Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Select Git revision
  • 151-implement-addall-stream-atom-for-factbases
  • 158-refactor-component-builder
  • 163-fixing-evaluate-and-saturate-exception-with-provided-query-or-fact-2
  • 166-doter-les-unionfoquery-des-methodes-add-and-remove
  • 187-add-explanation-module
  • 190-deprecate-storedfunctionalterm-backup
  • 197-handle-errors-for-api
  • 199-add-fallback-for-mus-enumeration-in-explanations
  • 200-going-further-towards-the-generalized-use-of-keywords
  • 203-adding-comments-and-correcting-atomtype
  • 205-integrating-iri-naming-in-integraal
  • 208-integraal-cli-bug-fixing-qol
  • NCLI
  • NNCLI
  • WIP
  • acharoen/WIP
  • detached
  • detached2
  • develop
  • develop-test-kbdm
  • explanations_hypergraph
  • features-explanations
  • features/integraal-corese-storage
  • features/integraal-tatooine
  • filtered_hypergraph
  • hybrid-reasoning
  • mapping-examples
  • mapping-examples-new-containers
  • refactoring_explanation
  • test-gui
  • test-merge-187
  • tmp_explanation
  • Corese-storages
  • Tatooine
  • cycle-1
  • cycle-2
  • cycle-3
  • cycle-4
  • cycle-5
  • cycle-6
  • cycle-7
41 results
Target
  • rules/integraal
  • ulliana/integraal
2 results
Select Git revision
  • NCLI
  • NNCLI
  • WIP
  • acharoen/WIP
  • detached
  • detached2
  • develop
  • develop-test-kbdm
  • hybrid-reasoning
  • mapping-examples
  • test-gui
  • test-merge-187
  • tmp_explanation
  • Corese-storages
  • Tatooine
  • cycle-1
  • cycle-2
  • cycle-3
  • cycle-4
  • cycle-5
  • cycle-6
  • cycle-7
41 results
Show changes
Commits on Source (1)
with 664 additions and 92 deletions
...@@ -273,6 +273,7 @@ public enum InteGraalKeywords { ...@@ -273,6 +273,7 @@ public enum InteGraalKeywords {
* Query Explanation * Query Explanation
QUERY_EXPLANATION, QUERY_EXPLANATION,
BASELINE_EXPLANATION,
* CSV Rules Encoding * CSV Rules Encoding
...@@ -12,10 +12,16 @@ import fr.boreal.model.logicalElements.api.Term; ...@@ -12,10 +12,16 @@ import fr.boreal.model.logicalElements.api.Term;
import fr.boreal.model.rule.api.FORule; import fr.boreal.model.rule.api.FORule;
import fr.boreal.storage.natives.SimpleInMemoryGraphStore; import fr.boreal.storage.natives.SimpleInMemoryGraphStore;
import java.io.BufferedWriter;
import java.io.File; import java.io.File;
import java.io.IOException; import java.io.IOException;
import java.nio.file.Files;
import java.nio.file.Path;
import java.nio.file.Paths;
import java.util.*; import java.util.*;
import java.util.Collections; import java.util.Collections;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
import java.util.stream.Collectors; import java.util.stream.Collectors;
public class QuerySelector { public class QuerySelector {
...@@ -97,9 +103,9 @@ public class QuerySelector { ...@@ -97,9 +103,9 @@ public class QuerySelector {
.created_facts_as_factbase() .created_facts_as_factbase()
.getAtoms() .getAtoms()
.filter(a -> a.getPredicate().label().startsWith("query")) .filter(a -> a.getPredicate().label().startsWith("query"))
.filter(a -> !a.getPredicate().label().startsWith("constant"))
.filter(a -> !a.getPredicate().label().startsWith("owl:Thing")) .filter(a -> !a.getPredicate().label().startsWith("owl:Thing"))
.filter(a -> Arrays.stream(a.getTerms()).noneMatch(Term::isVariable)) .filter(a -> Arrays.stream(a.getTerms()).noneMatch(Term::isVariable))
.filter(a -> Arrays.stream(a.getTerms()).noneMatch(t -> t.toString().startsWith("constant")))
.collect(Collectors.toList()); .collect(Collectors.toList());
if (!factsProduced.isEmpty()) { if (!factsProduced.isEmpty()) {
...@@ -107,19 +113,8 @@ public class QuerySelector { ...@@ -107,19 +113,8 @@ public class QuerySelector {
// List<List<Atom>> allQueries = new ArrayList<>(); writePredicateMatrixCsv(foundAxiomEntailments, Paths.get("predicates.csv"));
// for (int i = 0; i < foundAxiomEntailments.size(); i++) { writeDlgpFiles(foundAxiomEntailments, Paths.get("dlgps"));
// List<Atom> l = new ArrayList<>();
// for (Atom a : foundAxiomEntailments.get(i)) {
// if (a.getPredicate().label().startsWith("query")) {
// l.add(a);
// if (!l.isEmpty()) {
// allQueries.add(l);
for (List<Atom> l : foundAxiomEntailments) { for (List<Atom> l : foundAxiomEntailments) {
System.out.println(l.size()); System.out.println(l.size());
...@@ -141,6 +136,125 @@ public class QuerySelector { ...@@ -141,6 +136,125 @@ public class QuerySelector {
return queries; return queries;
