GitLab
Explore
Primary navigation
Search or go to…
S
ScalFMM
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
ScalFMM
152f5db4
152f5db4
11 years ago
Olivier COULAUD
Downloads
Patches
Add scripts to check peridic systems
015740c3
2
2 changed files
Utils/scripts/fmmper.sh
+37
37 additions, 0 deletions
Utils/scripts/plotper.gnu
+11
11 additions, 0 deletions
48 additions
0 → 100755
37
152f5db4
#!/bin/bash
#PBS -N MG_water
# preciser le temps en heures, minutes, secondes
#PBS -l walltime=01:59:00
# nombre de noeuds et de coeurs
#PBS -l nodes=1:ppn=12
#PBS -l naccesspolicy=singlejob
# PlaFRIM environment
w
source
$HOME
/.bashrc
FMMPER_EXE
"Tests/Release/testSphericalEwalAlgorithm"
FILE
"../Data/forceNacl_2000_dlpolyPer.txt"
FILE
"../Data/forceNacl_128_dlpolyPer.txt"
cd
~/Dev/src/ScalFMM/scalfmmT/BuildGCC
# RUN 1 influence de la taille de la boite sur la precision des calculs
# Regarde size, Nx ny nz energie total, dipole et le temps de calcul
PER_SIZE
"-1 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18"
rm
-f
FMM_PER.out
echo
"# PerSize DOMAIN_SIZE ENERGY"
FMM_PER.out
pwd
for
l
in
$PER_SIZE
do
echo
"Running per = "
l
echo
$FMMPER_EXE
-f
$FILE
-h 4 -sh 2 -per
$l
$FILE
.out "
$FMMPER_EXE
-f
$FILE
-h
4
-sh
2
-per
$l
$FILE
.out
DOMAINSIZE
grep
"Simulated box:"
$FILE
.out |
awk
'{print $3}'
ENERGY
grep
"Energy FMM="
$FILE
.out |awk
'{ print $3 }'
echo
$l
$DOMAINSIZE
$ENERGY
FMM_PER.out
done
This diff is collapsed.
11
152f5db4
#set terminal postscript enhanced color
#set output FMMEnergy.ps'
set key left
szt encoding iso_8859_1
set title "FMM Energy"
set xlabel "per size (per)"
set ylabel "Energy (kcal/mol)"
plot "FMM_PER.out" u ($1,$3) w l t "FMM Energy"
Loading
Save comment
