Commit a07a686b authored by STEFF Laurent's avatar STEFF Laurent
fixed various typos
parent e8ead53a
%% Cell type:markdown id: tags: %% Cell type:markdown id: tags:
# [Getting started in C++](./) - [Procedural programming](./0-main.ipynb) - [Functions](./4-Functions.ipynb) # [Getting started in C++](./) - [Procedural programming](./0-main.ipynb) - [Functions](./4-Functions.ipynb)
<h1>Table of contents<span class="tocSkip"></span></h1> <h1>Table of contents<span class="tocSkip"></span></h1>
<div class="toc"><ul class="toc-item"><li><span><a href="#Function-definition" data-toc-modified-id="Function-definition-1">Function definition</a></span><ul class="toc-item"><li><span><a href="#Passing-arguments-by-value" data-toc-modified-id="Passing-arguments-by-value-1.1">Passing arguments by value</a></span></li><li><span><a href="#Passing-arguments-by-reference" data-toc-modified-id="Passing-arguments-by-reference-1.2">Passing arguments by reference</a></span></li><li><span><a href="#A-bit-of-wandering:-using-C-like-error-codes" data-toc-modified-id="A-bit-of-wandering:-using-C-like-error-codes-1.3">A bit of wandering: using C-like error codes</a></span></li><li><span><a href="#Passing-arguments-by-pointers" data-toc-modified-id="Passing-arguments-by-pointers-1.4">Passing arguments by pointers</a></span></li></ul></li><li><span><a href="#Function-with-return-value" data-toc-modified-id="Function-with-return-value-2">Function with return value</a></span></li><li><span><a href="#Alternate-function-syntax" data-toc-modified-id="Alternate-function-syntax-3">Alternate function syntax</a></span></li><li><span><a href="#Function-overload" data-toc-modified-id="Function-overload-4">Function overload</a></span><ul class="toc-item"><li><span><a href="#The-easy-cases:-arguments-without-ambiguity" data-toc-modified-id="The-easy-cases:-arguments-without-ambiguity-4.1">The easy cases: arguments without ambiguity</a></span></li><li><span><a href="#[WARNING]-Return-type-doesn't-count!" data-toc-modified-id="[WARNING]-Return-type-doesn't-count!-4.2">[WARNING] Return type doesn't count!</a></span></li><li><span><a href="#Good-practice:-don't-make-signature-vary-only-by-a-reference-or-a-pointer" data-toc-modified-id="Good-practice:-don't-make-signature-vary-only-by-a-reference-or-a-pointer-4.3">Good practice: don't make signature vary only by a reference or a pointer</a></span></li><li><span><a href="#Best-viable-function" data-toc-modified-id="Best-viable-function-4.4">Best viable function</a></span></li><li><span><a href="#Advice:-use-overload-only-when-there-is-no-ambiguity-whatsoever" data-toc-modified-id="Advice:-use-overload-only-when-there-is-no-ambiguity-whatsoever-4.5">Advice: use overload only when there is no ambiguity whatsoever</a></span></li></ul></li><li><span><a href="#Optional-parameters" data-toc-modified-id="Optional-parameters-5">Optional parameters</a></span></li><li><span><a href="#Lambda-functions" data-toc-modified-id="Lambda-functions-6">Lambda functions</a></span></li><li><span><a href="#Passing-a-function-as-a-an-argument" data-toc-modified-id="Passing-a-function-as-a-an-argument-7">Passing a function as a an argument</a></span></li><li><span><a href="#A-very-special-function:-main" data-toc-modified-id="A-very-special-function:-main-8">A very special function: <strong>main</strong></a></span></li><li><span><a href="#inline-functions" data-toc-modified-id="inline-functions-9"><code>inline</code> functions</a></span></li></ul></div> <div class="toc"><ul class="toc-item"><li><span><a href="#Function-definition" data-toc-modified-id="Function-definition-1">Function definition</a></span><ul class="toc-item"><li><span><a href="#Passing-arguments-by-value" data-toc-modified-id="Passing-arguments-by-value-1.1">Passing arguments by value</a></span></li><li><span><a href="#Passing-arguments-by-reference" data-toc-modified-id="Passing-arguments-by-reference-1.2">Passing arguments by reference</a></span></li><li><span><a href="#A-bit-of-wandering:-using-C-like-error-codes" data-toc-modified-id="A-bit-of-wandering:-using-C-like-error-codes-1.3">A bit of wandering: using C-like error codes</a></span></li><li><span><a href="#Passing-arguments-by-pointers" data-toc-modified-id="Passing-arguments-by-pointers-1.4">Passing arguments by pointers</a></span></li></ul></li><li><span><a href="#Function-with-return-value" data-toc-modified-id="Function-with-return-value-2">Function with return value</a></span></li><li><span><a href="#Alternate-function-syntax" data-toc-modified-id="Alternate-function-syntax-3">Alternate function syntax</a></span></li><li><span><a href="#Function-overload" data-toc-modified-id="Function-overload-4">Function overload</a></span><ul class="toc-item"><li><span><a href="#The-easy-cases:-arguments-without-ambiguity" data-toc-modified-id="The-easy-cases:-arguments-without-ambiguity-4.1">The easy cases: arguments without ambiguity</a></span></li><li><span><a href="#[WARNING]-Return-type-doesn't-count!" data-toc-modified-id="[WARNING]-Return-type-doesn't-count!-4.2">[WARNING] Return type doesn't count!</a></span></li><li><span><a href="#Good-practice:-don't-make-signature-vary-only-by-a-reference-or-a-pointer" data-toc-modified-id="Good-practice:-don't-make-signature-vary-only-by-a-reference-or-a-pointer-4.3">Good practice: don't make signature vary only by a reference or a pointer</a></span></li><li><span><a href="#Best-viable-function" data-toc-modified-id="Best-viable-function-4.4">Best viable function</a></span></li><li><span><a href="#Advice:-use-overload-only-when-there-is-no-ambiguity-whatsoever" data-toc-modified-id="Advice:-use-overload-only-when-there-is-no-ambiguity-whatsoever-4.5">Advice: use overload only when there is no ambiguity whatsoever</a></span></li></ul></li><li><span><a href="#Optional-parameters" data-toc-modified-id="Optional-parameters-5">Optional parameters</a></span></li><li><span><a href="#Lambda-functions" data-toc-modified-id="Lambda-functions-6">Lambda functions</a></span></li><li><span><a href="#Passing-a-function-as-a-an-argument" data-toc-modified-id="Passing-a-function-as-a-an-argument-7">Passing a function as a an argument</a></span></li><li><span><a href="#A-very-special-function:-main" data-toc-modified-id="A-very-special-function:-main-8">A very special function: <strong>main</strong></a></span></li><li><span><a href="#inline-functions" data-toc-modified-id="inline-functions-9"><code>inline</code> functions</a></span></li></ul></div>
## Function definition ## Function definition
To be usable in a C++ instruction, a function must be __defined__ beforehand. This definition includes the name and type of the arguments, the type of the return value and the instruction block that make up the function. To be usable in a C++ instruction, a function must be __defined__ beforehand. This definition includes the name and type of the arguments, the type of the return value and the instruction block that make up the function.
`void` is a special type to indicate a function doesn't return any value. `void` is a special type to indicate a function doesn't return any value.
__BEWARE__: Functions can't be defined in blocks. __BEWARE__: Functions can't be defined in blocks.
%% Cell type:code id: tags: %% Cell type:code id: tags:
``` C++17 ``` C++17
#include <iostream> #include <iostream>
void PrintDivision(int arg1, int arg2) void PrintDivision(int arg1, int arg2)
if (arg2 == 0) if (arg2 == 0)
std::cerr << "Failure: division by zero!" << std::endl; std::cerr << "Failure: division by zero!" << std::endl;
else else
int division ; int division ;
division = arg1/arg2 ; division = arg1/arg2 ;
std::cout << arg1 << " / " << arg2 << " = " << division << std::endl ; std::cout << arg1 << " / " << arg2 << " = " << division << std::endl ;
``` C++17 ``` C++17
PrintDivision(12, 3); PrintDivision(12, 3);
PrintDivision(6, 0); PrintDivision(6, 0);
PrintDivision(15, 6); PrintDivision(15, 6);
Functions can't be nested in C++, contrary to some other langages such as Python: Functions can't be nested in C++, contrary to some other langages such as Python:
``` C++17 ``` C++17
void function_1() // a function might have no arguments void function_1() // a function might have no arguments
void subfunction() // COMPILATION ERROR! void subfunction() // COMPILATION ERROR!
To reintroduce hierarchy, __namespaces__ can be used (they will be introduced [a bit later](../6-InRealEnvironment/5-Namespace.ipynb)); __lambda functions__ introduced later in this notebook are not limited by the same rule. To reintroduce hierarchy, __namespaces__ can be used (they will be introduced [a bit later](../6-InRealEnvironment/5-Namespace.ipynb)); __lambda functions__ introduced later in this notebook are not limited by the same rule.
### Passing arguments by value ### Passing arguments by value
In the simple example above, we passed the arguments by value, which is to say the values passed by the arguments were copied when given to the function: In the simple example above, we passed the arguments by value, which is to say the values passed by the arguments were copied when given to the function:
``` C++17 ``` C++17
void increment_and_print(int i) void increment_and_print(int i)
++i; ++i;
std::cout << "Inside the function: i = " << i << std::endl; std::cout << "Inside the function: i = " << i << std::endl;
int i = 5; // I could have named it differently - it doesn't matter as the scope is different! int i = 5; // I could have named it differently - it doesn't matter as the scope is different!
increment_and_print(i); increment_and_print(i);
std::cout << "Outside the function: i = " << i << std::endl; std::cout << "Outside the function: i = " << i << std::endl;
The `i` in the block body and in the function definition is not the same: one or the other could have been named differently and the result would have been the same. The `i` in the block body and in the function definition is not the same: one or the other could have been named differently and the result would have been the same.
