Commit cea5a737 authored by PRUVOST Florent's avatar PRUVOST Florent
sonarqube: fix coverage filename to import
parent c287d4e3
...@@ -66,7 +66,7 @@ sonar.cxx.gcc.encoding=UTF-8 ...@@ -66,7 +66,7 @@ sonar.cxx.gcc.encoding=UTF-8
sonar.cxx.gcc.regex=(?<file>.*):(?<line>[0-9]+):[0-9]+:\\\x20warning:\\\x20(?<message>.*)\\\x20\\\[(?<id>.*)\\\] sonar.cxx.gcc.regex=(?<file>.*):(?<line>[0-9]+):[0-9]+:\\\x20warning:\\\x20(?<message>.*)\\\x20\\\[(?<id>.*)\\\]
sonar.cxx.gcc.reportPaths=hqr-build*.log sonar.cxx.gcc.reportPaths=hqr-build*.log
sonar.cxx.xunit.reportPaths=junit.xml sonar.cxx.xunit.reportPaths=junit.xml
sonar.cxx.cobertura.reportPaths=hqr-coverage.xml sonar.cxx.cobertura.reportPaths=coverage.xml
sonar.cxx.cppcheck.reportPaths=hqr-cppcheck.xml sonar.cxx.cppcheck.reportPaths=hqr-cppcheck.xml
sonar.cxx.rats.reportPaths=hqr-rats.xml sonar.cxx.rats.reportPaths=hqr-rats.xml
EOF EOF
