GitLab
Explore
Primary navigation
Search or go to…
H
hqr
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container Registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
hqr
d02d9e85
d02d9e85
8 years ago
BOUCHERIE Raphael
Downloads
Patches
Updated drawinf functions, added factorisation parameters, allowing to change color
3326debb
1 merge request
!4
Treewalk
3
3 changed files
include/libdraw.h
+2
-3
2 additions, 3 deletions
include/libdraw.h
src/treedraw.c
+35
-7
35 additions, 7 deletions
src/treedraw.c
testings/testing_treedraw.c
+6
-5
6 additions, 5 deletions
43 additions
15 deletions
include/libdraw.h
2
3
d02d9e85
@@ -27,10 +27,9 @@ BEGIN_C_DECLS
void
libhqr_writeheader
FILE
tree
void
libhqr_writecss
void
libhqr_writeend
FILE
tree
void
libhqr_drawTT
int
x
int
y
int
w
int
h
FILE
tree
void
libhqr_drawTS
int
x
int
y
int
w
int
h
FILE
tree
void
libhqr_drawTT
int
x
int
y
int
w
int
h
int
k
FILE
tree
void
libhqr_drawTS
int
x
int
y
int
w
int
h
int
k
FILE
tree
void
libhqr_drawline
int
x1
int
y1
int
x2
int
y2
FILE
tree
END_C_DECLS
This diff is collapsed.
src/treedraw.c
35
7
d02d9e85
@@ -28,14 +28,42 @@ void libhqr_writeheader(FILE *tree){
if
fprintf
tree
"<svg width=
2000
height=
2000
version=
1.1
\n
xmlns=
http://www.w3.org/2000/svg
\n
return
void
libhqr_writecss
void
libhqr_drawTT
int
x
int
y
int
w
int
h
FILE
tree
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
red
\n
x
y
w
h
return
void
libhqr_drawTT
int
x
int
y
int
w
int
h
int
k
FILE
tree
switch
k
4
case
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
red
\n
x
y
w
h
return
break
case
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
blue
\n
x
y
w
h
return
break
case
2
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
green
\n
x
y
w
h
return
break
case
3
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
black
\n
x
y
w
h
return
break
default:
return
void
libhqr_drawTS
int
x
int
y
int
w
int
h
FILE
tree
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill =
red
\n
x
y
w
h
return
void
libhqr_drawTS
int
x
int
y
int
w
int
h
int
k
FILE
tree
switch
k
4
case
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
red
\n
x
y
w
h
return
break
case
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
blue
\n
x
y
w
h
return
break
case
2
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
green
\n
x
y
w
h
return
break
case
3
if
fprintf
tree
"<rect x=
%d
y=
%d
width=
%d
height=
%d
fill=
black
\n
x
y
w
h
return
break
default:
return
int
x2
x
w
4
int
y2
y
h
4
int
w2
w
2
@@ -44,7 +72,7 @@ void libhqr_drawTS(int x, int y, int w, int h, FILE *tree){
void
libhqr_drawline
int
x1
int
y1
int
x2
int
y2
FILE
tree
if
fprintf
tree
"<line x1=
%d
y1=
%d
x2=
%d
y2=
%d
\n
x1
y1
x2
y2
return
if
fprintf
tree
"<line x1=
%d
y1=
%d
x2=
%d
y2=
%d
style=
fill:none;stroke:black;stroke-width:2px;
\n
x1
y1
x2
y2
return
void
libhqr_writeend
FILE
tree
6
5
d02d9e85
@@ -19,20 +19,21 @@
#include
<string.h>
#include
"libdraw.h"
#define WIDTH 50
#define HEIGHT 50
int
main
int
argc
char
argv
FILE
tree
fopen
"tree.svg"
"w+"
int
x
y
w
h
i
j
w
50
h
50
int
x
y
i
j
libhqr_writeheader
tree
libhqr_drawline
125
100
125
800
tree
for
i
i
5
i
for
j
j
9
j
x
100
i
y
100
j
libhqr_drawline
x
y
w
h
tree
libhqr_drawTS
x
y
w
h
tree
libhqr_drawTS
x
y
WIDTH
HEIGHT
tree
libhqr_writeend
tree
Loading
Save comment