### Passing arguments by reference ### Passing arguments by reference
If we intended to modify the value of `i` outside the function, we should have passed it by reference: If we intended to modify the value of `i` outside the function, we should have passed it by reference:
``` C++17 ``` C++17
void increment_and_print_by_reference(int& i) void increment_and_print_by_reference(int& i)
++i; ++i;
increment_and_print_by_reference(i); increment_and_print_by_reference(i);
As in C++ you can't return several values in the return type, passing by reference is a way to get in output several values (C++ 11 introduced in the standard library a workaround to get several values in return type with a so-called `std::tuple`, but the passing by reference remains the better way to do so in most cases). As in C++ you can't return several values in the return type, passing by reference is a way to get in output several values (C++ 11 introduced in the standard library a workaround to get several values in return type with a so-called `std::tuple`, but the passing by reference remains the better way to do so in most cases).
``` C++17 ``` C++17
int compute_division(int arg1, int arg2, int& quotient, int& remainder) int compute_division(int arg1, int arg2, int& quotient, int& remainder)
return -1; // error code. return -1; // error code.
quotient = arg1 / arg2; quotient = arg1 / arg2;
remainder = arg1 % arg2; remainder = arg1 % arg2;
return 0; // code when everything is alright. return 0; // code when everything is alright.
``` C++17 ``` C++17
int quotient, remainder; int quotient, remainder;
if (compute_division(5, 3, quotient, remainder) == 0) if (compute_division(5, 3, quotient, remainder) == 0)
std::cout << "5 / 3 = " << quotient << " with a remainder of " << remainder << '.' << std::endl; std::cout << "5 / 3 = " << quotient << " with a remainder of " << remainder << '.' << std::endl;
if (compute_division(5, 0, quotient, remainder) == 0) if (compute_division(5, 0, quotient, remainder) == 0)
std::cout << "5 / 0 = " << quotient << " with a remainder of " << remainder << '.' << std::endl; std::cout << "5 / 0 = " << quotient << " with a remainder of " << remainder << '.' << std::endl;
else else
std::cerr << "Can't divide by 0!" << std::endl; std::cerr << "Can't divide by 0!" << std::endl;
### A bit of wandering: using C-like error codes ### A bit of wandering: using C-like error codes
The function above gets two outputs: the quotient and the remainder of the euclidian division. Moreover, this function returns an error code: by convention this function returns 0 when everything is alright and -1 in case of a zero divider. The function above gets two outputs: the quotient and the remainder of the euclidian division. Moreover, this function returns an error code: by convention this function returns 0 when everything is alright and -1 in case of a zero divider.
Using such an error code is a very common pattern in C, that might as well be used in C++... The issue is that it requires a lot of discipline from the user of the function: there are no actual incentive to use the return value! Just calling `compute_division()` as if it was a void function is perfectly fine (and yet completely ill-advised). We will see [later](../5-UsefulConceptsAndSTL/1-ErrorHandling.ipynb) the `exception` mechanism C++ recommends instead of error codes. Using such an error code is a very common pattern in C, that might as well be used in C++... The issue is that it requires a lot of discipline from the user of the function: there are no actual incentive to use the return value! Just calling `compute_division()` as if it was a void function is perfectly fine (and yet completely ill-advised). We will see [later](../5-UsefulConceptsAndSTL/1-ErrorHandling.ipynb) the `exception` mechanism C++ recommends instead of error codes.
Below is an example where things go awry due to the lack of check: Below is an example where things go awry due to the lack of check:
``` C++17 ``` C++17
void print_division(int arg1, int arg2) void print_division(int arg1, int arg2)
compute_division(arg1, arg2, quotient, remainder); // the dev 'forgot' to check the error code. compute_division(arg1, arg2, quotient, remainder); // the dev 'forgot' to check the error code.
std::cout << "Euclidian division of " << arg1 << " by " << arg2 << " yields a quotient of " std::cout << "Euclidian division of " << arg1 << " by " << arg2 << " yields a quotient of "
<< quotient << " and a remainder of " << remainder << std::endl; << quotient << " and a remainder of " << remainder << std::endl;
print_division(8, 5); print_division(8, 5);
print_division(8, 0); // bug! print_division(8, 0); // bug!
The developer made two important mistakes: The developer made two important mistakes:
* The return value of `compute_division` is not checked, so something is printed on screen. * The return value of `compute_division` is not checked, so something is printed on screen.
* This is something completely out of control: quotient and remainder don't get a default value that would help to see if something is askew. The behaviour is undefined: you have no guarantee on the values the program will print (currently I see the same values as in the previous function call, but another compiler/architecture/etc... might yield another wrong value. * This is something completely out of control: quotient and remainder don't get a default value that would help to see if something is askew. The behaviour is undefined: you have no guarantee on the values the program will print (currently I see the same values as in the previous function call, but another compiler/architecture/etc... might yield another wrong value.
**UPDATE:** I still do not advise to use error codes, but the [nodiscard](https://en.cppreference.com/w/cpp/language/attributes/nodiscard) attribute introduced in C++ 17 helps your compiler to warn you when the return value was left unused. **UPDATE:** I still do not advise to use error codes, but the [nodiscard](https://en.cppreference.com/w/cpp/language/attributes/nodiscard) attribute introduced in C++ 17 helps your compiler to warn you when the return value was left unused.
### Passing arguments by pointers ### Passing arguments by pointers
When the argument of a function is a pointer, each function call When the argument of a function is a pointer, each function call
results in the creation of a temporary pointer which is given the address provided as argument. Then using the `*` operator, you can access the results in the creation of a temporary pointer which is given the address provided as argument. Then using the `*` operator, you can access the
original variable, not a copy. original variable, not a copy.
Except in the case of interaction with a C library or some _very_ specific cases, I wouldn't advise using passing arguments by pointers: by reference does the job as neatly and in fact more efficiently (dereferencing a pointer with `*i` is not completely costless). Except in the case of interaction with a C library or some _very_ specific cases, I wouldn't advise using passing arguments by pointers: by reference does the job as neatly and in fact more efficiently (dereferencing a pointer with `*i` is not completely costless).
``` C++17 ``` C++17
void increment_and_print_by_pointer(int* i) void increment_and_print_by_pointer(int* i)
*i += 1; *i += 1;
std::cout << "Inside the function: i = " << *i << std::endl; std::cout << "Inside the function: i = " << *i << std::endl;
increment_and_print_by_pointer(&i); increment_and_print_by_pointer(&i);
## Function with return value ## Function with return value
The value to return should come after the keyword `return`. The value to return should come after the keyword `return`.
A C++ function may include several return values in its implementation: A C++ function may include several return values in its implementation:
``` C++17 ``` C++17
//! \brief Returns 1 if the value is positive, 0 if it is 0 and -1 if it's negative. //! \brief Returns 1 if the value is positive, 0 if it is 0 and -1 if it's negative.
int sign(int a) int sign(int a)
if (a > 0) if (a > 0)
return 1; return 1;
if (a == 0) if (a == 0)
return 0; return 0;
return -1; return -1;
for (int a = -3; a < 4; ++a) for (int a = -3; a < 4; ++a)
std::cout << "Sign of " << a << " = " << sign(a) << std::endl; std::cout << "Sign of " << a << " = " << sign(a) << std::endl;
## Alternate function syntax ## Alternate function syntax
There is now since C++ 11 another way to declare a function; it is not widespread but is advised by some developers (see for instance [this blog post](https://blog.petrzemek.net/2017/01/17/pros-and-cons-of-alternative-function-syntax-in-cpp/) which lists pros and cons of both syntaxes). There is now since C++ 11 another way to declare a function; it is not widespread but is advised by some developers (see for instance [this blog post](https://blog.petrzemek.net/2017/01/17/pros-and-cons-of-alternative-function-syntax-in-cpp/) which lists pros and cons of both syntaxes).
``` C++17 ``` C++17
auto sum(int a, int b) -> int // Currently doesn't compile in Xeus-cling environment auto sum(int a, int b) -> int // Currently doesn't compile in Xeus-cling environment
return a + b; return a + b;
The return value is optional (and was the reason of Xeus-cling failure): The return value is optional (and was the reason of Xeus-cling failure):
``` C++17 ``` C++17
auto sum(int a, int b) // compiles just fine in Xeus-cling auto sum(int a, int b) // compiles just fine in Xeus-cling
``` C++17 ``` C++17
int a = 8; int a = 8;
int b = -3; int b = -3;
std::cout << a << " + " << b << " = " << sum(a, b) << std::endl; std::cout << a << " + " << b << " = " << sum(a, b) << std::endl;
## Function overload ## Function overload
### The easy cases: arguments without ambiguity ### The easy cases: arguments without ambiguity
It is possible to define several different functions with the exact same name, provided the type of the argument differ: It is possible to define several different functions with the exact same name, provided the type of the argument differ:
``` C++17 ``` C++17
#include <string> #include <string>
void f(); void f();
void f(int); // Ok void f(int); // Ok
double f(int, double); // Ok double f(int, double); // Ok
auto f(char) -> int; // Ok (alternate function syntax) auto f(char) -> int; // Ok (alternate function syntax)
std::string f(double, int, char*); // Ok std::string f(double, int, char*); // Ok
### [WARNING] Return type doesn't count! ### [WARNING] Return type doesn't count!
It's not the entire signature of the function that is taken into account when possible ambiguity is sought by the compiler: the return type isn't taken into account. So the following cases won't be accepted: It's not the entire signature of the function that is taken into account when possible ambiguity is sought by the compiler: the return type isn't taken into account. So the following cases won't be accepted:
``` C++17 ``` C++17
void g(int); void g(int);
int g(int); // COMPILATION ERROR int g(int); // COMPILATION ERROR
If we think about it, it is rather logical: in C++ we are not required to use the return type of a function (it's not the case in all languages: Go follows a different path on that topic for instance). The issue then is that the compiler has no way to know which `g(int)` is supposed to be called with `g(5)` for instance. If we think about it, it is rather logical: in C++ we are not required to use the return type of a function (it's not the case in all languages: Go follows a different path on that topic for instance). The issue then is that the compiler has no way to know which `g(int)` is supposed to be called with `g(5)` for instance.
