOUND AND STARPU_LOOK_FOR_MAGMA)
if (MAGMA_INCLUDE_DIRS_DEP) if (MAGMA_INCLUDE_DIRS_DEP)
list(APPEND REQUIRED_INCDIRS "${MAGMA_INCLUDE_DIRS_DEP}") list(APPEND REQUIRED_INCDIRS "${MAGMA_INCLUDE_DIRS_DEP}")
elseif(MAGMA_INCLUDE_DIRS) elseif(MAGMA_INCLUDE_DIRS)
list(APPEND REQUIRED_INCDIRS "${MAGMA_INCLUDE_DIRS}") list(APPEND REQUIRED_INCDIRS "${MAGMA_INCLUDE_DIRS}")
endif() endif()
if (MAGMA_LIBRARY_DIRS_DEP) if (MAGMA_LIBRARY_DIRS_DEP)
list(APPEND REQUIRED_LIBDIRS "${MAGMA_LIBRARY_DIRS_DEP}") list(APPEND REQUIRED_LIBDIRS "${MAGMA_LIBRARY_DIRS_DEP}")
elseif(MAGMA_LIBRARY_DIRS) elseif(MAGMA_LIBRARY_DIRS)
list(APPEND REQUIRED_LIBDIRS "${MAGMA_LIBRARY_DIRS}") list(APPEND REQUIRED_LIBDIRS "${MAGMA_LIBRARY_DIRS}")
endif() endif()
if (MAGMA_LIBRARIES_DEP) if (MAGMA_LIBRARIES_DEP)
list(APPEND REQUIRED_LIBS "${MAGMA_LIBRARIES_DEP}") list(APPEND REQUIRED_LIBS "${MAGMA_LIBRARIES_DEP}")
elseif(MAGMA_LIBRARIES) elseif(MAGMA_LIBRARIES)
foreach(lib ${MAGMA_LIBRARIES}) foreach(lib ${MAGMA_LIBRARIES})
else() else()
endif() endif()
endif() endif()
if (MAGMA_LINKER_FLAGS) if (MAGMA_LINKER_FLAGS)
list(APPEND REQUIRED_LDFLAGS "${MAGMA_LINKER_FLAGS}") list(APPEND REQUIRED_LDFLAGS "${MAGMA_LINKER_FLAGS}")
endif() endif()
endif() endif()
# CUDA # CUDA
if (CUDA_FOUND AND STARPU_LOOK_FOR_CUDA) if (CUDA_FOUND AND STARPU_LOOK_FOR_CUDA)
if (CUDA_INCLUDE_DIRS) if (CUDA_INCLUDE_DIRS)
list(APPEND REQUIRED_INCDIRS "${CUDA_INCLUDE_DIRS}") list(APPEND REQUIRED_INCDIRS "${CUDA_INCLUDE_DIRS}")
endif() endif()
if (CUDA_LIBRARY_DIRS) if (CUDA_LIBRARY_DIRS)
list(APPEND REQUIRED_LIBDIRS "${CUDA_LIBRARY_DIRS}") list(APPEND REQUIRED_LIBDIRS "${CUDA_LIBRARY_DIRS}")
endif() endif()
list(APPEND REQUIRED_LIBS "${CUDA_CUBLAS_LIBRARIES};${CUDA_LIBRARIES}") list(APPEND REQUIRED_LIBS "${CUDA_CUBLAS_LIBRARIES};${CUDA_LIBRARIES}")
endif() endif()
# FXT # FXT
if (FXT_FOUND AND STARPU_LOOK_FOR_FXT) if (FXT_FOUND AND STARPU_LOOK_FOR_FXT)
if (FXT_INCLUDE_DIRS) if (FXT_INCLUDE_DIRS)
list(APPEND REQUIRED_INCDIRS "${FXT_INCLUDE_DIRS}") list(APPEND REQUIRED_INCDIRS "${FXT_INCLUDE_DIRS}")
endif() endif()
if (FXT_LIBRARY_DIRS) if (FXT_LIBRARY_DIRS)
list(APPEND REQUIRED_LIBDIRS "${FXT_LIBRARY_DIRS}") list(APPEND REQUIRED_LIBDIRS "${FXT_LIBRARY_DIRS}")
endif() endif()
foreach(lib ${FXT_LIBRARIES}) foreach(lib ${FXT_LIBRARIES})
else() else()
endif() endif()
endif() endif()
# SIMGRID # SIMGRID
if (SIMGRID_FOUND AND STARPU_LOOK_FOR_SIMGRID) if (SIMGRID_FOUND AND STARPU_LOOK_FOR_SIMGRID)
if (SIMGRID_INCLUDE_DIRS) if (SIMGRID_INCLUDE_DIRS)
list(APPEND REQUIRED_INCDIRS "${SIMGRID_INCLUDE_DIRS}") list(APPEND REQUIRED_INCDIRS "${SIMGRID_INCLUDE_DIRS}")
endif() endif()
if (SIMGRID_LIBRARY_DIRS) if (SIMGRID_LIBRARY_DIRS)
