Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • sfilip/rminimax
1 result
Show changes
Commits on Source (2)
......@@ -15,20 +15,19 @@ elseif(COMPILER_SUPPORTS_CXX0X)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++0x")
else()
message(STATUS "The compiler ${CMAKE_CXX_COMPILER} has no C++11
support. Please use a C++11-supporting compiler.")
support. Please use a C++11-compatible compiler.")
endif()
# Check that the prerequisite libraries are installed and visible
message(STATUS "Starting dependency check...")
set (INCLUDE_DEPS gmp mpfr mpreal fplll qsopt_ex eigen3 flint2 arb)
set (LIB_DEPS gmp mpfr fplll qsopt_ex flint2 arb)
set (INCLUDE_DEPS gmp mpfr mpreal fplll qsopt_ex eigen3 flint3)
set (LIB_DEPS gmp mpfr fplll qsopt_ex flint3)
set (gmp_lib gmp)
set (mpfr_lib mpfr)
set (fplll_lib fplll)
set (qsopt_ex_lib qsopt_ex)
set (flint2_lib flint)
set (arb_lib arb)
set (flint3_lib flint)
set (gmp_header gmp.h)
set (mpfr_header mpfr.h)
......@@ -36,8 +35,7 @@ set (mpreal_header mpreal.h)
set (fplll_header fplll.h)
set (qsopt_ex_header qsopt_ex/QSopt_ex.h)
set (eigen3_header eigen3/Eigen)
set (flint2_header flint/flint.h)
set (arb_header arb.h)
set (flint3_header flint/flint.h)
foreach (LIB ${LIB_DEPS})
string (TOUPPER ${LIB} LIB_UPPER)
......@@ -62,6 +60,10 @@ foreach (LIB ${INCLUDE_DEPS})
set (DEP_INCLUDE_DIRS ${DEP_INCLUDE_DIRS} ${${HEADER_PKG}_INCLUDE_DIR})
endforeach ()
if (FLINT3_VERSION_MAJOR LESS 3)
message(FATAL_ERROR "\t rminimax requires at least Flint version 3.0")
endif()
message (STATUS "Finished dependency check.")
add_subdirectory(${PROJECT_SOURCE_DIR}/src)
......@@ -75,4 +77,6 @@ target_link_libraries(ratapprox ${LIB_DEPS} rminimax)
# generate test executables
add_executable(test_atan tests/test_atan.cpp)
add_executable(test_lyon tests/test_lyon.cpp)
target_link_libraries(test_atan ${LIB_DEPS} rminimax)
target_link_libraries(test_lyon ${LIB_DEPS} rminimax)
......@@ -15,7 +15,6 @@ This tool requires the following tools and/or libraries be installed and discove
* [fplll](https://github.com/fplll/fplll) - C++ library implementing several lattice algorithms
* [QSopt Exact](https://github.com/jonls/qsopt-ex) - an exact linear programming solver, written in C
* [flint](https://flintlib.org/) - C library for doing number theory
* [Arb](https://fredrikj.net/arb/) - C library for arbitrary-precision floating-point ball arithmetic
## Compilation
This is a CMake-based project, hence building the tool can be as simple as
#include "fpminimax.h"
#include "cheby.h"
#include "minimax.h"
#include <acb.h>
#include <arb.h>
#include <arb_fmpz_poly.h>
#include <cstdlib>
#include <flint/acb.h>
#include <flint/arb.h>
#include <flint/arb_fmpz_poly.h>
#include <flint/arith.h>
#include <flint/fmpz_poly_factor.h>
#include <fplll.h>
#include <fstream>
#include <sstream>
......@@ -175,20 +176,25 @@ void factorize(
fmpz_poly_t p;
fmpz_poly_factor_t fac;
acb_ptr roots;
mpz_t ibuff;
fmpz_t ibuff, decomp_fmpz;
mpz_t ibuff_mpz;
fmpz_poly_init(p);
fmpz_poly_factor_init(fac);
mpz_init(ibuff);
fmpz_init(ibuff);
fmpz_init(decomp_fmpz);
mpz_init(ibuff_mpz);
for (std::size_t i{0u}; i < coeffs.size(); ++i) {
decomp = mpfr_decomp(coeffs[i]);
decomp.second -= scale_exp;
mpz_ui_pow_ui(ibuff, 2u, (unsigned int)decomp.second);
mpz_mul(ibuff, ibuff, decomp.first.get_mpz_t());
fmpz_poly_set_coeff_mpz(p, i, ibuff);
fmpz_ui_pow_ui(ibuff, 2u, (unsigned int)decomp.second);
fmpz_set_mpz(decomp_fmpz, decomp.first.get_mpz_t());
fmpz_mul(ibuff, ibuff, decomp_fmpz);
fmpz_poly_set_coeff_fmpz(p, i, ibuff);
scale = mpreal(ibuff);
fmpz_get_mpz(ibuff_mpz, ibuff);
scale = mpreal(ibuff_mpz);
scale <<= scale_exp;
fmpz_poly_factor_squarefree(fac, p);
......@@ -225,7 +231,9 @@ void factorize(
fmpz_poly_factor_clear(fac);
fmpz_poly_clear(p);
mpz_clear(ibuff);
fmpz_clear(ibuff);
fmpz_clear(decomp_fmpz);
mpz_clear(ibuff_mpz);
mpreal::set_default_prec(prev);
