GitLab
Explore
Primary navigation
Search or go to…
H
hqr
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container Registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
hqr
908f904e
908f904e
7 years ago
Mathieu Faverge
Downloads
Patches
Add some comments to libhqr.h and add cmake files
ac112958
Branches containing commit
1 merge request
!7
Cleanup
3
3 changed files
CMakeLists.txt
+56
56 additions, 0 deletions
CMakeLists.txt
include/libhqr.h
+28
-18
28 additions, 18 deletions
include/libhqr.h
testings/CMakeLists.txt
+25
25 additions, 0 deletions
109 additions
18 deletions
CMakeLists.txt
56
908f904e
# @copyright 2017 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
# Univ. Bordeaux. All rights reserved.
# @version 0.1.0
# @author Mathieu Faverge
# @date 2017-04-26
cmake_minimum_required
VERSION 3.0
project
LIBHQR C
# The current version number
set
LIBHQR_VERSION_MAJOR 0
set
LIBHQR_VERSION_MINOR 1
set
LIBHQR_VERSION_MICRO 0
set
LIBHQR_VERSION
### Misc options
option
BUILD_SHARED_LIBS
"Build shared libraries"
OFF
if
NOT CMAKE_BUILD_TYPE
set
CMAKE_BUILD_TYPE RelWithDebInfo CACHE STRING
"Choose the type of build, options are None, Debug, Release, RelWithDebInfo and MinSizeRel."
FORCE
endif
set
hdrs
include/common.h
include/libdraw.h
include/libhqr.h
include/queue.h
set
srcs
src/libhqr.c
src/libhqr_dbg.c
src/libhqr_systolic.c
src/queue.c
src/treedraw.c
src/treewalk.c
include_directories
include
add_library
hqr
srcs
target_link_libraries
hqr m
add_subdirectory
testings
install
FILES
include/libhqr.h
include/libhqr_dbg.h
DESTINATION include
#-- Add a custom target to generate tags
add_custom_target
tags
COMMAND
"git ls-files | xargs etags"
This diff is collapsed.
include/libhqr.h
28
18
908f904e
@@ -36,7 +36,7 @@ static inline int libhqr_iceil(int a, int b){
* @brief Define
to
which tree level the tile belongs to.
* @brief Define which tree level the tile belongs to.
* Four levels of trees are available:
* - The top one (LIBHQR_KILLED_BY_DISTTREE) is meant to be the communication
@@ -49,8 +49,9 @@ static inline int libhqr_iceil(int a, int b){
* the local trees in order to generate a better pipeline for tall and skinny
* matrices.
* @remark LIBHQR_KILLED_BY_TS needs to be stay 0 for all variant of QR
* factorizations in order to distinguish TT kernels from TS kernels in compuations
* @remark LIBHQR_KILLED_BY_TS needs to be 0 for all variant of QR
* compuations
typedef
enum
libhqr_type_
@@ -62,6 +63,10 @@ typedef enum libhqr_type_ {
* @brief Define the type of trees that can be used for the reduction.
* These are the kind of trees available for low-level reduction in shared
* memory, or for high-level reduction in distributed memory. Note that all
* kinds of trees are not available for both levels.
typedef
enum
libhqr_tree_
LIBHQR_FLAT_TREE
@@ -75,18 +80,18 @@ typedef enum libhqr_tree_ {
* @brief Define the type of factorization to apply: QR or LQ.
typedef
enum
libhqr_typefacto_
LIBHQR_QR
LIBHQR_LQ
LIBHQR_QR
/**< QR factorization will be performed, and A shape is considered */
LIBHQR_LQ
/**< LQ factorization will be performed, and A^t shape is considered */
libhqr_typefacto_e
* @brief Minimal structure to define the shape of the matrix to factorize.
typedef
struct
libhqr_tiledesc_s
int
mt
/**< The number of rows of tiles */
int
nt
/**< The number of columns of tiles */
int
nodes
/**< The number of nodes involved in the data distribution */
int
p
/**< The number of nodes per column in the data distribution */
int
mt
int
nt
int
nodes
int
p
libhqr_tiledesc_t
@@ -107,6 +112,9 @@ typedef struct libhqr_tree_s libhqr_tree_t;
typedef
struct
libhqr_context_s
libhqr_context_t
* @brief Hierarchical tree structure for QR/LQ factorization like kernels.
struct
libhqr_tree_s
* @brief Return the number of geqrt/gelqt kernels in the column/row k
@@ -178,15 +186,17 @@ struct libhqr_tree_s {
int
prevpiv
const
libhqr_tree_t
qrtree
int
k
int
p
int
m
/** Descriptor infos associated to the factorization */
int
mt
int
nt
/** Size of the domain where TS kernels are applied */
int
a
/** Size of highest level tree (distributed one) */
int
p
int
domino
void
args
int
mt
/**< Number of rows of tile A if QR factorization, and in A^t if LQ
factorization */
int
nt
/**< Number of tile reflectors to compute. This is equal to
min(A->mt, A->nt) */
int
a
/**< Size of the local flat TS trees */
int
p
/**< Size of the highest level tree (distributed one), recommended
to be the number of process rows in the 2D-cyclic distribution */
int
domino
/**< Enable the domino tree to connect high and low level trees
in T&S matrices */
void
args
/**< Arguments of the qrtree structure (depends on the kind of
tree: hqr, systolic, svd, ...) */
int
libhqr_systolic_init
libhqr_tree_t
qrtree
25
908f904e
# @version 0.1.0
# @date 2017-04-26
set
TESTINGS
testing_pivgen.c
testing_tileinit.c
testing_treedraw.c
foreach
_file
TESTINGS
get_filename_component
_name_we
_file
NAME_WE
add_executable
_name_we
_file
_name_we
hqr
install
TARGETS
_name_we
RUNTIME DESTINATION examples
install
FILES
_file
endforeach
Loading
Save comment