### Good practice: don't make signature vary only by a reference or a pointer ### Good practice: don't make signature vary only by a reference or a pointer
On the other hand, compiler is completely able to accept signatures that differs only by a reference or a pointer on one of the argument: On the other hand, compiler is completely able to accept signatures that differs only by a reference or a pointer on one of the argument:
``` C++17 ``` C++17
void h(double a) void h(double a)
std::cout << "h(double) is called with a = " << a << '.' << std::endl; std::cout << "h(double) is called with a = " << a << '.' << std::endl;
``` C++17 ``` C++17
void h(double* a) // Ok void h(double* a) // Ok
std::cout << "h(double*) is called with a = " << *a << "; a is doubled by the function." << std::endl; std::cout << "h(double*) is called with a = " << *a << "; a is doubled by the function." << std::endl;
*a *= 2.; *a *= 2.;
``` C++17 ``` C++17
void h(double& a) // Ok... but not advised! (see below) void h(double& a) // Ok... but not advised! (see below)
std::cout << "h(double*) is called with a = " << a << "; a is doubled by the function." << std::endl; std::cout << "h(double&) is called with a = " << a << "; a is doubled by the function." << std::endl;
a *= 2.; a *= 2.;
``` C++17 ``` C++17
h(5); // Ok h(5); // Ok
double x = 1.; double x = 1.;
h(&x); // Ok h(&x); // Ok
However, there is a possible ambiguity between the pass-by-copy and pass-by-reference: However, there is a possible ambiguity between the pass-by-copy and pass-by-reference:
``` C++17 ``` C++17
h(x); // COMPILATION ERROR: should it call h(double) or h(double& )? h(x); // COMPILATION ERROR: should it call h(double) or h(double& )?
You can lift the ambiguity for the pass-by-value: You can lift the ambiguity for the pass-by-value:
``` C++17 ``` C++17
h(static_cast<double>(x)); // Ok h(static_cast<double>(x)); // Ok
But not to my knowledge for the pass-by-reference... So you should really avoid doing so: if you really need both functions, name them differently to avoid the ambiguity. But not to my knowledge for the pass-by-reference... So you should really avoid doing so: if you really need both functions, name them differently to avoid the ambiguity.
I would even avoid the pointer case: granted, there is no ambiguity for a computer standpoint, but if you get a developer who is not 100% clear about the pointer syntax he might end-up calling the wrong function: I would even avoid the pointer case: granted, there is no ambiguity for a computer standpoint, but if you get a developer who is not 100% clear about the pointer syntax he might end-up calling the wrong function:
``` C++17 ``` C++17
void h2(double a) void h2(double a)
std::cout << "h2(double) is called with a = " << a << '.' << std::endl; std::cout << "h2(double) is called with a = " << a << '.' << std::endl;
``` C++17 ``` C++17
void h2(double* a) void h2(double* a)
std::cout << "h2(double*) is called with a = " << *a << "; a is doubled by the function." << std::endl; std::cout << "h2(double*) is called with a = " << *a << "; a is doubled by the function." << std::endl;
*a *= 2.; *a *= 2.;
``` C++17 ``` C++17
double x = 5.; double x = 5.;
double* ptr = &x; double* ptr = &x;
h2(x); // call h2(double) h2(x); // call h2(double)
h2(ptr); // call h2(double*) h2(ptr); // call h2(double*)
h2(*ptr); // call h2(double) h2(*ptr); // call h2(double)
h2(&x); // call h2(double*) h2(&x); // call h2(double*)
### Best viable function ### Best viable function
In fact, overloading may work even if the match is not perfect: the **best viable function** is chosen if possible... and some ambiguity may appear if none matches! In fact, overloading may work even if the match is not perfect: the **best viable function** is chosen if possible... and some ambiguity may appear if none matches!
The complete rules are very extensive and may be found [here](https://en.cppreference.com/w/cpp/language/overload_resolution); as a rule of thumb you should really strive to write overloaded functions with no easy ambiguity... or not using it at all: sometimes naming the function differently avoids loads of issues! The complete rules are very extensive and may be found [here](https://en.cppreference.com/w/cpp/language/overload_resolution); as a rule of thumb you should really strive to write overloaded functions with no easy ambiguity... or not using it at all: sometimes naming the function differently avoids loads of issues!
``` C++17 ``` C++17
int min(int a, int b) int min(int a, int b)
std::cout << "int version called!" << std::endl; std::cout << "int version called!" << std::endl;
return a < b ? a : b; return a < b ? a : b;
``` C++17 ``` C++17
double min(double a, double b) double min(double a, double b)
std::cout << "double version called!" << std::endl; std::cout << "double version called!" << std::endl;
``` C++17 ``` C++17
int i1 { 5 }, i2 { -7 }; int i1 { 5 }, i2 { -7 };
double d1 { 3.14}, d2 { -1.e24}; double d1 { 3.14}, d2 { -1.e24};
float f1 { 3.14f }, f2 { -4.2f}; float f1 { 3.14f }, f2 { -4.2f};
short s1 { 5 }, s2 { 7 }; short s1 { 5 }, s2 { 7 };
min(5, 7); // no ambiguity min(5, 7); // no ambiguity
min(i1, i2); // no ambiguity min(i1, i2); // no ambiguity
min(f1, f2); // conversion to closest one min(f1, f2); // conversion to closest one
min(f1, d2); // conversion to closest one min(f1, d2); // conversion to closest one
min(s1, s2); // conversion to closest one min(s1, s2); // conversion to closest one
However, with some other types it doesn't work as well if implicit conversion is dangerous and may loose data: However, with some other types it doesn't work as well if implicit conversion is dangerous and may loose data:
``` C++17 ``` C++17
unsigned int i1 { 5 }, i2 { 7 }; unsigned int i1 { 5 }, i2 { 7 };
min(i1, i2); // COMPILATION ERROR: no 'obvious' best candidate! min(i1, i2); // COMPILATION ERROR: no 'obvious' best candidate!
``` C++17 ``` C++17
long i1 { 5 }, i2 { 7 }; long i1 { 5 }, i2 { 7 };
Likewise, if best candidate is not the same for each argument: Likewise, if best candidate is not the same for each argument:
``` C++17 ``` C++17
float f1 { 5.f }; float f1 { 5.f };
int i1 { 5 }; int i1 { 5 };
min(f1, i1); // for i1 the 'int'version is better, but for f1 the 'double' is more appropriate... min(f1, i1); // for i1 the 'int'version is better, but for f1 the 'double' is more appropriate...
### Advice: use overload only when there is no ambiguity whatsoever ### Advice: use overload only when there is no ambiguity whatsoever
That is when: That is when:
- The number of arguments is different between overloads. - The number of arguments is different between overloads.
- Or their types do not convert implicitly from one to another. For instance the following overloads are completely safe to use and the interface remains obvious for the end-user: - Or their types do not convert implicitly from one to another. For instance the following overloads are completely safe to use and the interface remains obvious for the end-user:
``` C++17 ``` C++17
std::string GenerateString() std::string GenerateString()
std::cout << "No argument!"; std::cout << "No argument!";
return ""; return "";
``` C++17 ``` C++17
std::string GenerateString(char one_character) std::string GenerateString(char one_character)
std::cout << "One character: "; std::cout << "One character: ";
return std::string(1, one_character); return std::string(1, one_character);
``` C++17 ``` C++17
std::string GenerateString(char value1, char value2) std::string GenerateString(char value1, char value2)
std::cout << "Two characters: "; std::cout << "Two characters: ";
std::string ret(1, value1); std::string ret(1, value1);
ret += value2; ret += value2;
return ret; return ret;
``` C++17 ``` C++17
std::string GenerateString(const std::string& string) std::string GenerateString(const std::string& string)
std::cout << "Std::string: "; std::cout << "Std::string: ";
return string; return string;
``` C++17 ``` C++17
std::string GenerateString(const char* string) std::string GenerateString(const char* string)
std::cout << "Char*: "; std::cout << "Char*: ";
return std::string(string); return std::string(string);
``` C++17 ``` C++17
std::cout << GenerateString() << std::endl; std::cout << GenerateString() << std::endl;
std::cout << GenerateString('a') << std::endl; std::cout << GenerateString('a') << std::endl;
std::cout << GenerateString('a', 'b') << std::endl; std::cout << GenerateString('a', 'b') << std::endl;
std::cout << GenerateString("Hello world!") << std::endl; std::cout << GenerateString("Hello world!") << std::endl;
std::string text("Hello!"); std::string text("Hello!");
std::cout << GenerateString(text) << std::endl; std::cout << GenerateString(text) << std::endl;
## Optional parameters ## Optional parameters
It is possible to provide optional parameters in the **declaration** of a function: It is possible to provide optional parameters in the **declaration** of a function:
``` C++17 ``` C++17
// Declaration. // Declaration.
void FunctionWithOptional(double x, double y = 0., double z = 0.); void FunctionWithOptional(double x, double y = 0., double z = 0.);
``` C++17 ``` C++17
// Definition // Definition
void FunctionWithOptional(double x, double y, double z) // notice the absence of default value! void FunctionWithOptional(double x, double y, double z) // notice the absence of default value!
std::cout << '(' << x << ", " << y << ", " << z << ')' << std::endl; std::cout << '(' << x << ", " << y << ", " << z << ')' << std::endl;
``` C++17 ``` C++17
// WARNING: Xeus-cling issue! // WARNING: Xeus-cling issue!
