Commit 181ed51a authored by PRUVOST Florent's avatar PRUVOST Florent
ci: add -Werror gcc flag
parent bb02b055
1 merge request!27ci: add -Werror gcc flag
...@@ -7,7 +7,7 @@ if [[ "$SYSTEM" == "linux" ]]; then ...@@ -7,7 +7,7 @@ if [[ "$SYSTEM" == "linux" ]]; then
# on linux we perform a coverage analysis # on linux we perform a coverage analysis
cmake -B build -S . -DCMAKE_INSTALL_PREFIX=$PWD/install \ cmake -B build -S . -DCMAKE_INSTALL_PREFIX=$PWD/install \
-DBUILD_SHARED_LIBS=ON -DCMAKE_VERBOSE_MAKEFILE=ON \ -DBUILD_SHARED_LIBS=ON -DCMAKE_VERBOSE_MAKEFILE=ON \
-DCMAKE_C_FLAGS="-O0 -g -fPIC --coverage -Wall -fdiagnostics-show-option -fno-inline" \ -DCMAKE_C_FLAGS="-O0 -g -fPIC --coverage -Werror -Wall -fdiagnostics-show-option -fno-inline" \
-DCMAKE_EXE_LINKER_FLAGS="--coverage" -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_EXE_LINKER_FLAGS="--coverage" -DCMAKE_EXPORT_COMPILE_COMMANDS=ON
else else
