Commit f00c8fa2 authored by Mathieu Faverge's avatar Mathieu Faverge
control/desc: Simplify/Fix computation of descriptor fields
parent 9b9d774b
1 merge request!256Update on descriptors
This commit is part of merge request !256. Comments created here will be created in the context of that merge request.
...@@ -194,38 +194,45 @@ int chameleon_desc_init( CHAM_desc_t *desc, void *mat, ...@@ -194,38 +194,45 @@ int chameleon_desc_init( CHAM_desc_t *desc, void *mat,
memset( desc, 0, sizeof(CHAM_desc_t) ); memset( desc, 0, sizeof(CHAM_desc_t) );
assert( i == 0 );
assert( j == 0 );
assert( bsiz == (mb * nb) );
chamctxt = chameleon_context_self(); chamctxt = chameleon_context_self();
if (chamctxt == NULL) { if (chamctxt == NULL) {
chameleon_error("CHAMELEON_Desc_Create", "CHAMELEON not initialized"); chameleon_error("CHAMELEON_Desc_Create", "CHAMELEON not initialized");
return CHAMELEON_ERR_NOT_INITIALIZED; return CHAMELEON_ERR_NOT_INITIALIZED;
// If one of the function get_* is NULL, we switch back to the default, like in chameleon_desc_init() /* If one of the function get_* is NULL, we switch back to the default */
desc->get_blktile = chameleon_desc_gettile; desc->get_blktile = chameleon_desc_gettile;
desc->get_blkaddr = get_blkaddr ? get_blkaddr : chameleon_getaddr_ccrb; desc->get_blkaddr = get_blkaddr ? get_blkaddr : chameleon_getaddr_ccrb;
desc->get_blkldd = get_blkldd ? get_blkldd : chameleon_getblkldd_ccrb; desc->get_blkldd = get_blkldd ? get_blkldd : chameleon_getblkldd_ccrb;
desc->get_rankof = get_rankof ? get_rankof : chameleon_getrankof_2d; desc->get_rankof = get_rankof ? get_rankof : chameleon_getrankof_2d;
// Matrix properties
/* Matrix properties */
desc->dtyp = dtyp; desc->dtyp = dtyp;
// Should be given as parameter to follow get_blkaddr (unused) /* Should be given as parameter to follow get_blkaddr (unused) */
desc->styp = ChamCCRB; desc->styp = (get_blkaddr == chameleon_getaddr_cm ) ? ChamCM : ChamCCRB;
desc->mb = mb; desc->mb = mb;
desc->nb = nb; desc->nb = nb;
desc->bsiz = bsiz; desc->bsiz = mb * nb;
// Large matrix parameters
desc->lm = lm; /* Matrix parameters */
desc->ln = ln; desc->i = 0;
// Large matrix derived parameters desc->j = 0;
desc->lmt = (lm%mb==0) ? (lm/mb) : (lm/mb+1);
desc->lnt = (ln%nb==0) ? (ln/nb) : (ln/nb+1);
// Submatrix parameters
desc->i = i;
desc->j = j;
desc->m = m; desc->m = m;
desc->n = n; desc->n = n;
// Submatrix derived parameters
desc->mt = (m == 0) ? 0 : (i+m-1)/mb - i/mb + 1; /* Matrix stride parameters */
desc->nt = (n == 0) ? 0 : (j+n-1)/nb - j/nb + 1; desc->lm = m;
desc->ln = n;
/* Matrix derived parameters */
desc->mt = chameleon_ceil( m, mb );
desc->nt = chameleon_ceil( n, nb );
desc->lmt = desc->mt;
desc->lnt = desc->nt;
desc->id = nbdesc; desc->id = nbdesc;
nbdesc++; nbdesc++;
...@@ -233,14 +240,20 @@ int chameleon_desc_init( CHAM_desc_t *desc, void *mat, ...@@ -233,14 +240,20 @@ int chameleon_desc_init( CHAM_desc_t *desc, void *mat,
desc->myrank = RUNTIME_comm_rank( chamctxt ); desc->myrank = RUNTIME_comm_rank( chamctxt );
// Grid size /* Grid size */
desc->p = p; desc->p = p;
desc->q = q; desc->q = q;
// Local dimensions in tiles /* Local dimensions in tiles */
if ( desc->myrank < (p*q) ) { if ( desc->myrank < (p*q) ) {
desc->llmt = (desc->lmt + p - 1) / p; int gmt, gnt;
desc->llnt = (desc->lnt + q - 1) / q;
/* Compute the fictive full number of tiles to derivate the local leading dimension */
gmt = chameleon_ceil( lm, mb );
gnt = chameleon_ceil( ln, nb );
desc->llmt = chameleon_ceil( gmt, p );
desc->llnt = chameleon_ceil( gnt, q );
// Local dimensions // Local dimensions
if ( ((desc->lmt-1) % p) == (desc->myrank / q) ) { if ( ((desc->lmt-1) % p) == (desc->myrank / q) ) {
...@@ -255,8 +268,8 @@ int chameleon_desc_init( CHAM_desc_t *desc, void *mat, ...@@ -255,8 +268,8 @@ int chameleon_desc_init( CHAM_desc_t *desc, void *mat,
desc->lln = desc->llnt * nb; desc->lln = desc->llnt * nb;
desc->llm1 = (desc->llm/mb); desc->llm1 = desc->llm / mb;
desc->lln1 = (desc->lln/nb); desc->lln1 = desc->lln / nb;
} else { } else {
desc->llmt = 0; desc->llmt = 0;
desc->llnt = 0; desc->llnt = 0;
...@@ -326,13 +339,13 @@ CHAM_desc_t* chameleon_desc_submatrix( CHAM_desc_t *descA, int i, int j, int m, ...@@ -326,13 +339,13 @@ CHAM_desc_t* chameleon_desc_submatrix( CHAM_desc_t *descA, int i, int j, int m,
CHAM_desc_t *descB = malloc(sizeof(CHAM_desc_t)); CHAM_desc_t *descB = malloc(sizeof(CHAM_desc_t));
int mb, nb; int mb, nb;
if ( (descA->i + i + m) > descA->lm ) { if ( (descA->i + i + m) > descA->m ) {
chameleon_error("chameleon_desc_submatrix", "The number of rows (i+m) of the submatrix doesn't fit in the parent matrix"); chameleon_error("chameleon_desc_submatrix", "The number of rows (i+m) of the submatrix doesn't fit in the parent matrix");
assert((descA->i + i + m) > descA->lm); assert((descA->i + i + m) > descA->m);
if ( (descA->j + j + n) > descA->ln ) { if ( (descA->j + j + n) > descA->n ) {
chameleon_error("chameleon_desc_submatrix", "The number of rows (j+n) of the submatrix doesn't fit in the parent matrix"); chameleon_error("chameleon_desc_submatrix", "The number of rows (j+n) of the submatrix doesn't fit in the parent matrix");
assert((descA->j + j + n) > descA->ln); assert((descA->j + j + n) > descA->n);
memcpy( descB, descA, sizeof(CHAM_desc_t) ); memcpy( descB, descA, sizeof(CHAM_desc_t) );