FunctionWithOptional(3., 5., 6.); // ok FunctionWithOptional(3., 5., 6.); // ok
FunctionWithOptional(3.); // should be ok, but Xeus-cling issue. FunctionWithOptional(3.); // should be ok, but Xeus-cling issue.
The reason not to repeat them is rather obvious: if both were accepted you may modify one of them and forget to modify the others, which would be a bad design... The reason not to repeat them is rather obvious: if both were accepted you may modify one of them and forget to modify the others, which would be a bad design...
There is a way to put it in the same place, that I do not recommend it (and your compiler should warn you most of the time): if you do not declare the function beforehand, default arguments may be specified at definition: There is a way to put it in the same place, that I do not recommend it (and your compiler should warn you most of the time): if you do not declare the function beforehand, default arguments may be specified at definition:
``` C++17 ``` C++17
// Definition which double acts as declaration // Definition which double acts as declaration
void FunctionWithOptional2(double x, double y = 0., double z = 0.) void FunctionWithOptional2(double x, double y = 0., double z = 0.)
``` C++17 ``` C++17
FunctionWithOptional2(3., 5., 6.); // ok FunctionWithOptional2(3., 5., 6.); // ok
FunctionWithOptional2(3.); // ok FunctionWithOptional2(3.); // ok
In C and C++, arguments are only **positional**: you do not have a way to explicitly set an argument with a name for instance. In C and C++, arguments are only **positional**: you do not have a way to explicitly set an argument with a name for instance.
Therefore: Therefore:
* Optional arguments must be put together at the end of the function. * Optional arguments must be put together at the end of the function.
* You must think carefully if there are several of them and put the less likely to be set manually by the function user at then end. In our example above, if you want do call the function with a `x` and a `z` you must mandatorily also provide explicitly `y`. * You must think carefully if there are several of them and put the less likely to be set manually by the function user at then end. In our example above, if you want do call the function with a `x` and a `z` you must mandatorily also provide explicitly `y`.
## Lambda functions ## Lambda functions
C++ 11 introduced a shorthand to define functions called __lambda functions__. C++ 11 introduced a shorthand to define functions called __lambda functions__.
An example is the best way to introduce them: An example is the best way to introduce them:
``` C++17 ``` C++17
// Locally defined function. // Locally defined function.
auto square = [](double x) -> double auto square = [](double x) -> double
return x * x; return x * x;
std::cout << square(5.) << std::endl; std::cout << square(5.) << std::endl;
Several notes: Several notes:
* Use `auto` as its return type; said type is not reproducible (see the _square_ and _cube_ example below). * Use `auto` as its return type; said type is not reproducible (see the _square_ and _cube_ example below).
* The symbol `->` that specifies the type of the returned value is optional. * The symbol `->` that specifies the type of the returned value is optional.
* Parameters come after the `[]` in parenthesis with the same syntax as ordinary functions. * Parameters come after the `[]` in parenthesis with the same syntax as ordinary functions.
* This is not the same as the [alternate syntax](../1-ProceduralProgramming/4-Functions.ipynb#Alternate-function-syntax) explained earlier, even if they look similar: a lambda may be defined locally (here within a block) whereas a standard function (with usual or alternate syntax) can't. * This is not the same as the [alternate syntax](../1-ProceduralProgramming/4-Functions.ipynb#Alternate-function-syntax) explained earlier, even if they look similar: a lambda may be defined locally (here within a block) whereas a standard function (with usual or alternate syntax) can't.
``` C++17 ``` C++17
auto square = [](double x) auto square = [](double x)
auto cube = [](double x) auto cube = [](double x)
return x * x * x; return x * x * x;
std::cout << "Are the lambda prototypes the same type? " std::cout << "Are the lambda prototypes the same type? "
<< (std::is_same<decltype(square), decltype(cube)>() ? "true" : "false") << std::endl; << (std::is_same<decltype(square), decltype(cube)>() ? "true" : "false") << std::endl;
Inside the `[]` you might specify values that are transmitted to the body of the function; by default nothing is transmitted: Inside the `[]` you might specify values that are transmitted to the body of the function; by default nothing is transmitted:
``` C++17 ``` C++17
int a = 5; int a = 5;
auto a_plus_b = [](int b) auto a_plus_b = [](int b)
std::cout << a_plus_b(3) << std::endl; // COMPILATION ERROR: a is not known inside the lambda body. std::cout << a_plus_b(3) << std::endl; // COMPILATION ERROR: a is not known inside the lambda body.
``` C++17 ``` C++17
auto a_plus_b = [a](int b) // Notice the `[a]` here! auto a_plus_b = [a](int b) // Notice the `[a]` here!
std::cout << a_plus_b(3) << std::endl; std::cout << a_plus_b(3) << std::endl;
The values captured in the lambda might be transmitted by reference: The values captured in the lambda might be transmitted by reference:
``` C++17 ``` C++17
auto add_to_a = [&a](int b) // Notice the `[&a]` here! auto add_to_a = [&a](int b) // Notice the `[&a]` here!
a += b; a += b;
add_to_a(3); add_to_a(3);
std::cout << a << std::endl; std::cout << a << std::endl;
It is possible to capture everything (in the scope where the lambda is defined) by reference by using `[&]` but it is really ill-advised; don't do this! It is possible to capture everything (in the scope where the lambda is defined) by reference by using `[&]` but it is really ill-advised; don't do this!
Lambda functions really shines when you want to use them in a very special context; see below an example using the sort function provided by the standard library, in which for some reasons we want to sort integers but in two blocks: first the odd numbers properly ordered and then the even numbers: Lambda functions really shines when you want to use them in a very special context; see below an example using the sort function provided by the standard library, in which for some reasons we want to sort integers but in two blocks: first the odd numbers properly ordered and then the even numbers:
``` C++17 ``` C++17
// Nice Jupyter Xeus-cling feature that doesn't work for the Conda version of cling in macOS. // Nice Jupyter Xeus-cling feature that doesn't work for the Conda version of cling in macOS.
?std::sort ?std::sort
``` C++17 ``` C++17
#include <vector> #include <vector>
#include <algorithm> // for sort #include <algorithm> // for sort
std::vector<int> list { 3, 5, 2, -4, 8, -17, 99, 15, 125447, 0, -1246 }; std::vector<int> list { 3, 5, 2, -4, 8, -17, 99, 15, 125447, 0, -1246 };
std::cout << "Initial list = "; std::cout << "Initial list = ";
for (int value : list) for (int value : list)
std::cout << value << ' '; std::cout << value << ' ';
// My very specific sort operation: // My very specific sort operation:
// Returns true if lhs is odd and rhs isn't or is lhs < rhs. // Returns true if lhs is odd and rhs isn't or if lhs < rhs.
auto odd_first = [](auto lhs, auto rhs) auto odd_first = [](auto lhs, auto rhs)
const bool is_lhs_odd = !(lhs % 2 == 0); const bool is_lhs_odd = !(lhs % 2 == 0);
const bool is_rhs_odd = !(rhs % 2 == 0); const bool is_rhs_odd = !(rhs % 2 == 0);
if (is_lhs_odd != is_rhs_odd) if (is_lhs_odd != is_rhs_odd)
return is_lhs_odd; return is_lhs_odd;
return lhs < rhs; return lhs < rhs;
std::sort(list.begin(), list.end(), odd_first); std::sort(list.begin(), list.end(), odd_first);
std::cout << std::endl << "Sorted list = "; std::cout << std::endl << "Sorted list = ";
Please notice the use of an intermediate local variable for the lambda is not mandatory; the lambda may be provided on the fly: Please notice the use of an intermediate local variable for the lambda is not mandatory; the lambda may be provided on the fly:
``` C++17 ``` C++17
#include <algorithm> #include <algorithm>
std::vector<int> even_only; std::vector<int> even_only;
// Don't worry about the syntax of `copy_if` or `back_inserter` here; we will see that later! // Don't worry about the syntax of `copy_if` or `back_inserter` here; we will see that later!
std::copy_if(list.cbegin(), std::copy_if(list.cbegin(),
list.cend(), list.cend(),
std::back_inserter(even_only), std::back_inserter(even_only),
[](int value) [](int value)
return value % 2 == 0; return value % 2 == 0;
for (int value : even_only) for (int value : even_only)
## Passing a function as a an argument ## Passing a function as a an argument
In some cases, you might want to pass a function as an argument (and honestly most of the time you should refrain to do so: it may underline your design is not top notch). In some cases, you might want to pass a function as an argument (and honestly most of the time you should refrain to do so: it may underline your design is not top notch).
The syntax to do so is a bit ugly and stems directly from C; it relies upon using a pointer to a function. The syntax to do so is a bit ugly and stems directly from C; it relies upon using a pointer to a function.
The syntax looks like: The syntax looks like:
`unsigned int (*f) (int, double)` `unsigned int (*f) (int, double)`
where: where:
* `unsigned int` is the return type. * `unsigned int` is the return type.
* `int, double` are the type of the parameters of the function given as argument. * `int, double` are the type of the parameters of the function given as argument.
* `f` is the name of the argument. * `f` is the name of the argument.
