Commit c9d84863 authored by JIA Shuman's avatar JIA Shuman
Add source code.
parent cd5c8668
#include "itkMesh.h"
#include "itkMeshFileReader.h"
#include "itkImage.h"
#include "itkImageFileReader.h"
#include "itkImageFileWriter.h"
#include "itkCastImageFilter.h"
#include "itkTriangleMeshToBinaryImageFilter.h"
int main( int argc, char* argv[] )
if( argc != 4 )
std::cerr << "Usage: "<< std::endl;
std::cerr << argv[0];
std::cerr << " <InputImageName> <InputMeshName> <OutputImageName>";
std::cerr << std::endl;
return EXIT_FAILURE;
const char * inputImageName = argv[1];
const char * inputMeshName = argv[2];
const char * outputImageName = argv[3];
const unsigned int Dimension = 3;
typedef double MeshPixelType;
typedef itk::Mesh< MeshPixelType, Dimension > MeshType;
typedef itk::MeshFileReader< MeshType > MeshReaderType;
MeshReaderType::Pointer meshReader = MeshReaderType::New();
meshReader->SetFileName( inputMeshName );
typedef unsigned char InputPixelType;
typedef itk::Image< InputPixelType, Dimension > InputImageType;
typedef itk::ImageFileReader< InputImageType > ImageReaderType;
ImageReaderType::Pointer imageReader = ImageReaderType::New();
imageReader->SetFileName( inputImageName );
typedef unsigned char OutputPixelType;
typedef itk::Image< OutputPixelType, Dimension > OutputImageType;
typedef itk::CastImageFilter< InputImageType, OutputImageType > CastFilterType;
CastFilterType::Pointer cast = CastFilterType::New();
cast->SetInput( imageReader->GetOutput() );
typedef itk::TriangleMeshToBinaryImageFilter< MeshType, OutputImageType > FilterType;
FilterType::Pointer filter = FilterType::New();
filter->SetInput( meshReader->GetOutput() );
filter->SetInfoImage( cast->GetOutput() );
filter->SetInsideValue( itk::NumericTraits< OutputPixelType >::max() );
try
filter->Update();
catch( itk::ExceptionObject & error )
std::cerr << "Error: " << error << std::endl;
typedef itk::ImageFileWriter< OutputImageType > WriterType;
WriterType::Pointer writer = WriterType::New();
writer->SetFileName( outputImageName );
writer->SetInput( filter->GetOutput() );
try
writer->Update();
return EXIT_SUCCESS;