public static List<Atom> getBalancedStrike(List<List<Atom>> listOfLists, int nbQueries) {
List<Atom> flatList = new ArrayList<>();
for (List<Atom> sublist : listOfLists) {
flatList.addAll(sublist);
if (flatList.isEmpty()) {
System.out.println("No atoms available.");
return Collections.emptyList();
// Group atoms by predicate
Map<String, List<Atom>> atomsByPredicate = new HashMap<>();
for (Atom atom : flatList) {
String predicate = atom.getPredicate().label();
atomsByPredicate.computeIfAbsent(predicate, k -> new ArrayList<>()).add(atom);
int predicateCount = atomsByPredicate.size();
int baseCount = nbQueries / predicateCount;
int leftover = nbQueries % predicateCount;
Set<Atom> resultSet = new LinkedHashSet<>();
Random random = new Random();
// Step 1: Select baseCount atoms per predicate
for (Map.Entry<String, List<Atom>> entry : atomsByPredicate.entrySet()) {
List<Atom> atoms = entry.getValue();
Collections.shuffle(atoms, random);
int limit = Math.min(baseCount, atoms.size());
resultSet.addAll(atoms.subList(0, limit));
// Step 2: Distribute leftovers to predicates that have room
List<Atom> leftovers = new ArrayList<>();
for (Atom atom : atoms) {
if (!resultSet.contains(atom)) {
leftovers.add(atom);
Collections.shuffle(leftovers, random);
Iterator<Atom> iter = leftovers.iterator();
while (resultSet.size() < nbQueries && iter.hasNext()) {
resultSet.add(iter.next());
// Count atoms per predicate
Map<String, Integer> predicateCounts = new TreeMap<>();
for (Atom atom : resultSet) {
predicateCounts.put(predicate, predicateCounts.getOrDefault(predicate, 0) + 1);
System.out.println("Selected " + nbQueries + " atoms with " + predicateCounts.size() + " distinct predicates:");
for (Map.Entry<String, Integer> entry : predicateCounts.entrySet()) {
System.out.println(" " + entry.getKey() + ": " + entry.getValue());
return new ArrayList<>(resultSet);
public static List<Atom> getSimpleStrikes(List<List<Atom>> listOfLists, int nbQueries) {
// Separate atoms by predicate
List<Atom> q01Atoms = new ArrayList<>();
List<Atom> q03Atoms = new ArrayList<>();
List<Atom> otherAtoms = new ArrayList<>();
String predicate = atom.getPredicate().label(); // Adjust as needed
if (predicate.contains("query01")) {
q01Atoms.add(atom);
} else if (predicate.contains("query03")) {
q03Atoms.add(atom);
} else {
otherAtoms.add(atom);
resultSet.addAll(q01Atoms);
resultSet.addAll(q03Atoms);
int remaining = nbQueries - resultSet.size();
if (remaining <= 0) {
// Already have 100 or more atoms, just return the first 100
return new ArrayList<>(resultSet).subList(0, nbQueries);
List<Atom> workingPool = new ArrayList<>(otherAtoms);
while (resultSet.size() < nbQueries) {
Collections.shuffle(workingPool, random);
for (Atom atom : workingPool) {
resultSet.add(atom);
if (resultSet.size() == nbQueries) {
break;
public static List<Atom> sampleQueries(List<List<Atom>> lists, int nbQueries) { public static List<Atom> sampleQueries(List<List<Atom>> lists, int nbQueries) {
if (lists == null || lists.isEmpty()) { if (lists == null || lists.isEmpty()) {
throw new IllegalArgumentException("The outer list must not be null or empty."); throw new IllegalArgumentException("The outer list must not be null or empty.");
...@@ -195,4 +309,106 @@ public class QuerySelector { ...@@ -195,4 +309,106 @@ public class QuerySelector {
return picked; return picked;
public static void writePredicateMatrixCsv(List<List<Atom>> levels,
Path csvTarget) throws IOException {
Map<String,int[]> matrix = buildCountMatrix(levels); // ← compte, pas présence
int levelCount = levels.size();
try (BufferedWriter w = Files.newBufferedWriter(csvTarget)) {
// Header
w.write("Predicate");
for (int i = 0; i < levelCount; i++) w.write(",L" + i);
w.write(",Total"); // ← colonne de synthèse (optionnel)
w.newLine();
for (Map.Entry<String,int[]> e : matrix.entrySet()) {
w.write(e.getKey());
int sum = 0;
for (int c : e.getValue()) {
w.write(',' + Integer.toString(c)); // « 0 » si absent
sum += c;
w.write(',' + Integer.toString(sum)); // ← total sur toutes les
w.newLine(); // profondeurs
private static Map<String,int[]> buildCountMatrix(List<List<Atom>> levels) {
Map<String,int[]> matrix = new TreeMap<>();
Pattern name = Pattern.compile("^\\s*([^(\\s]+)\\s*\\(");
for (int lvl = 0; lvl < levelCount; lvl++) {
for (Atom a : levels.get(lvl)) {
String fact = a.toString();
Matcher m = name.matcher(fact);
if (m.find()) {
String p = m.group(1);
matrix.computeIfAbsent(p, k -> new int[levelCount])[lvl]++; // ← ++
return matrix;
* Creates one DLGP file per level.