It will be clearer in an example: It will be clearer in an example:
``` C++17 ``` C++17
void PrintFunctionCall(int (*f) (int, int), int m, int n) void PrintFunctionCall(int (*f) (int, int), int m, int n)
std::cout << "f(" << m << ", " << n << ") = " << f(m, n) << std::endl; std::cout << "f(" << m << ", " << n << ") = " << f(m, n) << std::endl;
``` C++17 ``` C++17
int multiply(int a, int b) int multiply(int a, int b)
return a * b; return a * b;
``` C++17 ``` C++17
int add(int a, int b) int add(int a, int b)
``` C++17 ``` C++17
PrintFunctionCall(multiply, 5, 6); PrintFunctionCall(multiply, 5, 6);
PrintFunctionCall(add, 5, 6); PrintFunctionCall(add, 5, 6);
There are other ways to do this task: There are other ways to do this task:
* Using a template parameter. Templates will be reached [later in this tutorial](../4-Templates/0-main.ipynb), but for me it's usually the way to go. * Using a template parameter. Templates will be reached [later in this tutorial](../4-Templates/0-main.ipynb), but for me it's usually the way to go.
* Using [functors](../3-Operators/5-Functors.ipynb) * Using [functors](../3-Operators/5-Functors.ipynb)
* Using `std::function`, introduced in C++ 11. However <a href="https://vittorioromeo.info/index/blog/passing_functions_to_functions.html">this blog</a> explains why it's not a good idea; on top of the arguments given there it doesn't seem to respect the prototype closely (a function with double instead of int is for instance accepted). * Using `std::function`, introduced in C++ 11. However <a href="https://vittorioromeo.info/index/blog/passing_functions_to_functions.html">this blog</a> explains why it's not a good idea; on top of the arguments given there it doesn't seem to respect the prototype closely (a function with double instead of int is for instance accepted).
## A very special function: __main__ ## A very special function: __main__
Any C++ program must include one and only one `main` function. Its prototype is __int main(int argc, char** argv)__ where: Any C++ program must include one and only one `main` function. Its prototype is __int main(int argc, char** argv)__ where:
* __argc__ is the number of arguments given on the command line. This is at least 1: the name of the program is one argument. For instance, if your program creates a _isPrime_ executable that takes an integer as argument, `argc` will return 2. * __argc__ is the number of arguments given on the command line. This is at least 1: the name of the program is one argument. For instance, if your program creates a _isPrime_ executable that takes an integer as argument, `argc` will return 2.
* __argv__ is the list of arguments read on the command line, given as an array of C-strings. In our _isPrime_ example, __argv[0]__ is _isPrime_ and __argv[1]__ is the integer given. * __argv__ is the list of arguments read on the command line, given as an array of C-strings. In our _isPrime_ example, __argv[0]__ is _isPrime_ and __argv[1]__ is the integer given.
Please notice the internal mechanics of C/C++ compiler returns these values; if a user type `isPrime qwerty 20`, the main functions will return argc = 3. It is up to the writer of the main to ensure the arguments are correct. Please notice the internal mechanics of C/C++ compiler returns these values; if a user type `isPrime qwerty 20`, the main functions will return argc = 3. It is up to the writer of the main to ensure the arguments are correct.
If some of these values should be interpreted as numbers, it is also up to the developer to foresee the conversion from the C-string to a numerical value. If some of these values should be interpreted as numbers, it is also up to the developer to foresee the conversion from the C-string to a numerical value.
In the very specific of our Jupyter notebook, a unique main might be defined or not in the file: _cling_ performs some magic to generate one under the hood. In the very specific of our Jupyter notebook, a unique main might be defined or not in the file: _cling_ performs some magic to generate one under the hood.
The __main__ function may also be defined as __int main()__ without arguments if the program doesn't actually need any. The __main__ function may also be defined as __int main()__ without arguments if the program doesn't actually need any.
Sometimes, in old programs you may see __void main()__; this is not correct and is now refused by most modern compilers. Sometimes, in old programs you may see __void main()__; this is not correct and is now refused by most modern compilers.
The return value of the main function is an integer, __EXIT_SUCCESS__ should be returned when the program succeeds and __EXIT_FAILURE__ if it fails. You will often see a numerical value instead of these: __EXIT_SUCCESS__ is just a macro which value is 0. I recommend its use as you should strive to avoid any magic number in your codes. The return value of the main function is an integer, __EXIT_SUCCESS__ should be returned when the program succeeds and __EXIT_FAILURE__ if it fails. You will often see a numerical value instead of these: __EXIT_SUCCESS__ is just a macro which value is 0. I recommend its use as you should strive to avoid any magic number in your codes.
We will deal with main functions later when we will work in a true C++ environment. We will deal with main functions later when we will work in a true C++ environment.
## `inline` functions ## `inline` functions
You may also in a function declaration and definition function prepend the prototype by an `inline`. This indicates the compiler this function might be **inlined**: this means the content of the function may be copied directly, thus avoiding a function call and potentially making your code a tiny bit faster. So for instance if you have a function: You may also in a function declaration and definition function prepend the prototype by an `inline`. This indicates the compiler this function might be **inlined**: this means the content of the function may be copied directly, thus avoiding a function call and potentially making your code a tiny bit faster. So for instance if you have a function:
``` C++17 ``` C++17
inline double square(double x) inline double square(double x)
when this function is called somewhere, the compiler may replace directly the function by the code inside the definition: when this function is called somewhere, the compiler may replace directly the function by the code inside the definition:
``` C++17 ``` C++17
square(5.); // The compiler might substitute 5. * 5. to the actual function call here square(5.); // The compiler might substitute 5. * 5. to the actual function call here
This behaviour is pretty similar to the often frowned-upon **macros** from C, but the use of `inline` is absolutely not considered a bad practice... provided you have in mind the way it works: This behaviour is pretty similar to the often frowned-upon **macros** from C, but the use of `inline` is absolutely not considered a bad practice... provided you have in mind the way it works:
* You have probably notice the conditional in my statements regarding `inline`: the keyword is an _hint_ given to the compiler... that might be followed or not. * You have probably notice the conditional in my statements regarding `inline`: the keyword is an _hint_ given to the compiler... that might be followed or not.
* On the syntactic side, `inline` must be provided both in the declaration `and` the definition. * On the syntactic side, `inline` must be provided both in the declaration `and` the definition.
* `inline` definitions must be provided in header file (see the [upcoming notebook](../6-InRealEnvironment/2-FileStructure.ipynb) that will deal extensively with the file structure to follow in a C++ program). You therefore pay the price in compilation time whenever you change its implementation (as we'll see more in detail in aforementioned notebook, modifying a header file yields more re-compilation). * `inline` definitions must be provided in header file (see the [upcoming notebook](../6-InRealEnvironment/2-FileStructure.ipynb) that will deal extensively with the file structure to follow in a C++ program). You therefore pay the price in compilation time whenever you change its implementation (as we'll see more in detail in aforementioned notebook, modifying a header file yields more re-compilation).
* Don't bother inlining functions with any complexity whatsoever, so if your function includes a loop or is more than few lines long, write a normal function instead. * Don't bother inlining functions with any complexity whatsoever, so if your function includes a loop or is more than few lines long, write a normal function instead.
The `square` example was sound: this is typically the kind of functions that might be inlined. The `square` example was sound: this is typically the kind of functions that might be inlined.
Just to finish, my comparison with a macro was not fair; one of the known drawback of macros is perfectly handled: Just to finish, my comparison with a macro was not fair; one of the known drawback of macros is perfectly handled:
``` C++17 ``` C++17
#define SQUARE(x) ((x) * (x)) #define SQUARE(x) ((x) * (x))
``` C++17 ``` C++17
std::cout << square(++x) << std::endl; std::cout << square(++x) << std::endl;
std::cout << SQUARE(++x) << std::endl; std::cout << SQUARE(++x) << std::endl;
© _CNRS 2016_ - _Inria 2018-2021_ © _CNRS 2016_ - _Inria 2018-2021_
_This notebook is an adaptation of a lecture prepared by David Chamont (CNRS) under the terms of the licence [Attribution-NonCommercial-ShareAlike 4.0 International (CC BY-NC-SA 4.0)](http://creativecommons.org/licenses/by-nc-sa/4.0/)_ _This notebook is an adaptation of a lecture prepared by David Chamont (CNRS) under the terms of the licence [Attribution-NonCommercial-ShareAlike 4.0 International (CC BY-NC-SA 4.0)](http://creativecommons.org/licenses/by-nc-sa/4.0/)_
_The present version has been written by Sébastien Gilles and Vincent Rouvreau (Inria)_ _The present version has been written by Sébastien Gilles and Vincent Rouvreau (Inria)_
# [Getting started in C++](./) - [Procedural programming](./0-main.ipynb) - [Dynamic allocations](./5-DynamicAllocation.ipynb) # [Getting started in C++](./) - [Procedural programming](./0-main.ipynb) - [Dynamic allocations](./5-DynamicAllocation.ipynb)
<div class="toc"><ul class="toc-item"><li><span><a href="#Introduction" data-toc-modified-id="Introduction-1">Introduction</a></span></li><li><span><a href="#Stack" data-toc-modified-id="Stack-2">Stack</a></span></li><li><span><a href="#Heap-and-free-store" data-toc-modified-id="Heap-and-free-store-3">Heap and free store</a></span><ul class="toc-item"><li><span><a href="#Free-store?" data-toc-modified-id="Free-store?-3.1">Free store?</a></span></li></ul></li><li><span><a href="#Arrays-on-heap" data-toc-modified-id="Arrays-on-heap-4">Arrays on heap</a></span></li></ul></div> <div class="toc"><ul class="toc-item"><li><span><a href="#Introduction" data-toc-modified-id="Introduction-1">Introduction</a></span></li><li><span><a href="#Stack" data-toc-modified-id="Stack-2">Stack</a></span></li><li><span><a href="#Heap-and-free-store" data-toc-modified-id="Heap-and-free-store-3">Heap and free store</a></span><ul class="toc-item"><li><span><a href="#Free-store?" data-toc-modified-id="Free-store?-3.1">Free store?</a></span></li></ul></li><li><span><a href="#Arrays-on-heap" data-toc-modified-id="Arrays-on-heap-4">Arrays on heap</a></span></li></ul></div>
## Introduction ## Introduction
In C++, we can finely control the life cycle of objects and manage the memory allocated to them. This is what makes it possible to create more powerful applications than with many other languages, but it is also the main source of errors in the language. Pointers and dynamic memory management: watch out for danger! In C++, we can finely control the life cycle of objects and manage the memory allocated to them. This is what makes it possible to create more powerful applications than with many other languages, but it is also the main source of errors in the language. Pointers and dynamic memory management: watch out for danger!
