GitLab
Explore
Primary navigation
Search or go to…
cadbiom
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
VIGNET Pierre
cadbiom
cf11e848
cf11e848
6 years ago
VIGNET Pierre
Downloads
Patches
Remove redondant and hard to maintain documentation from README
b54e4e2c
strasbourg_vlan
README.md
+5
-144
5 additions, 144 deletions
README.md
5 additions
144 deletions
README.md
5
144
cf11e848
@@ -197,152 +197,13 @@ The gui package exposes the command `cadbiom` to the current context.
# Use
# Use
## Command line
## Command line
& API
### General:
For up-to-date help on how to use the various commands, please visit this page:
link
http://cadbiom.genouest.org/doc/cadbiom/command_line_usage.html
$ cadbiom_cmd -h
For up-to-date help on how to use the various APIs, please visit this page:
link
http://cadbiom.genouest.org/doc/cadbiom/command_line_doc.html
usage: cadbiom_cmd [-h] [-vv [VERBOSE]]
{compute_macs,sort_solutions,parse_trajectories,merge_cams}
optional arguments:
-h, --help show this help message and exit
-vv [VERBOSE], --verbose [VERBOSE]
subcommands:
compute_macs Parse arguments and launch Cadbiom search of MACs
(Minimal Activation Conditions). - If there is no
input file, there will be only one process. - If an
input file is given, there will be 1 process per line
(per logical formula on each line). - all_macs: Solver
will try to search all macs with 0 to the maximum of
steps allowed. - continue: If there is a mac file from
a previous work, last frontier places will be
reloaded.
sort_solutions Parse a solution file and sort all frontier places in
alphabetical order.
parse_trajectories Parse a complete solution file and make a
representation of trajectories.
The output is in graphml file format and is exported
in 'graphs' directory. .. note:: Requires the
model file.
merge_cams Merge solutions to a csv file. .. note:: CSV file:
<Final property formula>;<cam>
model_comp Model consistency checking. Check if the 2 given
models have the same topology, nodes & edges
attributes/roles. .. note:: You can export a graphml
file for the 2 models.
model_infos Model informations. Get number of nodes, edges,
centralities (degree, closeness, betweenness). ..
note:: You can export a graphml file for model.
### compute_macs:
usage: cadbiom_cmd compute_macs [-h] [--input_file [INPUT_FILE]]
[--combinations] [--steps [STEPS]]
[--all_macs] [--continue]
[--start_prop [START_PROP]]
[--inv_prop [INV_PROP]] [--output [OUTPUT]]
chart_file [final_prop]
positional arguments:
chart_file
final_prop
optional arguments:
--combinations
--steps [STEPS]
--all_macs
--continue
--output [OUTPUT]
### parse_trajectories:
usage: cadbiom_cmd parse_trajectories [-h] chart_file sol_file
chart_file
sol_file
<br>
Result:
examples/graph_example_with_legend.png
Cytoscape styles:
file
examples/cytoscape_styles.xml
### sort_solutions:
usage: cadbiom_cmd sort_solutions [-h] sol_file
sol_file
### merge_cams:
usage: cadbiom_cmd merge_cams [-h] [--output [OUTPUT]] [solutions_directory]
solutions_directory
### model_comp:
usage: cadbiom_cmd model_comp [-h] [--make_graphs] model_file_1 model_file_2
model_file_1
model_file_2
optional arguments:
--graphs
--json
--output [OUTPUT]
<br>
Usage in scripts:
>>> from cadbiom_cmd.solution_repr import graph_isomorph_test
>>> print(graph_isomorph_test('test.bcx', 'test2.bcx', output_dir='graphs/',
make_graphs=False, make_json=False))
INFO: 3 transitions loaded
INFO: BUILD GRAPH FOR SOL: Connexin_32_0 Connexin_26_0
INFO: Topology checking: True
INFO: Nodes checking: True
INFO: Edges checking: True
{u'nodes': True, u'edges': True, u'topology': True}
### model_infos
usage: cadbiom_cmd model_infos [-h] [--graph] [--json] [--output [OUTPUT]]
model_file
model_file
optional arguments:
--graph
--json
--output [OUTPUT]
## Graphical User Interface
This diff is collapsed.
Loading
Save comment
