Commit 445019f1 authored by SAUCEZ Damien's avatar SAUCEZ Damien
e2 interface
parent 1af04aeb
......@@ -71,6 +71,7 @@ config:
tac: "{{ core.tac}}" # check the information with AMF
sst: "{{ core.sst }}" #currently only 4 standard values are allowed 1,2,3,4
amfhost: "{{ network.ips.amf.n2.ip }}" # amf ip-address or service-name oai-amf-svc or 172.21.6.94
flexrichost: "oai-flexric.{{ core.core.namespace }}"
n2IfName: "n2" # if multus.n2Interface.create is true then use n2
n3IfName: "n3" #if multus.n3Interface.create is true then use n3 or you can only use 1 interface n2 or eth0
f1IfName: "f1" #if multus.f1Interface.create is true then use f1
......@@ -70,6 +70,7 @@ config:
cuCpHost: "{{ network.ips.cucp.e1.ip }}" #
f1IfName: "f1" #if multus.f1uInterface.create is true then use f1