## Stack ## Stack
The ordinary variables of C++ have a lifetime limited to the current instruction block, whether it is the current function, or an instruction block attached to an `if`, `for` or just independant. The ordinary variables of C++ have a lifetime limited to the current instruction block, whether it is the current function, or an instruction block attached to an `if`, `for` or just independant.
The memory allocated to them is located in an area called a **stack**, and is automatically relieved when exiting the current block using the **last in, first out** principle. The memory allocated to them is located in an area called a **stack**, and is automatically relieved when exiting the current block using the **last in, first out** principle.
``` C++17 ``` C++17
int a { 5 }; int a { 5 };
double b { 7.4 }; double b { 7.4 };
} // at the end of this block, b is released first and then a - but 99.99 % of the time you shouldn't care } // at the end of this block, b is released first and then a - but 99.99 % of the time you shouldn't care
// about that order! // about that order!
// a and b are not available here // a and b are not available here
There are few limitations with the stack: There are few limitations with the stack:
* The number of memory you can allocate on the stack is rather limited. On a current POSIX OS the order of magnitude is ~ 8 Mo (on Unix type `ulimit -a` in a terminal to get this information). If you allocate more you will get a **stack overflow** (and now you know why the [most popular developers forum](https://stackoverflow.com/) is named this way!) * The number of memory you can allocate on the stack is rather limited. On a current POSIX OS the order of magnitude is ~ 8 MB (on Unix type `ulimit -s` in a terminal to get this information). If you allocate more you will get a **stack overflow** (and now you know why the [most popular developers forum](https://stackoverflow.com/) is named this way!)
* The information is very local; you can't use it elsewhere. If you pass the variable as argument in a function for instance a copy is made (or if you're using a reference or a pointer you have to be sure all is done when the block is exited!) * The information is very local; you can't use it elsewhere. If you pass the variable as argument in a function for instance a copy is made (or if you're using a reference or a pointer you have to be sure all is done when the block is exited!)
* Stack information must be known at compile time: if you're allocating an array on the stack you must know its size beforehand. * Stack information must be known at compile time: if you're allocating an array on the stack you must know its size beforehand.
## Heap and free store ## Heap and free store
You can in fact also explicitly place a variable in another memory area called **heap** or **free store**; doing so overcomes the stack limitations mentioned above. You can in fact also explicitly place a variable in another memory area called **heap** or **free store**; doing so overcomes the stack limitations mentioned above.
This is done by calling the `new` operator, which reserves the memory and returns its address, so that the user can store it _with a pointer_. This is done by calling the `new` operator, which reserves the memory and returns its address, so that the user can store it _with a pointer_.
The **heap** is independent of the **stack** and the variable thus created exists as long as the `delete` operator is not explicitly called. The creation and destruction of this type of variable is the responsibility of the programmer. The **heap** is independent of the **stack** and the variable thus created exists as long as the `delete` operator is not explicitly called. The creation and destruction of this type of variable is the responsibility of the programmer.
``` C++17 ``` C++17
int* n = new int(5); // variable created on the heap and initialized with value 5. int* n = new int(5); // variable created on the heap and initialized with value 5.
std::cout << *n << std::endl; std::cout << *n << std::endl;
delete n; // deletion must be explicitly called; if not there is a memory leak! delete n; // deletion must be explicitly called; if not there is a memory leak!
What is especially tricky is that: What is especially tricky is that:
* Creating and destroying can be done in places very disconnected in your program. * Creating and destroying can be done in places very disconnected in your program.
* You must ensure that whatever the runtime path used in your program each variable allocated on the heap: * You must ensure that whatever the runtime path used in your program each variable allocated on the heap:
- is destroyed (otherwise you get a **memory leak**) - is destroyed (otherwise you get a **memory leak**)
- is only destroyed once (or your program will likely crash with a message about **double deletion**). - is only destroyed once (or your program will likely crash with a message about **double deletion**).
In sophisticated programs, this could lead in serious and tedious bookkeeping to ensure all variables are properly handled, even if tools such as [Valgrind](http://www.valgrind.org/) or [Address sanitizer](https://github.com/google/sanitizers/wiki/AddressSanitizer) may help to find out those you will probably have forgotten somewhere along the way. In sophisticated programs, this could lead in serious and tedious bookkeeping to ensure all variables are properly handled, even if tools such as [Valgrind](http://www.valgrind.org/) or [Address sanitizer](https://github.com/google/sanitizers/wiki/AddressSanitizer) may help to find out those you will probably have forgotten somewhere along the way.
To be honest, C++ gets quite a bad name due to this tedious memory handling; fortunately the RAII idiom provides a neat way to automatize nicely memory management (which we'll study [later](../5-UsefulConceptsAndSTL/2-RAII.ipynb)) and some vocal critics on forums that regret the lack of [garbage collection](https://en.wikipedia.org/wiki/Garbage_collection_(computer_science)) might actually not be aware of this fundamental (from my point of view at least) idiom. To be honest, C++ gets quite a bad name due to this tedious memory handling; fortunately the RAII idiom provides a neat way to automatize nicely memory management (which we'll study [later](../5-UsefulConceptsAndSTL/2-RAII.ipynb)) and some vocal critics on forums that regret the lack of [garbage collection](https://en.wikipedia.org/wiki/Garbage_collection_(computer_science)) might actually not be aware of this fundamental (from my point of view at least) idiom.
### Free store? ### Free store?
**Free store** is very similar in functionality to the **heap** (to the point I had to [check the difference](https://stackoverflow.com/questions/1350819/c-free-store-vs-heap) before writing this...) , and more often than not one word might be used as the other. If you want to be pedantic: **Free store** is very similar in functionality to the **heap** (to the point I had to [check the difference](https://stackoverflow.com/questions/1350819/c-free-store-vs-heap) before writing this...) , and more often than not one word might be used as the other. If you want to be pedantic:
* When memory is handled by `new`/`delete`, you should talk about **free store**. * When memory is handled by `new`/`delete`, you should talk about **free store**.
* When memory is handled by `malloc`/`free` (the C functions), you should talk about **heap**. * When memory is handled by `malloc`/`free` (the C functions), you should talk about **heap**.
Pedantry aside, the important thing to know is to never mix both syntax: if you allocate memory by `new` don't use `free` to relieve it. Pedantry aside, the important thing to know is to never mix both syntax: if you allocate memory by `new` don't use `free` to relieve it.
%% Cell type:markdown id: tags: %% Cell type:markdown id: tags:
## Arrays on heap ## Arrays on heap
If you want to init an array which size you do not know at compile time or that might overflow the stack, you may to do with `new` syntax mixed with `[]`: If you want to init an array which size you do not know at compile time or that might overflow the stack, you may to do with `new` syntax mixed with `[]`:
``` C++17 ``` C++17
const unsigned int Ndigit = 5; // not known at compile-time! const unsigned int Ndigit = 5; // not known at compile-time!
int* pi_first_five_digits = new int[Ndigit]; int* pi_first_five_digits = new int[Ndigit];
pi_first_five_digits[0] = 3; pi_first_five_digits[0] = 3;
pi_first_five_digits[1] = 1; pi_first_five_digits[1] = 1;
pi_first_five_digits[2] = 4; pi_first_five_digits[2] = 4;
pi_first_five_digits[3] = 1; pi_first_five_digits[3] = 1;
pi_first_five_digits[4] = 5; pi_first_five_digits[4] = 5;
delete[] pi_first_five_digits; delete[] pi_first_five_digits;
Please notice that: Please notice that:
* No value can be assigned in construction: you must first allocate the memory for the array and only in a second time fill it. * No value can be assigned in construction: you must first allocate the memory for the array and only in a second time fill it.
* A `[]` **must** be added to the **delete** instruction to indicate to the compiler this is actually an array that is destroyed. * A `[]` **must** be added to the **delete** instruction to indicate to the compiler this is actually an array that is destroyed.
In fact, my advice would be to avoid entirely to deal directly with such arrays and use containers from the standard library such as `std::vector`: In fact, my advice would be to avoid entirely to deal directly with such arrays and use containers from the standard library such as `std::vector`:
``` C++17 ``` C++17
std::vector<int> pi_first_five_digits { 3, 1, 4, 1, 5 }; std::vector<int> pi_first_five_digits { 3, 1, 4, 1, 5 };
that does the exact same job in a shorter way and is much more secure to use (spoiler: `std::vector` is built upon the RAII idiom mentioned briefly in this notebook). that does the exact same job in a shorter way and is much more secure to use (spoiler: `std::vector` is built upon the RAII idiom mentioned briefly in this notebook).