* @param levels List of levels, each level is a List of fact strings
* @param outputFolder Directory to receive the files (must exist or be creatable)
* @throws IOException if writing fails
public static void writeDlgpFiles(List<List<Atom>> levels,
Path outputFolder) throws IOException {
if (!Files.exists(outputFolder))
Files.createDirectories(outputFolder);
for (int i = 0; i < levels.size(); i++) {
Path file = outputFolder.resolve("level_" + i + ".dlgp");
try (BufferedWriter w = Files.newBufferedWriter(file)) {
for (Atom a : levels.get(i)) {
w.write("@facts");
w.write(System.lineSeparator());
w.write(fact.trim());
if (!fact.trim().endsWith(".")) w.write(".");
// Helpers
private static final Pattern PREDICATE_NAME =
/** Builds a predicate-to-level presence matrix */
private static Map<String, boolean[]> buildPresenceMatrix(List<List<Atom>> levels) {
Map<String, boolean[]> matrix = new TreeMap<>(); // alpha order for readability
Matcher m = PREDICATE_NAME.matcher(fact);
if (m.find()) {
String pred = m.group(1);
matrix.computeIfAbsent(pred, k -> new boolean[levelCount])[lvl] = true;
} else {
// silently ignore malformed lines; could also throw
return matrix;
...@@ -283,6 +283,7 @@ public abstract class AbstractStaticGRIBasedExplainer_KBGRI<ExplanationType> imp ...@@ -283,6 +283,7 @@ public abstract class AbstractStaticGRIBasedExplainer_KBGRI<ExplanationType> imp
StatsUtil.timerWithOrderedQuery(this::decodeGMUSesFromSat4j, queryNumber, explainerName, "Decoding GMUSes from sat4j", datasetName); StatsUtil.timerWithOrderedQuery(this::decodeGMUSesFromSat4j, queryNumber, explainerName, "Decoding GMUSes from sat4j", datasetName);
StatsUtil.recordSize((long) encodingResult.clauses().size(), queryNumber, explainerName, "# Clauses", datasetName);
StatsUtil.recordSize((long) explanations.size(), queryNumber, explainerName, "Explanations", datasetName); StatsUtil.recordSize((long) explanations.size(), queryNumber, explainerName, "Explanations", datasetName);
} else if (queryInInitialFB) { } else if (queryInInitialFB) {
...@@ -9,25 +9,28 @@ import fr.boreal.explanation.configuration.DefaultChaseForExplanations; ...@@ -9,25 +9,28 @@ import fr.boreal.explanation.configuration.DefaultChaseForExplanations;
import fr.boreal.explanation.configuration.StatsUtil; import fr.boreal.explanation.configuration.StatsUtil;
import fr.boreal.explanation.kb_gri.rule_transformation.GRIRuleTransformer; import fr.boreal.explanation.kb_gri.rule_transformation.GRIRuleTransformer;
import fr.boreal.explanation.kb_gri.rule_transformation.static_gri.RulesetForStaticGRIBuildingAndTracing; import fr.boreal.explanation.kb_gri.rule_transformation.static_gri.RulesetForStaticGRIBuildingAndTracing;
import fr.boreal.explanation.solving_enumerating.hybrid.HybridSAT4JMARCOSolver;
import fr.boreal.explanation.solving_enumerating.marco.MARCOGMUSSolver; import fr.boreal.explanation.solving_enumerating.marco.MARCOGMUSSolver;
import fr.boreal.explanation.solving_enumerating.sat4j.Sat4JSolver; import fr.boreal.explanation.solving_enumerating.sat4j.Sat4JSolver;
import fr.boreal.grd.api.GraphOfFORuleDependencies;
import fr.boreal.grd.impl.GRDImpl;
import fr.boreal.model.kb.api.KnowledgeBase; import fr.boreal.model.kb.api.KnowledgeBase;
import fr.boreal.model.kb.api.RuleBase;
import fr.boreal.model.kb.impl.KnowledgeBaseImpl; import fr.boreal.model.kb.impl.KnowledgeBaseImpl;
import fr.boreal.model.kb.impl.RuleBaseImpl;
import fr.boreal.model.logicalElements.api.Atom; import fr.boreal.model.logicalElements.api.Atom;
import fr.boreal.model.logicalElements.api.Predicate; import fr.boreal.model.logicalElements.api.Predicate;
import fr.boreal.model.logicalElements.impl.AtomImpl; import fr.boreal.model.logicalElements.impl.AtomImpl;
import fr.boreal.model.query.factory.FOQueryFactory;
import fr.boreal.unifier.QueryUnifier;
import fr.boreal.unifier.QueryUnifierAlgorithm;
import fr.boreal.views.FederatedFactBase; import fr.boreal.views.FederatedFactBase;
import org.apache.commons.lang3.NotImplementedException;
import java.util.Collection; import java.io.IOException;
import java.util.Iterator; import java.util.*;
import java.util.List;
import java.util.Set;
import static fr.boreal.explanation.configuration.PathFinder.ensureFilePath;
public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> implements AtomicQueryExplainer<ExplanationType> { public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> implements AtomicQueryExplainer<ExplanationType> {
...@@ -39,6 +42,13 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -39,6 +42,13 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
protected KnowledgeBase inputKB; protected KnowledgeBase inputKB;
private FederatedFactBase federatedFactBase; private FederatedFactBase federatedFactBase;
* Ancestor Rules
private static GraphOfFORuleDependencies grd;
private Set<FORule> queryAncestorRules = new HashSet<>();
* RuleTransforming * RuleTransforming
...@@ -49,10 +59,16 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -49,10 +59,16 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
* Static and dynamic knowledge bases * Static and dynamic knowledge bases
protected KnowledgeBase staticKB; protected KnowledgeBase staticKB;
protected KnowledgeBase dynamicKB; protected KnowledgeBase dynamicKB;
* Rule History
private List<RuleBase> staticRuleHistory = new ArrayList<>();
private List<RuleBase> dynamicRuleHistory = new ArrayList<>();
* Intermediate objects from the pipeline * Intermediate objects from the pipeline