list(APPEND REQUIRED_LIBDIRS "${SIMGRID_LIBRARY_DIRS}") list(APPEND REQUIRED_LIBDIRS "${SIMGRID_LIBRARY_DIRS}")
endif() endif()
foreach(lib ${SIMGRID_LIBRARIES}) foreach(lib ${SIMGRID_LIBRARIES})
else() else()
endif() endif()
list(APPEND REQUIRED_FLAGS "-include starpu_simgrid_wrap.h") list(APPEND REQUIRED_FLAGS "-include starpu_simgrid_wrap.h")
endif() endif()
# BLAS # BLAS
if (BLAS_FOUND AND STARPU_LOOK_FOR_BLAS) if (BLAS_FOUND AND STARPU_LOOK_FOR_BLAS)
if (BLAS_INCLUDE_DIRS) if (BLAS_INCLUDE_DIRS)
list(APPEND REQUIRED_INCDIRS "${BLAS_INCLUDE_DIRS}") list(APPEND REQUIRED_INCDIRS "${BLAS_INCLUDE_DIRS}")
endif() endif()
if (BLAS_LIBRARY_DIRS) if (BLAS_LIBRARY_DIRS)
list(APPEND REQUIRED_LIBDIRS "${BLAS_LIBRARY_DIRS}") list(APPEND REQUIRED_LIBDIRS "${BLAS_LIBRARY_DIRS}")
endif() endif()
list(APPEND REQUIRED_LIBS "${BLAS_LIBRARIES}") list(APPEND REQUIRED_LIBS "${BLAS_LIBRARIES}")
if (BLAS_LINKER_FLAGS) if (BLAS_LINKER_FLAGS)
list(APPEND REQUIRED_LDFLAGS "${BLAS_LINKER_FLAGS}") list(APPEND REQUIRED_LDFLAGS "${BLAS_LINKER_FLAGS}")
endif() endif()
endif() endif()
# Fortran # Fortran
if (CMAKE_C_COMPILER_ID MATCHES "GNU") if (CMAKE_C_COMPILER_ID MATCHES "GNU")
find_library( find_library(
FORTRAN_gfortran_LIBRARY FORTRAN_gfortran_LIBRARY
NAMES gfortran NAMES gfortran
HINTS ${_lib_env} HINTS ${_lib_env}
mark_as_advanced(FORTRAN_gfortran_LIBRARY) mark_as_advanced(FORTRAN_gfortran_LIBRARY)
if (FORTRAN_gfortran_LIBRARY AND CMAKE_C_COMPILER_ID STREQUAL "GNU") if (FORTRAN_gfortran_LIBRARY AND CMAKE_C_COMPILER_ID STREQUAL "GNU")
list(APPEND REQUIRED_LIBS "${FORTRAN_gfortran_LIBRARY}") list(APPEND REQUIRED_LIBS "${FORTRAN_gfortran_LIBRARY}")
endif() endif()
elseif (CMAKE_C_COMPILER_ID MATCHES "Intel") elseif (CMAKE_C_COMPILER_ID MATCHES "Intel")
FORTRAN_ifcore_LIBRARY FORTRAN_ifcore_LIBRARY
NAMES ifcore NAMES ifcore
mark_as_advanced(FORTRAN_ifcore_LIBRARY) mark_as_advanced(FORTRAN_ifcore_LIBRARY)
if (FORTRAN_ifcore_LIBRARY) if (FORTRAN_ifcore_LIBRARY)
list(APPEND REQUIRED_LIBS "${FORTRAN_ifcore_LIBRARY}") list(APPEND REQUIRED_LIBS "${FORTRAN_ifcore_LIBRARY}")
endif() endif()
endif() endif()
# EXTRA LIBS such that pthread, m, rt # EXTRA LIBS such that pthread, m, rt
...@@ -865,9 +874,9 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -865,9 +874,9 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
if(STARPU_WORKS) if(STARPU_WORKS)
# save link with dependencies # save link with dependencies
if (REQUIRED_FLAGS) if (REQUIRED_FLAGS)
set(STARPU_LIBRARIES_DEP "${REQUIRED_FLAGS};${REQUIRED_LIBS}") set(STARPU_LIBRARIES_DEP "${REQUIRED_FLAGS};${REQUIRED_LIBS}")
else() else()
set(STARPU_LIBRARIES_DEP "${REQUIRED_LIBS}") set(STARPU_LIBRARIES_DEP "${REQUIRED_LIBS}")
