Unverified Commit cb33d4db authored by Christian Heinrich's avatar Christian Heinrich Committed by Christian Heinrich
Updated Labbook
parent fe0c771a
......@@ -523,7 +523,6 @@ make
values, to better test limits of the network.
** Taurus machine in Lyon :CHRISTIAN:
*** Reservation
The taurus machine shares a single switch with both orion and hercule
......@@ -531,7 +530,7 @@ clusters. We’ve observed that experiments are not reliable if these
two clusters are not reserved as well, since the switch does not
isolate all clusters from each other.
Hence, the code that I used to reserve the clusters:
The command that I used to reserve the clusters:
#+begin_src sh :results output :exports both
oarsub -t deploy -l "{cluster in ('taurus', 'orion', 'hercule')}/nodes=ALL,walltime=00:55" -r "$(date '+%Y-%m-%d %H:%M:%S')"