We shall see `std::vector` more deeply [later](../5-UsefulConceptsAndSTL/3-Containers.ipynb) but will nonetheless use it before this as it is a rather elementary brick in most C++ codes. We shall see `std::vector` more deeply [later](../5-UsefulConceptsAndSTL/3-Containers.ipynb) but will nonetheless use it before this as it is a rather elementary brick in most C++ codes.
# [Getting started in C++](./) - [Templates](./0-main.ipynb) - [Introduction](./1-Intro.ipynb) # [Getting started in C++](./) - [Templates](./0-main.ipynb) - [Introduction](./1-Intro.ipynb)
<h1>Table of contents<span class="tocSkip"></span></h1> <h1>Table of contents<span class="tocSkip"></span></h1>
<div class="toc"><ul class="toc-item"><li><span><a href="#Motivation" data-toc-modified-id="Motivation-1">Motivation</a></span></li><li><span><a href="#Function-templates-(or-methods)" data-toc-modified-id="Function-templates-(or-methods)-2">Function templates (or methods)</a></span><ul class="toc-item"><li><span><a href="#static_assert" data-toc-modified-id="static_assert-2.1"><code>static_assert</code></a></span></li></ul></li><li><span><a href="#Class-templates" data-toc-modified-id="Class-templates-3">Class templates</a></span><ul class="toc-item"><li><span><a href="#Template-method-of-a-template-class" data-toc-modified-id="Template-method-of-a-template-class-3.1">Template method of a template class</a></span></li><li><span><a href="#Friendship-syntax" data-toc-modified-id="Friendship-syntax-3.2">Friendship syntax</a></span></li></ul></li><li><span><a href="#Type-or-non-type-template-parameter" data-toc-modified-id="Type-or-non-type-template-parameter-4">Type or non-type template parameter</a></span></li><li><span><a href="#Few-precisions-about-templates" data-toc-modified-id="Few-precisions-about-templates-5">Few precisions about templates</a></span></li></ul></div> <div class="toc"><ul class="toc-item"><li><span><a href="#Motivation" data-toc-modified-id="Motivation-1">Motivation</a></span></li><li><span><a href="#Function-templates-(or-methods)" data-toc-modified-id="Function-templates-(or-methods)-2">Function templates (or methods)</a></span><ul class="toc-item"><li><span><a href="#static_assert" data-toc-modified-id="static_assert-2.1"><code>static_assert</code></a></span></li></ul></li><li><span><a href="#Class-templates" data-toc-modified-id="Class-templates-3">Class templates</a></span><ul class="toc-item"><li><span><a href="#Template-method-of-a-template-class" data-toc-modified-id="Template-method-of-a-template-class-3.1">Template method of a template class</a></span></li><li><span><a href="#Friendship-syntax" data-toc-modified-id="Friendship-syntax-3.2">Friendship syntax</a></span></li></ul></li><li><span><a href="#Type-or-non-type-template-parameter" data-toc-modified-id="Type-or-non-type-template-parameter-4">Type or non-type template parameter</a></span></li><li><span><a href="#Few-precisions-about-templates" data-toc-modified-id="Few-precisions-about-templates-5">Few precisions about templates</a></span></li></ul></div>
## Motivation ## Motivation
The typical introduction to the need of generic programming is implementing a function that determines the minimum between two quantities (by the way don't do that: STL provides it already...) The typical introduction to the need of generic programming is implementing a function that determines the minimum between two quantities (by the way don't do that: STL provides it already...)
``` C++17 ``` C++17
int min(int lhs, int rhs) int min(int lhs, int rhs)
return lhs < rhs ? lhs : rhs; return lhs < rhs ? lhs : rhs;
``` C++17 ``` C++17
double min(double lhs, double rhs) double min(double lhs, double rhs)
%% Cell type:code id: tags: %% Cell type:code id: tags:
``` C++17 ``` C++17
float min(float lhs, float rhs) float min(float lhs, float rhs)
``` C++17 ``` C++17
#include <iostream> #include <iostream>
std::cout << min(5, -8) << std::endl; std::cout << min(5, -8) << std::endl;
std::cout << min(5., -8.) << std::endl; std::cout << min(5., -8.) << std::endl;
std::cout << min(5.f, -8.f) << std::endl; std::cout << min(5.f, -8.f) << std::endl;
Already tired? Yet we have still to define the same for unsigned versions, other types such as `short` ou `long`... And it's not very [**DRY** (Don't Repeat Yourself)](https://en.wikipedia.org/wiki/Don%27t_repeat_yourself): you may have noticed the implementation is exactly the same! Already tired? Yet we have still to define the same for unsigned versions, other types such as `short` ou `long`... And it's not very [**DRY** (Don't Repeat Yourself)](https://en.wikipedia.org/wiki/Don%27t_repeat_yourself): you may have noticed the implementation is exactly the same!
## Function templates (or methods) ## Function templates (or methods)
A mechanism was therefore introduced in C++ to provide only one implementation: the **templates**: A mechanism was therefore introduced in C++ to provide only one implementation: the **templates**:
``` C++17 ``` C++17
template<class T> template<class T>
T min2(T lhs, T rhs) T min2(T lhs, T rhs)
``` C++17 ``` C++17
std::cout << min2<int>(5, -8) << std::endl; std::cout << min2<int>(5, -8) << std::endl;
std::cout << min2(5, -8) << std::endl; std::cout << min2(5, -8) << std::endl;
std::cout << min2(5., -8.) << std::endl; std::cout << min2(5., -8.) << std::endl;
std::cout << min2(5.f, -8.f) << std::endl; std::cout << min2(5.f, -8.f) << std::endl;
As you can see: As you can see:
* The type is replaced by a parameter (here called `T`) * The type is replaced by a parameter (here called `T`)
* In the function call, you might specify the type explicitly between brackets (`<>`). If not specified, the compiler may figure it out if said type is used for one of the parameters. In other words, for the following case it won't work: * In the function call, you might specify the type explicitly between brackets (`<>`). If not specified, the compiler may figure it out if said type is used for one of the parameters. In other words, for the following case it won't work:
``` C++17 ``` C++17
T Convert(int value) T Convert(int value)
return static_cast<T>(value); return static_cast<T>(value);
``` C++17 ``` C++17
double x = Convert(5); // Error: can't figure out which type `T` to use! double x = Convert(5); // Error: can't figure out which type `T` to use!
``` C++17 ``` C++17
float x = Convert<double>(5); // Ok float x = Convert<double>(5); // Ok
You may have see noticed there are no constraints on `T` whatsoever. If you invoke a template and the implementation doesn't make sense for the chosen type the compiler will yell (no doubt you have already seen compilers are extremely talented to do so and it is even truer regarding templates...) You may have noticed there are no constraints on `T` whatsoever. If you invoke a template and the implementation doesn't make sense for the chosen type the compiler will yell (no doubt you have already seen compilers are extremely talented to do so and it is even truer regarding templates...)
``` C++17 ``` C++17
Convert<std::string>(5); // Doesn't make sense so compiler will yell! Convert<std::string>(5); // Doesn't make sense so compiler will yell!
### `static_assert` ### `static_assert`
Of course, it would be nicer to get a clearer error message when an impossible type is provided... C++ 20 will introduce the [concept](https://en.cppreference.com/w/cpp/language/constraints) to constraint properly which type is acceptable, but C++ 11 already introduced a way slightly better than C++ 03 with `static_assert`: Of course, it would be nicer to get a clearer error message when an impossible type is provided... C++ 20 will introduce the [concept](https://en.cppreference.com/w/cpp/language/constraints) to constraint properly which type is acceptable, but C++ 11 already introduced a way slightly better than C++ 03 with `static_assert`:
``` C++17 ``` C++17
#include <type_traits> // for std::is_arithmetic #include <type_traits> // for std::is_arithmetic
T Convert2(int value) T Convert2(int value)
static_assert(std::is_arithmetic<T>(), "T must be an integer or a floating point!"); static_assert(std::is_arithmetic<T>(), "T must be an integer or a floating point!");
``` C++17 ``` C++17
Convert2<std::string>(5); // Doesn't make sense so compiler will yell! Convert2<std::string>(5); // Doesn't make sense so compiler will yell!
// But first line is much clearer than previously... // But first line is much clearer than previously...
`static_assert` evolved in C++ 17: `static_assert` evolved in C++ 17:
* In C++ 11, it takes two arguments: the test and a string which features an explanation on the topic at hand. * In C++ 11, it takes two arguments: the test and a string which features an explanation on the topic at hand.
* In C++ 17 and above, you might just give the test; it is actually handy when the test is already crystal clear: * In C++ 17 and above, you might just give the test; it is actually handy when the test is already crystal clear:
````static_assert(std::is_same<T, int>(), "Check T is an integer");```` is a tad overkill! ````static_assert(std::is_same<T, int>(), "Check T is an integer");```` is a tad overkill!
That being said, if the test is not that trivial you should really use the possibility to add an explanation. That being said, if the test is not that trivial you should really use the possibility to add an explanation.