...@@ -62,8 +78,10 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -62,8 +78,10 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
// preprocessing // preprocessing
java.util.function.Predicate<Atom> belongsToInitialFactbase; java.util.function.Predicate<Atom> belongsToInitialFactbase;
boolean queryEntailed = false; protected boolean queryEntailed = false;
boolean queryInInitialFB = false; protected boolean queryInInitialFB = false;
// memory of entailed queries
Set<Atom> entailedQueryCache = new HashSet<>();
// encoding // encoding
GSATEncodingResult_GRI encodingResult; GSATEncodingResult_GRI encodingResult;
...@@ -74,10 +92,13 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -74,10 +92,13 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
// marco // marco
MARCOGMUSSolver marcoSolver = new MARCOGMUSSolver(); MARCOGMUSSolver marcoSolver = new MARCOGMUSSolver();
File gcnffile = new File(ensureFilePath("integraal-explanation/gsat.gcnf", "gsat.gcnf"));
String tmpFileName = "gsat.gcnf";
File gcnffile = new File(tmpFileName);
// decoding // decoding
protected Set explanations; protected Set<ExplanationType> explanations;
protected Set<String> gmuses; protected Set<String> gmuses;
...@@ -108,14 +129,13 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -108,14 +129,13 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
* Dynamic step * Dynamic step
* @param query * @param query
public void dynamicStep(Atom query) { public void dynamicStep(Atom query) {
if (this.explanations != null) { if (this.explanations != null) {
dynamicStepClear(); dynamicStepClear();
checkQueryEntailment(query);
checkQueryInInitialFB(query); checkQueryInInitialFB(query);
if (queryEntailed & !queryInInitialFB) { if (queryEntailed & !queryInInitialFB) {
encodeClauses(query); encodeClauses(query);
if (solver instanceof MARCOGMUSSolver) { if (solver instanceof MARCOGMUSSolver) {
...@@ -125,6 +145,8 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -125,6 +145,8 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
} else if (solver instanceof Sat4JSolver) { } else if (solver instanceof Sat4JSolver) {
solveGMUSviaSat4j(); solveGMUSviaSat4j();
decodeGMUSesFromSat4j(); decodeGMUSesFromSat4j();
} else if (solver instanceof HybridSAT4JMARCOSolver) {
solveViaHybridSolver();
returnExplanationForQueryInFB(query); returnExplanationForQueryInFB(query);
...@@ -133,14 +155,10 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -133,14 +155,10 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
private void dynamicStepClear() { public void dynamicStepClear() {
explanations.clear(); explanations = new HashSet<>();
if (gmuses != null) { gmuses = new HashSet<>();
gmuses.clear(); sat4jGmuses = new ArrayList<>();
if (sat4jGmuses != null) {
sat4jGmuses.clear();
...@@ -152,9 +170,8 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -152,9 +170,8 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
StatsUtil.timerSumAllQueries(this::transformRules, explainerName, "Transforming rules", datasetName); StatsUtil.timerSumAllQueries(this::transformRules, explainerName, "Transforming rules", datasetName);
StatsUtil.timerSumAllQueries(this::prepareKBforGRI, explainerName, "Preparing KB for GRI", datasetName); StatsUtil.timerSumAllQueries(this::prepareKBforGRI, explainerName, "Preparing KB for GRI", datasetName);
StatsUtil.timerSumAllQueries(this::chaseKBforGRI, explainerName, "Chasing on staticKB for GRI", datasetName); StatsUtil.timerChasePerEachQuery(this::chaseKBforGRI, staticKB, explainerName, "Chasing on staticKB for GRI", datasetName);
StatsUtil.timerSumAllQueries(this::recordInitialFactbase, explainerName, "Recording initial factbase", datasetName); StatsUtil.timerSumAllQueries(this::recordInitialFactbase, explainerName, "Recording initial factbase", datasetName);
StatsUtil.timerSumAllQueries(this::prepareEncoding, explainerName, "Preparing Encoding", datasetName);
for (Atom query : queries) { for (Atom query : queries) {
...@@ -185,7 +202,7 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -185,7 +202,7 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
public void pipelineIn2StepsWithTimer (String datasetName, Collection<Atom> queries) { public void pipelineIn2StepsWithTimer(String datasetName, Collection<Atom> queries) {
String explainerName = this.getClass().getSimpleName() + " + " + this.solver.getClass().getSimpleName(); String explainerName = this.getClass().getSimpleName() + " + " + this.solver.getClass().getSimpleName();
StatsUtil.timerPerEachQuery(this::staticStep, explainerName, "Static Step", datasetName); StatsUtil.timerPerEachQuery(this::staticStep, explainerName, "Static Step", datasetName);
...@@ -198,9 +215,80 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -198,9 +215,80 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
@Override @Override
public void pipelineWithOrderedQuery(String datasetName, Collection<Atom> queries) { public void pipelineWithOrderedQuery(String datasetName, Collection<Atom> queries) {
throw new NotImplementedException(); String explainerName = this.getClass().getSimpleName() + " + " + this.solver.getClass().getSimpleName();
StatsUtil.timerWithOrderedQuery(this::transformRules, "Pre-first-query", explainerName, "Transforming rules", datasetName);
StatsUtil.timerWithOrderedQuery(this::prepareKBforGRI, "Pre-first-query", explainerName, "Preparing KB for GRI", datasetName);
StatsUtil.timerWithOrderedQuery(this::chaseKBforGRI, "Pre-first-query", explainerName, "Chasing on staticKB for GRI", datasetName);
StatsUtil.timerWithOrderedQuery(this::recordInitialFactbase, "Pre-first-query", explainerName, "Recording initial factbase", datasetName);
