GitLab
Explore
Primary navigation
Search or go to…
Q
Querybuilder
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
pydisk
Querybuilder
47eb7183
47eb7183
1 year ago
Bruno Guillon
Downloads
Merge branch 'master' into features/helpers
parents
46988c56
4d940d36
Branches containing commit
Pipeline
#999835
failed
1 year ago
Stage: build
Stage: test
2
2 changed files
.gitlab-ci.yml
+1
1 addition, 0 deletions
.gitlab-ci.yml
querybuilder/helpers/schema.py
+19
-17
19 additions, 17 deletions
20 additions
17 deletions
.gitlab-ci.yml
47eb7183
@@ -32,6 +32,7 @@ type-checking:
medium
medium
$CI_REGISTRY_IMAGE/qbcontainer"
script
script
find -name '__pycache__' -type d -exec rm {} +
python3 -m mypy --install-types --non-interactive querybuilder/
test
test
This diff is collapsed.
19
17
47eb7183
@@ -320,25 +320,26 @@ class Field:
def
to_named_column
def
to_named_column
self
NamedColumn
ColumnSpec
self
NamedColumn
ColumnSpec
relation_name
Optional
str
None
relation_name
str
None
_MISSING_TYPE
MISSING
schema_name
Optional
str
None
schema_name
str
None
_MISSING_TYPE
MISSING
NamedColumn
NamedColumn
assert
self
name
assert
self
name
assert
self
sqltype
assert
self
sqltype
assert
if
relation_name
is
MISSING
not
self
relation_name
relation_name
self
relation_name
not
relation_name
elif
relation_name
is
None
self
relation_name
relation_name
schema_name
None
relation_name
cast
Optional
str
relation_name
assert
if
schema_name
is
MISSING
not
self
schema_name
not
schema_name
self
schema_name
schema_name
schema_name
self
schema_name
schema_name
cast
Optional
str
schema_name
return
NamedColumn
if
relation_name
self
sqltype
assert
not
self
relation_name
self
relation_name
relation_name
self
name
if
schema_name
self
relation_name
relation_name
assert
relation_name
self
schema_name
schema_name
assert
not
self
schema_name
self
schema_name
schema_name
return
NamedColumn
self
sqltype
self
name
relation_name
schema_name
@classmethod
@classmethod
def
_resolve_str_spec
def
_resolve_str_spec
@@ -506,7 +507,7 @@ class Field:
Optional
qb
atoms
constraints
ColumnCheck
Optional
qb
atoms
constraints
ColumnCheck
check
Optional
str
Column
qb
atoms
constraints
ColumnCheck
tuple
dict
check
Optional
str
Column
qb
atoms
constraints
ColumnCheck
tuple
dict
if
callable
self
check
if
callable
self
check
check
self
check
self
to_named_column
relation
check
self
check
self
to_named_column
relation
_name
None
rel
else
else
check
self
check
check
self
check
if
check
is
None
if
check
is
None
@@ -540,6 +541,7 @@ class Field:
qb
atoms
constraints
ColumnDefault
qb
atoms
constraints
ColumnDefault
if
callable
self
default
if
callable
self
default
# TODO: when is a callable default useful?
default
self
default
self
to_named_column
default
self
default
self
to_named_column
else
else
default
self
default
default
self
default
Loading
Save comment