## Class templates ## Class templates
We have seen templates in the case of functions, but classes can be templated as well: We have seen templates in the case of functions, but classes can be templated as well:
``` C++17 ``` C++17
class HoldAValue class HoldAValue
public: public:
HoldAValue(T value); HoldAValue(T value);
T GetValue() const; T GetValue() const;
private: private:
T value_; T value_;
``` C++17 ``` C++17
HoldAValue<T>::HoldAValue(T value) // the <T> is mandatory to identify properly the class HoldAValue<T>::HoldAValue(T value) // the <T> is mandatory to identify properly the class
: value_(value) : value_(value)
``` C++17 ``` C++17
T HoldAValue<T>::GetValue() const T HoldAValue<T>::GetValue() const
return value_; return value_;
``` C++17 ``` C++17
HoldAValue integer(5); HoldAValue integer(5);
std::cout << "Integer hold: " << integer.GetValue() << std::endl; std::cout << "Integer hold: " << integer.GetValue() << std::endl;
HoldAValue<std::string> string("Hello world!"); // If type not specified explicitly it would have been char*... HoldAValue<std::string> string("Hello world!"); // If type not specified explicitly it would have been char*...
std::cout << "String hold: " << string.GetValue() << std::endl; std::cout << "String hold: " << string.GetValue() << std::endl;
The template must be reminded in the definition as well; please notice before the `::` the brackets with the parameters *without their type*. The template must be reminded in the definition as well; please notice before the `::` the brackets with the parameters *without their type*.
### Template method of a template class ### Template method of a template class
Notice a template class may provide template methods: Notice a template class may provide template methods:
``` C++17 ``` C++17
class HoldAValue2 class HoldAValue2
public: public:
HoldAValue2(T value); HoldAValue2(T value);
template<class U> template<class U>
U Convert() const; U Convert() const;
private: private:
T value_; T value_;
``` C++17 ``` C++17
HoldAValue2<T>::HoldAValue2(T value) HoldAValue2<T>::HoldAValue2(T value)
``` C++17 ``` C++17
T HoldAValue2<T>::GetValue() const T HoldAValue2<T>::GetValue() const
In this case there are two `template` keyword for the definition: one for the class and the other for the method: In this case there are two `template` keyword for the definition: one for the class and the other for the method:
``` C++17 ``` C++17
template<class T> // template type for the class first template<class T> // template type for the class first
template<class U> // then template type for the method template<class U> // then template type for the method
U HoldAValue2<T>::Convert() const U HoldAValue2<T>::Convert() const
return static_cast<U>(value_); return static_cast<U>(value_);
``` C++17 ``` C++17
HoldAValue2 hold(9); HoldAValue2 hold(9);
hold.Convert<double>(); hold.Convert<double>();
### Friendship syntax ### Friendship syntax
There is a weird and specific syntax that is expected if you want to declare a friendship to a function. Quite naturally you would probably write something like: There is a weird and specific syntax that is expected if you want to declare a friendship to a function. Quite naturally you would probably write something like:
``` C++17 ``` C++17
class HoldAValue3 class HoldAValue3
public: public:
HoldAValue3(T value); HoldAValue3(T value);
friend void print(const HoldAValue3<T>& obj); friend void print(const HoldAValue3<T>& obj);
private: private:
T value_; T value_;
``` C++17 ``` C++17
HoldAValue3<T>::HoldAValue3(T value) HoldAValue3<T>::HoldAValue3(T value)
``` C++17 ``` C++17
void print(const HoldAValue3<T>& obj) void print(const HoldAValue3<T>& obj)
// Friendship required to access private data. // Friendship required to access private data.
// I wouldn't recommend friendship where an accessor would do the same task easily! // I wouldn't recommend friendship where an accessor would do the same task easily!
std::cout << "Underlying value is " << obj.value_ << std::endl; std::cout << "Underlying value is " << obj.value_ << std::endl;
``` C++17 ``` C++17
HoldAValue3<int> hold(5); HoldAValue3<int> hold(5);
print(hold); // LINK ERROR, and that is not something amiss in Xeus-cling! print(hold); // LINK ERROR, and that is not something amiss in Xeus-cling!
To make the friendship work, you have to use in the friendship declaration another label for the template parameter: To make the friendship work, you have to use in the friendship declaration another label for the template parameter:
``` C++17 ``` C++17
class HoldAValue4 class HoldAValue4
public: public:
HoldAValue4(T value); HoldAValue4(T value);
// 'Repeating' the list of template arguments and not using the ones from the class will fix the issue... // 'Repeating' the list of template arguments and not using the ones from the class will fix the issue...
// T wouldn't have work here; the label MUST differ. // T wouldn't have work here; the label MUST differ.
friend void print(const HoldAValue4<U>& obj); friend void print(const HoldAValue4<U>& obj);
private: private:
T value_; T value_;
``` C++17 ``` C++17
HoldAValue4<T>::HoldAValue4(T value) HoldAValue4<T>::HoldAValue4(T value)
``` C++17 ``` C++17
// Notice it is only a label: in the definition I'm free to use the same label as for the class definitions! // Notice it is only a label: in the definition I'm free to use the same label as for the class definitions!
void print(const HoldAValue4<T>& obj) void print(const HoldAValue4<T>& obj)
``` C++17 ``` C++17
HoldAValue4<int> hold(5); HoldAValue4<int> hold(5);
print(hold); // Ok! print(hold); // Ok!
This way of declaring friendship works but is not entirely fullproof: `print<int>` is hence a friend of `HoldAValue4<double>`, which was not what was sought. Most of the time it's ok but there are 2 other ways to declare friendship; have a look at [this link](https://web.mst.edu/~nmjxv3/articles/templates.html) if you want to learn more about it. This way of declaring friendship works but is not entirely fullproof: `print<int>` is hence a friend of `HoldAValue4<double>`, which was not what was sought. Most of the time it's ok but there are 2 other ways to declare friendship; have a look at [this link](https://web.mst.edu/~nmjxv3/articles/templates.html) if you want to learn more about it.
## Type or non-type template parameter ## Type or non-type template parameter
The examples so far are using **type** parameters: the `T` in the example stands for a type and is deemed to be substituted by a type. Templates may also use **non type** parameters, which are in most cases `enum` or `integral constant` types (beware: floating point types parameters or `std::string` **can't** be used as template parameters!) The examples so far are using **type** parameters: the `T` in the example stands for a type and is deemed to be substituted by a type. Templates may also use **non type** parameters, which are in most cases `enum` or `integral constant` types (beware: floating point types parameters or `std::string` **can't** be used as template parameters!)
Both can be mixed in a given template declaration: Both can be mixed in a given template declaration:
``` C++17 ``` C++17
template<class TypeT, std::size_t Nelts> template<class TypeT, std::size_t Nelts>
class MyArray class MyArray
public: public:
explicit MyArray(TypeT initial_value); explicit MyArray(TypeT initial_value);
private: private:
TypeT content_[Nelts]; TypeT content_[Nelts];
``` C++17 ``` C++17
MyArray<TypeT, Nelts>::MyArray(TypeT initial_value) MyArray<TypeT, Nelts>::MyArray(TypeT initial_value)
for (std::size_t i = 0; i < Nelts; ++i) for (std::size_t i = 0; i < Nelts; ++i)
content_[i] = initial_value; content_[i] = initial_value;
``` C++17 ``` C++17
MyArray<int, 5ul> array1(2); MyArray<int, 5ul> array1(2);
MyArray<double, 2ul> array2(3.3); MyArray<double, 2ul> array2(3.3);
However, you can't provide a type parameter where a non-type is expected (and vice-versa): However, you can't provide a type parameter where a non-type is expected (and vice-versa):
``` C++17 ``` C++17
MyArray<5ul, 5ul> array1(2); // COMPILATION ERROR! MyArray<5ul, 5ul> array1(2); // COMPILATION ERROR!
``` C++17 ``` C++17
MyArray<int, int> array1(2); // COMPILATION ERROR! MyArray<int, int> array1(2); // COMPILATION ERROR!
## Few precisions about templates ## Few precisions about templates
* Template parameters must be known or computed at **compile time**. You can't therefore instantiate a template from a value that was entered by the user of the program or computed at runtime. * Template parameters must be known or computed at **compile time**. You can't therefore instantiate a template from a value that was entered by the user of the program or computed at runtime.
* In the template syntax, `class` might be replaced by `typename`: * In the template syntax, `class` might be replaced by `typename`:
``` C++17 ``` C++17
template<typename T> template<typename T>
T Convert3(int value) T Convert3(int value)
There are exactly zero differences between both keywords; some authors suggest conventions (e.g. use `typename` for POD types and `class` for the more complicated types) but they are just that: conventions! There are exactly zero differences between both keywords; some authors suggest conventions (e.g. use `typename` for POD types and `class` for the more complicated types) but they are just that: conventions!
* The definition of the templates must be provided in header files, not in compiled files. The reason is that the compiler can't know all the types for which the template might be used: you may use `std::min` for your own defined types (provided they define a `<` operator...) and obviously STL writers can't foresee which type you will come up with! * The definition of the templates must be provided in header files, not in compiled files. The reason is that the compiler can't know all the types for which the template might be used: you may use `std::min` for your own defined types (provided they define a `<` operator...) and obviously STL writers can't foresee which type you will come up with!
* The compiler will generate the code for each type given to the template; for instance if `Convert<double>`, `Convert<unsigned int>` and `Convert<short>` are used in your code, the content of this template function will be instantiated thrice! This can lead to **code bloat**: lots of assembler code is generated, and compilation time may increase significatively. * The compiler will generate the code for each type given to the template; for instance if `Convert<double>`, `Convert<unsigned int>` and `Convert<short>` are used in your code, the content of this template function will be instantiated thrice! This can lead to **code bloat**: lots of assembler code is generated, and compilation time may increase significatively.
* So templates are a _very_ nice tool, but make sure to use them only when they're relevant, and you may employ techniques to limit the amount of code actually defined within the template definitions - the more straightforward being defining in a non template function the parts of the implementation that do not depend on the template parameter type. This way, this part of the code is not duplicated for each different type. * So templates are a _very_ nice tool, but make sure to use them only when they're relevant, and you may employ techniques to limit the amount of code actually defined within the template definitions - the more straightforward being defining in a non template function the parts of the implementation that do not depend on the template parameter type. This way, this part of the code is not duplicated for each different type.