StatsUtil.timerWithOrderedQuery(this::buildingGRD, "Pre-first-query", explainerName, "Recording initial factbase", datasetName);
int queryIndex = 0;
queryIndex++;
String queryNumber = "Q" + queryIndex;
// String queryNumber = query.toString();
tmpFileName = datasetName + queryIndex + "_static_gsat.gcnf";
String prefix = datasetName + queryIndex + "_static_gsat_";
String suffix = ".gcnf";
// gcnffile = new File(tmpFileName);
File gcnffile = null;
try {
gcnffile = File.createTempFile(prefix, suffix);
} catch (IOException e) {
throw new RuntimeException(e);
gcnffile.deleteOnExit();
StatsUtil.recordSize((long) staticKB.getFactBase().size(), queryNumber, explainerName, "GRI size", datasetName);
StatsUtil.timerWithOrderedQuery(this::dynamicStepClear, queryNumber, explainerName,
"Clearing gmuses and explanations for the previous query",
datasetName);
StatsUtil.timerWithOrderedQuery(() -> checkQueryEntailment(query), queryNumber, explainerName, "Checking if query is entailed", datasetName);
StatsUtil.timerWithOrderedQuery(() -> checkQueryInInitialFB(query), queryNumber, explainerName, "Checking if query is already in input FB", datasetName);
if (queryEntailed && !queryInInitialFB) {
StatsUtil.timerWithOrderedQuery(this::clearAncestorRules, queryNumber, explainerName, "Clearing Ancestor Rules", datasetName);
StatsUtil.timerWithOrderedQuery(() -> computeAncestorRules(query), queryNumber, explainerName, "Computing Ancestor Rules for each query", datasetName);
staticRuleHistory.add(staticKB.getRuleBase());
StatsUtil.timerWithOrderedQuery(() -> prepareEncoding(), queryNumber, explainerName, "Prepare Encoding", datasetName);
StatsUtil.timerWithOrderedQuery(() -> encodeClauses(query), queryNumber, explainerName, "Encoding clauses", datasetName);
StatsUtil.timerWithOrderedQuery(this::writeMarcoGCNF, queryNumber, explainerName, "Writing GCNF", datasetName);
StatsUtil.timerMarcoOrderedQueries(this::solveGMUSviaMarco, queryNumber, explainerName, "Computing GMUSes via Marco", datasetName);
StatsUtil.timerWithOrderedQuery(this::decodeGMUSesFromMarco, queryNumber, explainerName, "Decoding GMUSes from Marco", datasetName);
StatsUtil.timerWithOrderedQuery(this::solveGMUSviaSat4j, queryNumber, explainerName, "Computing GMUSes with sat4j", datasetName);
StatsUtil.timerWithOrderedQuery(() -> returnExplanationForQueryInFB(query), queryNumber, explainerName, "Returning the explanation for query already in FB", datasetName);
} else {
returnEmptySetForExplanation();
// System.out.println("Static GRI Query Ancestor Rules: " + queryAncestorRules);
// System.out.println("query: " + query);
// System.out.println("Static GRI REL-tracing RB: " + dynamicRuleHistory);
* Saturates the GRI with Tracing rules to compute relevant bodyAtoms and triggers for the query. * Saturates the GRI with Tracing rules to compute relevant bodyAtoms and triggers for the query.
* Then calls the solver. * Then calls the solver.
...@@ -217,6 +305,38 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -217,6 +305,38 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
return explanations; return explanations;
* compute queryAncestorRules (a set of rules (nodes) on the subgraph of the Graph of Rule Dependency
* that contain all ancestor rules of rules that produce the query)
* @param rb rulebase
* @param a atom
* @return
static private Set<FORule> getAncestorRules(RuleBase rb, Atom a) {
Set<FORule> ancestorRules = new LinkedHashSet<>();
for (FORule rule : rb.getRulesByHeadPredicate(a.getPredicate())) {
QueryUnifierAlgorithm QUA = new QueryUnifierAlgorithm();
Collection<QueryUnifier> unifiers = QUA.getMostGeneralSinglePieceUnifiers(
FOQueryFactory.instance().createOrGetQuery(a, List.of()),
rule
if (!unifiers.isEmpty()) {
ancestorRules.addAll(grd.getAncestorRules(rule,ancestorRules));
return ancestorRules;
public void buildingGRD() {
grd = new GRDImpl(inputKB.getRuleBase(), List.of());
public void transformRules() { public void transformRules() {
this.transformedRB = ruleTransformer.createStaticGRIBuildingRB(inputKB); this.transformedRB = ruleTransformer.createStaticGRIBuildingRB(inputKB);
...@@ -237,11 +357,12 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -237,11 +357,12 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
Atom queryWithFuncId = GRIRuleTransformer.instance().createAtomWithStoredFnTermIdentifier(query); Atom queryWithFuncId = GRIRuleTransformer.instance().createAtomWithStoredFnTermIdentifier(query);
if (staticKB.getFactBase().contains(queryWithFuncId)) { if (staticKB.getFactBase().contains(queryWithFuncId)) {
queryEntailed = true; queryEntailed = true;
this.entailedQueryCache.add(query);
public void returnEmptySetForExplanation() { public void returnEmptySetForExplanation() {
explanations = Set.of(); explanations = new HashSet();
public void checkQueryInInitialFB(Atom query) { public void checkQueryInInitialFB(Atom query) {
...@@ -254,11 +375,14 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -254,11 +375,14 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
explanations = getGMUSProcessor(solver).getQueryIsInTheIntitialFactbaseExplanation(query); explanations = getGMUSProcessor(solver).getQueryIsInTheIntitialFactbaseExplanation(query);
public void clearAncestorRules() {
queryAncestorRules.clear();
public void computeAncestorRules(Atom query) {
queryAncestorRules.addAll(getAncestorRules(inputKB.getRuleBase(), query));
* Prepares a dynamic KB that can be used for tracing relevant atoms for the input query.