endif() endif()
set(STARPU_LIBRARY_DIRS_DEP "${REQUIRED_LIBDIRS}") set(STARPU_LIBRARY_DIRS_DEP "${REQUIRED_LIBDIRS}")
set(STARPU_INCLUDE_DIRS_DEP "${REQUIRED_INCDIRS}") set(STARPU_INCLUDE_DIRS_DEP "${REQUIRED_INCDIRS}")
...@@ -877,13 +886,13 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND) ...@@ -877,13 +886,13 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT STARPU_FOUND)
list(REMOVE_DUPLICATES STARPU_LINKER_FLAGS) list(REMOVE_DUPLICATES STARPU_LINKER_FLAGS)
else() else()
message(STATUS "Looking for starpu : test of starpu_init fails") message(STATUS "Looking for starpu : test of starpu_init fails")
message(STATUS "CMAKE_REQUIRED_LIBRARIES: ${CMAKE_REQUIRED_LIBRARIES}") message(STATUS "CMAKE_REQUIRED_LIBRARIES: ${CMAKE_REQUIRED_LIBRARIES}")
message(STATUS "CMAKE_REQUIRED_INCLUDES: ${CMAKE_REQUIRED_INCLUDES}") message(STATUS "CMAKE_REQUIRED_INCLUDES: ${CMAKE_REQUIRED_INCLUDES}")
message(STATUS "Check in CMakeFiles/CMakeError.log to figure out why it fails") message(STATUS "Check in CMakeFiles/CMakeError.log to figure out why it fails")
message(STATUS "Maybe STARPU is linked with specific libraries. " message(STATUS "Maybe STARPU is linked with specific libraries. "
"Have you tried with COMPONENTS (HWLOC, CUDA, MPI, BLAS, MAGMA, FXT, SIMGRID)? " "Have you tried with COMPONENTS (HWLOC, CUDA, MPI, BLAS, MAGMA, FXT, SIMGRID)? "
"See the explanation in FindSTARPU.cmake.") "See the explanation in FindSTARPU.cmake.")
endif() endif()
endif() endif()
set(CMAKE_REQUIRED_INCLUDES) set(CMAKE_REQUIRED_INCLUDES)
...@@ -897,7 +906,7 @@ if (STARPU_LIBRARIES) ...@@ -897,7 +906,7 @@ if (STARPU_LIBRARIES)
if (STARPU_LIBRARY_DIRS) if (STARPU_LIBRARY_DIRS)
foreach(dir ${STARPU_LIBRARY_DIRS}) foreach(dir ${STARPU_LIBRARY_DIRS})
if ("${dir}" MATCHES "starpu") if ("${dir}" MATCHES "starpu")
set(first_lib_path "${dir}") set(first_lib_path "${dir}")
endif() endif()
else() else()
...@@ -922,8 +931,8 @@ if(NOT STARPU_FIND_QUIETLY) ...@@ -922,8 +931,8 @@ if(NOT STARPU_FIND_QUIETLY)
message(STATUS "StarPU library has been found.") message(STATUS "StarPU library has been found.")
message(STATUS "The mpi version of StarPU has been found so that we manage" message(STATUS "The mpi version of StarPU has been found so that we manage"
" two lists of libs, one sequential and one parallel (see" " two lists of libs, one sequential and one parallel (see"
" STARPU_SHM_LIBRARIES and STARPU_MPI_LIBRARIES).") " STARPU_SHM_LIBRARIES and STARPU_MPI_LIBRARIES).")
endif() endif()
message(STATUS "StarPU shared memory libraries stored in STARPU_SHM_LIBRARIES") message(STATUS "StarPU shared memory libraries stored in STARPU_SHM_LIBRARIES")
endif() endif()
