GitLab
Explore
Primary navigation
Search or go to…
E
eScriptorium
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
scripta
eScriptorium
ef456f17
ef456f17
4 years ago
Robin Tissot
Downloads
Patches
Fixes volumes inheritance confusing docker config.
ddcdb551
2
2 changed files
docker-compose.override.yml_example
+7
-6
7 additions, 6 deletions
docker-compose.yml
+0
-2
0 additions, 2 deletions
docker-compose.yml
7 additions
8 deletions
7
6
ef456f17
version: "3.9"
version: "3.9"
services:
services:
### to customize the homepage, uncomment this
#app:
# environment:
# - CUSTOM_HOME=True
# volumes:
# - $PWD/app/homepage
web: &web
web: &web
restart: always
restart: always
# deploy:
# deploy:
@@ -10,12 +17,6 @@ services:
# constraints:
# constraints:
# - node.hostname == frontend0
# environment:
# volumes:
channelserver:
channelserver:
restart: always
restart: always
# deploy:
# deploy:
This diff is collapsed.
docker-compose.yml
ef456f17
@@ -15,8 +15,6 @@ services:
web
web
*app
*app
command
uwsgi --ini /usr/src/app/uwsgi.ini
command
volumes
logs:/user/src/app/escriptorium/logs
expose
expose
8000
8000
Loading
Save comment