* The dynamic KB uses a federated factbase ; inferences will be put on the local storage, which can be eas
public void prepareEncoding() { public void prepareEncoding() {
SimpleInMemoryGraphStore encodingFB = new SimpleInMemoryGraphStore(); SimpleInMemoryGraphStore encodingFB = new SimpleInMemoryGraphStore();
...@@ -286,19 +410,19 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -286,19 +410,19 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
dynamicKB = new KnowledgeBaseImpl(encodingFB, transformedRB.getDynamicRuleBase()); dynamicKB = new KnowledgeBaseImpl(encodingFB, transformedRB.getDynamicRuleBase());
public void encodeClauses(Atom query) { public void encodeClauses(Atom query) {
encodingResult = getGMUSProcessor(solver).getEncoder().encode(dynamicKB, query, belongsToInitialFactbase); encodingResult = getGMUSProcessor(solver).getEncoder().encode(dynamicKB, query, belongsToInitialFactbase);
public void writeMarcoGCNF() { public void writeMarcoGCNF() {
marcoSolver.writeGCNF(encodingResult.propVarIDMap(), encodingResult.clauses(), encodingResult.nbGroup()); marcoSolver.writeGCNF(encodingResult.propVarIDMap(), encodingResult.clauses(), encodingResult.nbGroup(), gcnffile);
public void solveGMUSviaMarco() { public void solveGMUSviaMarco() {
gmuses = marcoSolver.getGMUSes(gcnffile); gmuses = marcoSolver.getGMUSes(gcnffile);
public void decodeGMUSesFromMarco() { public void decodeGMUSesFromMarco() {
explanations = getGMUSProcessor(solver).translateMARCOGMUS(gmuses, encodingResult.factIDMap(), encodingResult.ruleIDMap()); explanations = getGMUSProcessor(solver).translateMARCOGMUS(gmuses, encodingResult.factIDMap(), encodingResult.ruleIDMap());
...@@ -311,15 +435,67 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType> ...@@ -311,15 +435,67 @@ public abstract class AbstractStaticGRIBasedExplainer_Baseline<ExplanationType>
explanations = getGMUSProcessor(solver).translateSAT4JGMUS(sat4jGmuses, encodingResult.factIDMap(), encodingResult.ruleIDMap()); explanations = getGMUSProcessor(solver).translateSAT4JGMUS(sat4jGmuses, encodingResult.factIDMap(), encodingResult.ruleIDMap());
public void solveViaHybridSolver() {
var result = ((HybridSAT4JMARCOSolver) solver).solve(encodingResult);
switch (result.solver()) {
case MARCOGMUSSolver ignored -> {
explanations = getGMUSProcessor(solver).translateMARCOGMUS((Set<String>) result.solverResult(), encodingResult.factIDMap(), encodingResult.ruleIDMap());
case Sat4JSolver ignored ->
explanations = getGMUSProcessor(solver).translateSAT4JGMUS((List<List<List<Integer>>>) result.solverResult(), encodingResult.factIDMap(), encodingResult.ruleIDMap());
default -> throw new IllegalStateException("Unsupported solver");
abstract ExplanationProcessor_GRI getGMUSProcessor(Solver solver); abstract ExplanationProcessor_GRI getGMUSProcessor(Solver solver);
public boolean isQueryEntailed(Atom query){
throw new NotImplementedException(); public boolean isQueryEntailed(Atom query) {
if (this.entailedQueryCache.contains(query)) {
return true;
return true;
return false;
public boolean isQueryInInitialFB(Atom query) {
return this.belongsToInitialFactbase.test(query);
public Set<ExplanationType> getLastComputedExplanations() {
public boolean isQueryInInitialFB(Atom query){ public GSATEncodingResult_GRI getEncoding() {
throw new NotImplementedException(); return encodingResult;
public String getPrintableStatistics() {
StringBuilder result = new StringBuilder();
result.append("\n\nStatistics for : " + this.getClass().getSimpleName() + "\n");
result.append("GRInstance size " + this.staticKB.getFactBase().size() + "\n");
result.append("number of clauses " + this.encodingResult.clauses().size() + "\n");
result.append("number of explanations " + this.explanations.size() + "\n");
result.append("\n");
return result.toString();
public String getPrintableStatisticsXML() {
result.append("<statistics>\n");
result.append(" <component>").append(this.getClass().getSimpleName()).append("</component>\n");
result.append(" <grInstanceSize>").append(this.staticKB.getFactBase().size()).append("</grInstanceSize>\n");
result.append(" <numberOfClauses>").append(this.encodingResult.clauses().size()).append("</numberOfClauses>\n");
result.append(" <numberOfExplanations>").append(this.explanations.size()).append("</numberOfExplanations>\n");
result.append("</statistics>");
