GitLab
Explore
Primary navigation
Search or go to…
cadbiom
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
VIGNET Pierre
cadbiom
c4fe5c6a
c4fe5c6a
5 years ago
VIGNET Pierre
Downloads
Patches
[lib] Delete useless file
e06268ea
library/cadbiom/models/guard_transitions/translators/tests/res.xml
+0
-128
0 additions, 128 deletions
...adbiom/models/guard_transitions/translators/tests/res.xml
0 additions
128 deletions
deleted
100644 → 0
e06268ea
;; This buffer is for notes you don't want to save, and for Lisp evaluation.
;; If you want to create a file, visit that file with C-x C-f,
;; then enter the text in that file's own buffer.
<Interaction interaction_type="modification" id="210000">
<ReferenceList>
<Reference pmid="11551930">11551930</Reference>
</ReferenceList>
<InteractionComponentList>
<InteractionComponent role_type="input" molecule_idref="201131">
</InteractionComponent>
<InteractionComponent role_type="agent" molecule_idref="007">
<Label label_type="activity-state" value="active" />
<PTMExpression>
<PTMTerm protein="Q9H4B4" position="0" aa="X" modification="phosphorylation" />
</PTMExpression>
<InteractionComponent role_type="output" molecule_idref="201131">
<PTMExpression>
<PTMTerm protein="P04637" position="20" aa="S" modification="phosphorylation" />
</PTMExpression>
</InteractionComponentList>
</Interaction>
<Interaction interaction_type="modification" id="210183">
<InteractionComponent role_type="input" molecule_idref="200988">
<PTMExpression>
</PTMExpression>
<InteractionComponent role_type="input" molecule_idref="201885">
<Label label_type="location" value="cytoplasm" />
<InteractionComponent role_type="agent" molecule_idref="200988">
<InteractionComponent role_type="output" molecule_idref="201885">
<PTMExpression>
<PTMTerm protein="P30307" position="191" aa="S" modification="phosphorylation" />
</PTMExpression>
<PTMExpression>
</PTMExpression>
</Interaction>
<Interaction interaction_type="modification" id="210188">
<ReferenceList>
<Reference pmid="12242661">12242661</Reference>
</ReferenceList>
<InteractionComponent role_type="agent" molecule_idref="202443">
<InteractionComponent role_type="output" molecule_idref="200988">
<PTMExpression>
</PTMExpression>
</Interaction>
<Interaction interaction_type="translocation" id="210184">
<ReferenceList>
<Reference pmid="14968113">14968113</Reference>
</ReferenceList>
<PTMExpression>
</PTMExpression>
<Label label_type="location" value="nucleus" />
<PTMExpression>
</PTMExpression>
</Interaction>
<Interaction interaction_type="transcription" id="210182">
<ReferenceList>
<Reference pmid="17264206">17264206</Reference>
</ReferenceList>
<InteractionComponent role_type="output" molecule_idref="200673">
</Interaction>
\ No newline at end of file
This diff is collapsed.
Loading
Save comment
