Commit d359974a authored by Antoine Jego's avatar Antoine Jego :alembic:
added option to disable flushing or enable pruning
parent 52289146
...@@ -58,6 +58,8 @@ static struct argp_option options[] = { ...@@ -58,6 +58,8 @@ static struct argp_option options[] = {
{"niter", 'l', "int", 0, "Number of iterations (loops)"}, {"niter", 'l', "int", 0, "Number of iterations (loops)"},
{"mpi-thread",'t', "int", 0, "MPI thread level support : -1 StarPU, 0 SINGLE, 1 FUNNELED, 2 SERIALIZED, 3 MULTIPLE"}, {"mpi-thread",'t', "int", 0, "MPI thread level support : -1 StarPU, 0 SINGLE, 1 FUNNELED, 2 SERIALIZED, 3 MULTIPLE"},
{"datatype", 'd', 0, 0, "Whether or not to use our own datatype implementation"}, {"datatype", 'd', 0, 0, "Whether or not to use our own datatype implementation"},
{"no-flush", 's', 0, 0, "If handed out to the program, do not flush anything until computation has completed."},
{"prune", 'r', 0, 0, "If handed out to the program, prune the DAG as tightly as possible."},
{ 0 } { 0 }
...@@ -69,6 +71,7 @@ struct arguments ...@@ -69,6 +71,7 @@ struct arguments
int check,verbose,trace; int check,verbose,trace;
int niter; int niter;
int mpi_thread, datatype; int mpi_thread, datatype;
int no_flush, prune;
...@@ -114,6 +117,12 @@ parse_opt (int key, char *arg, struct argp_state *state) ...@@ -114,6 +117,12 @@ parse_opt (int key, char *arg, struct argp_state *state)
case 'd': case 'd':
arguments->datatype = 1; arguments->datatype = 1;
break; break;
case 's':
arguments->no_flush = 1;
break;
case 'r':
arguments->prune = 1;
break;
default: default:
return ARGP_ERR_UNKNOWN; return ARGP_ERR_UNKNOWN;
...@@ -134,6 +143,8 @@ static int datatype = ...@@ -134,6 +143,8 @@ static int datatype =
STARPU_EXAMPLE_DGEMM_OWNDATATYPE; /* whether to register our own datatype */ STARPU_EXAMPLE_DGEMM_OWNDATATYPE; /* whether to register our own datatype */
static int mpi_thread = -1; /* whether to register our own datatype */ static int mpi_thread = -1; /* whether to register our own datatype */
static int verbose = 0; static int verbose = 0;
static int flush = 1;
static int prune = 0;
#define MB ((M)/(BS)) /* Number of blocks */ #define MB ((M)/(BS)) /* Number of blocks */
#define NB ((N)/(BS)) /* Number of blocks */ #define NB ((N)/(BS)) /* Number of blocks */
...@@ -338,6 +349,8 @@ int main(int argc, char *argv[]) ...@@ -338,6 +349,8 @@ int main(int argc, char *argv[])
arguments.niter = T; arguments.niter = T;
arguments.mpi_thread = mpi_thread; arguments.mpi_thread = mpi_thread;
arguments.datatype = datatype; arguments.datatype = datatype;
arguments.no_flush = 0;
arguments.prune = 0;
argp_parse(&argp, argc, argv, 0, 0, &arguments); argp_parse(&argp, argc, argv, 0, 0, &arguments);
M = arguments.m; M = arguments.m;
...@@ -352,6 +365,8 @@ int main(int argc, char *argv[]) ...@@ -352,6 +365,8 @@ int main(int argc, char *argv[])
T = arguments.niter; T = arguments.niter;
mpi_thread = arguments.mpi_thread; mpi_thread = arguments.mpi_thread;
datatype = arguments.datatype; datatype = arguments.datatype;
flush = !arguments.no_flush;
prune = arguments.prune;
/* Initializes StarPU and the StarPU-MPI layer */ /* Initializes StarPU and the StarPU-MPI layer */
starpu_fxt_autostart_profiling(0); starpu_fxt_autostart_profiling(0);
...@@ -411,6 +426,8 @@ int main(int argc, char *argv[]) ...@@ -411,6 +426,8 @@ int main(int argc, char *argv[])
if (trace) printf("- Tracing enabled\n"); if (trace) printf("- Tracing enabled\n");
if (datatype) printf("- MPI datatype enabled\n"); if (datatype) printf("- MPI datatype enabled\n");
if (mpi_thread > -1) printf("MPI thread support level : %d\n", provided_mpi_thread); if (mpi_thread > -1) printf("MPI thread support level : %d\n", provided_mpi_thread);
if (!flush) printf("- Flushing disabled\n");
if (prune) printf("- Pruning enabled\n");
int barrier_ret, trial; int barrier_ret, trial;
double start, stop; double start, stop;
...@@ -433,23 +450,27 @@ int main(int argc, char *argv[]) ...@@ -433,23 +450,27 @@ int main(int argc, char *argv[])
for (b_aisle=0;b_aisle<KB;b_aisle++) for (b_aisle=0;b_aisle<KB;b_aisle++)
// printf("[%d] inserting C_%d,%d += A_%d,%d B_%d,%d\n",comm_rank, b_row,b_col, b_row,b_aisle, b_aisle,b_col); // printf("[%d] inserting C_%d,%d += A_%d,%d B_%d,%d\n",comm_rank, b_row,b_col, b_row,b_aisle, b_aisle,b_col);
struct cl_zgemm_args_s *clargs = NULL; if (!prune || (A->blocks[b_row*KB+b_aisle].owner == comm_rank || B->blocks[b_aisle*NB+b_col].owner == comm_rank || C->blocks[b_row*NB+b_col].owner == comm_rank)) {
if (C->blocks[b_row*NB+b_col].owner == comm_rank) { struct cl_zgemm_args_s *clargs = NULL;
clargs = malloc(sizeof( struct cl_zgemm_args_s )); if (C->blocks[b_row*NB+b_col].owner == comm_rank) {
clargs->alpha = alpha; clargs = malloc(sizeof( struct cl_zgemm_args_s ));
clargs->beta = b_aisle==0? beta : 1.0; clargs->alpha = alpha;
starpu_mpi_task_insert(MPI_COMM_WORLD, &gemm_cl,
STARPU_CL_ARGS, clargs, sizeof(struct cl_zgemm_args_s),
STARPU_R, A_h[b_row*KB+b_aisle],
STARPU_R, B_h[b_aisle*NB+b_col],
STARPU_RW, C_h[b_row*NB+b_col], 0);
// printf("[%d] inserted C_%d,%d += A_%d,%d B_%d,%d\n",comm_rank, b_row,b_col, b_row,b_aisle, b_aisle,b_col);
for (b_aisle=0;b_aisle<KB;b_aisle++) if (flush) {
{ for (b_aisle=0;b_aisle<KB;b_aisle++)
starpu_mpi_cache_flush(MPI_COMM_WORLD, A_h[b_row*KB+b_aisle]); {