...@@ -6,6 +6,7 @@ import fr.boreal.explanation.configuration.StatsUtil; ...@@ -6,6 +6,7 @@ import fr.boreal.explanation.configuration.StatsUtil;
import fr.boreal.explanation.configuration.query_selection.QuerySelector; import fr.boreal.explanation.configuration.query_selection.QuerySelector;
import fr.boreal.explanation.kb_gri.explainers.incremental_gri.KBSupportExplainer_IncrementalKBGRI; import fr.boreal.explanation.kb_gri.explainers.incremental_gri.KBSupportExplainer_IncrementalKBGRI;
import fr.boreal.explanation.kb_gri.explainers.static_gri.KBSupportExplainer_KBGRI; import fr.boreal.explanation.kb_gri.explainers.static_gri.KBSupportExplainer_KBGRI;
import fr.boreal.explanation.kb_gri.explainers.static_gri_baseline.KBSupportExplainer_Baseline;
import fr.boreal.io.dlgp.DlgpWriter; import fr.boreal.io.dlgp.DlgpWriter;
...@@ -30,45 +31,49 @@ public class compareExplainers { ...@@ -30,45 +31,49 @@ public class compareExplainers {
// static String benchPath = "integraal-explanation/src/test/resources/mowl-bench-main/"; // static String benchPath = "integraal-explanation/src/test/resources/mowl-bench-main/";
public static List<String> datasets = List.of( public static List<String> datasets = List.of(
"warmup", // "warmup",
// "218a127c-8d13-40af-9957-63c28b0a091e_elontology", // "lubm001"
// "3cb9dec1-627b-496f-b49a-543dd1c77837_snoopy",
// "b80a039c-8975-4928-b45f-017126159882_sification",
// "98523b14-b04e-4af0-9597-15a297e226eb_taEncoding",
// "d09d7487-43dd-452a-976a-b69bc44d9b06_onOntology",
// "08cb4085-d900-4f82-8fa8-f523e382008d_ESG_test_1",
// "04c0af47-ff23-4761-8a4e-8fec2389f89f_ESG_test_2",
// "0b1f5620-f71d-4a01-8a16-d1818f69c187_ncbi_rank",
// "7b46d780-2032-46e3-ac89-90ab183e22aa_properties",
// "bb6535f4-d6a3-4197-a678-7f464e737862_properties",
// "4c3c8c62-d8f4-42c0-a96c-c994ece58345_catalogue",
// "734871d0-bf0d-47b3-bc19-b484567f5f4f_rmOntology",
// "93c3774c-58c0-4fa9-a592-539c130ee2d7_AlgorithmTypes",
// "f8a8e732-205b-4703-b568-2ce69e524055_instances",
// "f32019cc-43f3-49ce-b4f2-235f7db97132_oil",
// "8ee7a7f5-ad8c-4ac5-afbe-207e3ff285c8_HARMONISE",
// "ddd6d023-65dd-429a-a01f-2784c1d61f65_WNAffect",
// "2d09369e-392a-4ef2-a7c9-28334cbdc6f8_ddex",
// "dce07111-010a-450b-8c3a-2d55a8b48a21_LSCOM",
// "3b327e7f-0409-4f52-8e69-7062a62f7ba1_undin_area"
// "c669669d-7a04-410c-9474-1f6e46230556_BioLinks",
// "1dd81ef3-1e3e-4b2f-9bd0-230123497968_atOntology",
// "80bf8685-0e15-4780-8e61-7130e4e777c6_00Ontology",
// "ab726941-765f-4e5e-b6c9-2d51b652e841_00Ontology"
"lubm001"
// "lubm010" // "lubm010"
// "andersen_1000" "andersen_1000"
// "andersen_50 // "andersen_50
// 00" // 00"
// "andersen_50000" // "andersen_50000"
// "andersen_10000" // "andersen_10000"
// "andersen_100000" // "andersen_100000"
); // "dataset_1",
// "dataset_2",
// "dataset_3",
// "dataset_4",
// "dataset_5",
// "dataset_6",
// "dataset_7",
// "dataset_8",
// "dataset_9",
// "dataset_10",
// "dataset_11",
// "dataset_12",
// "dataset_13",
// "dataset_14",
// "dataset_15",
// "dataset_16",
// "dataset_17",
// "dataset_18",
// "dataset_19",
// "dataset_20",
// "dataset_21",
// "dataset_22",
// "dataset_23",
// "dataset_24",
// "dataset_25",
// "dataset_26",
// "dataset_27"
enum AtomicQueryExplainerType { enum AtomicQueryExplainerType {
// STATIC_GRI_FB_MARCO, // STATIC_GRI_FB_MARCO,
// STATIC_GRI_RB_MARCO, // STATIC_GRI_RB_MARCO,
// STATIC_GRI_KB_MARCO // STATIC_GRI_KB_MARCO,
// STATIC_GRI_KB_S4J, // STATIC_GRI_KB_S4J,
// STATIC_GRI_FB_S4J, // STATIC_GRI_FB_S4J,
// STATIC_GRI_RB_S4J, // STATIC_GRI_RB_S4J,
...@@ -78,8 +83,8 @@ public class compareExplainers { ...@@ -78,8 +83,8 @@ public class compareExplainers {
// TRACKER_GRI_FB_S4J, // TRACKER_GRI_FB_S4J,
// TRACKER_GRI_KB_S4J, // TRACKER_GRI_KB_S4J,
// TRACKER_GRI_RB_S4J, // TRACKER_GRI_RB_S4J,
INCREMENTAL_GRI_KB_MARCO // INCREMENTAL_GRI_KB_MARCO
// BASELINE_GRI_KB_MARCO BASELINE_GRI_KB_MARCO
// TRACKER_GRI_UNAMBIGUOUS_PROOF_TREE_WHY_PROVENANCE // TRACKER_GRI_UNAMBIGUOUS_PROOF_TREE_WHY_PROVENANCE
...@@ -99,15 +104,15 @@ public class compareExplainers { ...@@ -99,15 +104,15 @@ public class compareExplainers {
// case TRACKER_GRI_FB_S4J -> new FactSupportExplainer_TrackerGRI(kb, new Sat4JSolver()); // case TRACKER_GRI_FB_S4J -> new FactSupportExplainer_TrackerGRI(kb, new Sat4JSolver());
// case TRACKER_GRI_KB_S4J -> new KBSupportExplainer_TrackerGRI(kb, new Sat4JSolver()); // case TRACKER_GRI_KB_S4J -> new KBSupportExplainer_TrackerGRI(kb, new Sat4JSolver());
