Commit 7f965afc authored by Raphael Boucherie's avatar Raphael Boucherie Committed by BOUCHERIE Raphael
added test file for drawing tree, anf functions to the library
parent ecbb5725
1 merge request!4Treewalk
......@@ -195,6 +195,16 @@ void libhqr_hqr_finalize( libhqr_tree_t *qrtree );
void libhqr_treewalk(const libhqr_tree_t *qrtree,int k);
* function for treedraw
void libhqr_writeheader();
void libhqr_writecss();
void libhqr_writeend();
void libhqr_drawTT(int x, int y, int k);
void libhqr_drawTS(int x, int y);
void libhqr_drawline(int x1, int y1, int x2, int y2);
* Debugging functions
......@@ -32,7 +32,7 @@
void libhqr_writeheader(){
FILE *tree = fopen("../tree.xml", "w+");
FILE *tree = fopen("tree.svg", "w+");
if(fprintf(tree, "<?xml version=\"1.0\" standalone=\"no\"?>\n") < 0) return;
if(fprintf(tree, "<!DOCTYPE svg PUBLIC \"-//W3C//DTD SVG 1.1//EN\" \n \"http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd\">\n ") < 0) return;
if(fprintf(tree, "<svg width=\"2000\" height=\"2000\" version=\"1.1\" \n xmlns=\"http://www.w3.org/2000/svg\">") <0) return;
......@@ -41,11 +41,21 @@ void libhqr_writeheader(){
void libhqr_drawTT(int x, int y, int k){
FILE *tree = fopen("../tree.xml","w+");
FILE *tree = fopen("tree.svg","a+");
if(fprintf(tree,"<rect x=\"50\" y=\"50\" width=\"50\" height=\"50\" fill=\"red\" />") < 0 ) return;
void libhqr_drawTS(int x, int y){
if(fprintf(tree,"<rect x=\"40\" y=\"40\" width=\"50\" height=\"50\" />") < 0 ) return;
void libhqr_drawline(int x1, int y1, int x2, int y2){
if(fprintf(tree,"<line x1=\"20\" y1=\"80\" x2=\"130\" y2=\"200\" />") < 0 ) return;
void libhqr_writeend(){
FILE *tree = fopen("tree.svg", "a+");
if(fprintf(tree, "<\\svg>") < 0) return;
* @file testting_treedraw.c
* PaStiX symbol structure routines
* @copyright 2017 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
* Univ. Bordeaux. All rights reserved.
* @version 1.0.0
* @author Raphael Boucherie
* @author Matthieu Faverge
* @date 2017-04-04
#include "libhqr.h"
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
int main(int argc, char ** argv)
libhqr_drawTT(50,50,1);
libhqr_drawTS(40,40);
libhqr_drawline(50,50,40,40);
libhqr_writeend();
