Commit 9851040e authored by Mathieu Faverge's avatar Mathieu Faverge
Fix sonarqube adress
parent b3bc9b45
...@@ -35,7 +35,7 @@ SONARQUBE_PROJECTKEY=${SONARQUBE_PROJECTKEY:-hiepacs:hqr:gitlab:master} ...@@ -35,7 +35,7 @@ SONARQUBE_PROJECTKEY=${SONARQUBE_PROJECTKEY:-hiepacs:hqr:gitlab:master}
# create the sonarqube config file # create the sonarqube config file
cat > sonar-project.properties << EOF cat > sonar-project.properties << EOF
sonar.host.url=https://sonarqube.bordeaux.inria.fr/sonarqube sonar.host.url=https://sonarqube.inria.fr/sonarqube
sonar.login=$SONARQUBE_LOGIN sonar.login=$SONARQUBE_LOGIN
sonar.links.homepage=https://gitlab.inria.fr/solverstack/hqr sonar.links.homepage=https://gitlab.inria.fr/solverstack/hqr