// case TRACKER_GRI_RB_S4J -> new RuleSupportExplainer_TrackerGRI(kb, new Sat4JSolver()); // case TRACKER_GRI_RB_S4J -> new RuleSupportExplainer_TrackerGRI(kb, new Sat4JSolver());
case INCREMENTAL_GRI_KB_MARCO -> new KBSupportExplainer_IncrementalKBGRI(kb); // case INCREMENTAL_GRI_KB_MARCO -> new KBSupportExplainer_IncrementalKBGRI(kb);
// case BASELINE_GRI_KB_MARCO -> new KBSupportExplainer_Baseline(kb); case BASELINE_GRI_KB_MARCO -> new KBSupportExplainer_Baseline(kb);
// case TRACKER_GRI_UNAMBIGUOUS_PROOF_TREE_WHY_PROVENANCE -> new UnambiguousProofTreeWhyProvenanceExplainer_TrackerGRI(kb); // case TRACKER_GRI_UNAMBIGUOUS_PROOF_TREE_WHY_PROVENANCE -> new UnambiguousProofTreeWhyProvenanceExplainer_TrackerGRI(kb);
public static void main(String[] args) throws IOException, InterruptedException { public static void main(String[] args) throws IOException, InterruptedException {
String strike = "10_4_queries"; String strike = "1";
if (args.length > 0) { if (args.length > 0) {
strike = args[0]; strike = args[0];
...@@ -167,8 +172,7 @@ public class compareExplainers { ...@@ -167,8 +172,7 @@ public class compareExplainers {
static Collection<Atom> loadQueryLubm(KnowledgeBase inputKB, String datasetName, Boolean record, int nbQueries, String strike) throws IOException { static Collection<Atom> loadQueryLubm(KnowledgeBase inputKB, String datasetName, Boolean record, int nbQueries, String strike) throws IOException {
Collection<Atom> queries = new ArrayList<>(); Collection<Atom> queries = new ArrayList<>();
// String strPath = benchPath + datasetName + "/"+datasetName + "_" + nbQueries + "_queries_strike_" + strike + ".dlgp"; // String strPath = benchPath + datasetName + "/"+datasetName + "_" + nbQueries + "_queries_strike_" + strike + ".dlgp";
// /home/akira/IdeaProjects/integraal/integraal/integraal-explanation/src/test/resources/ruleml24/lubm001/all_queries/output/ String strPath = "/home/akira/git/owlapi-comparison/data/lubm001/full/queries/complex_strikes/without_iri/strike1.dlgp";
String strPath = benchPath + datasetName + "/all_queries/output/query"+strike+".dlgp";
// System.out.println(strPath); // System.out.println(strPath);
File queryFile = new File(strPath); File queryFile = new File(strPath);
...@@ -199,12 +203,13 @@ public class compareExplainers { ...@@ -199,12 +203,13 @@ public class compareExplainers {
static Collection<Atom> loadQueryStrike(KnowledgeBase inputKB, String datasetName, Boolean record, int nbQueries, String strike) throws IOException { static Collection<Atom> loadQueryStrike(KnowledgeBase inputKB, String datasetName, Boolean record, int nbQueries, String strike) throws IOException {
String strPath = benchPath + datasetName + "/"+datasetName + "_" + nbQueries + "_queries_strike_" + strike + ".dlgp"; String strPath = benchPath + datasetName + "/"+datasetName + "_strike" + strike + ".dlgp";
System.out.println(strPath); System.out.println(strPath);
if (queryFile.exists()) { if (queryFile.exists()) {
System.out.println("yes");
queries = InternalDLGPParser.ParserForDLGP.parseQueries(queryFile); queries = InternalDLGPParser.ParserForDLGP.parseQueries(queryFile);
} else { } else {
queries = QuerySelector.selectQueries(inputKB, nbQueries); queries = QuerySelector.selectQueries(inputKB, nbQueries);
...@@ -134,7 +134,7 @@ public class MARCOGMUSSolver implements Solver { ...@@ -134,7 +134,7 @@ public class MARCOGMUSSolver implements Solver {
try { try {
while ((line = in.readLine()) != null) { while ((line = in.readLine()) != null) {
System.out.println(line); // System.out.println(line);
if (line.startsWith("Traceback (most recent call last)")) { if (line.startsWith("Traceback (most recent call last)")) {
System.out.println("Locally installed MARCO had an execution error. Trying to see if the docker-image is active. \n"); System.out.println("Locally installed MARCO had an execution error. Trying to see if the docker-image is active. \n");
...@@ -142,13 +142,13 @@ public class MARCOGMUSSolver implements Solver { ...@@ -142,13 +142,13 @@ public class MARCOGMUSSolver implements Solver {
if (line.startsWith("U")) { if (line.startsWith("U")) {
gmuses.add(line.split("U ")[1]); gmuses.add(line.split("U ")[1]);
} else { } else {
if (line.startsWith("S")) { if (line.startsWith("S")) {
// satisfiable set // satisfiable set
} else { } else {
System.err.println(line); System.out.println(line);
