GitLab
Explore
Primary navigation
Search or go to…
cadbiom
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
VIGNET Pierre
cadbiom
b2c20ecd
b2c20ecd
5 years ago
VIGNET Pierre
Downloads
Patches
[lib] Add few todos.. sorry
477ef5c0
Branches containing commit
Tags containing commit
library/cadbiom/models/clause_constraints/mcl/CLUnfolder.py
+12
12 additions, 0 deletions
12 additions
12
b2c20ecd
@@ -74,6 +74,8 @@ About shifting clauses and variables:
to the right or to the left depending on whether their values are positive
or negative.
*constraints attributes are shifted at every step and submitted to the solver.
init_with_query(query):
@@ -1291,12 +1293,15 @@ class CLUnfolder(object):
self
__aux_list
# idem
# Init properties to generate all variable num codes
## Similar code with init_backward_unfolding, move this into a function
## => could help to recall init state of a query
self
__init_initial_constraint_0
self
__init_final_constraint_0
self
__init_invariant_constraint_0
self
__init_variant_constraints_0
# Now shifting is possible
## TODO: check shift_direction too (not urgent, backward is not usable)
if
old_shift_step
self
__shift_step
self
__include_aux_clauses_changed
not
self
__dynamic_constraints
@@ -1307,6 +1312,7 @@ class CLUnfolder(object):
self
__forward_init_dynamic
self
__precomputed_dynamic_constraints
else
# Optimization for __dynamic_constraints
# Main settings of the unfolder haven't changed and the system
# was initialized before.
LOGGER
info
init_forward_unfolding:: Reload dynamic constraints
@@ -1346,6 +1352,12 @@ class CLUnfolder(object):
.. note:: Called by:
- __constraints_satisfied()
- __msolve_constraints()
.. todo::
Avoid to reload the solver everytime just for a few changed variables.
Ex: __initial_constraints is changed only because of
__initial_property and __dimacs_initial changes.
Ex: __dynamic_constraints is huge and stays the same.
# New API via C++ module
solv
add_clauses
self
__final_constraints
This diff is collapsed.
Loading
Save comment
