GitLab
Explore
Primary navigation
Search or go to…
cadbiom
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
VIGNET Pierre
cadbiom
a142eaf4
a142eaf4
5 years ago
VIGNET Pierre
Downloads
Patches
[lib] Reformat MCLQuery
95d1cfd8
library/cadbiom/models/clause_constraints/mcl/MCLQuery.py
+26
-13
26 additions, 13 deletions
26 additions
13 deletions
26
13
a142eaf4
@@ -48,6 +48,7 @@ from logging import DEBUG
LOGGER
cm
logger
LOGGER
cm
logger
class
MCLSimpleQuery
object
class
MCLSimpleQuery
object
Class packaging the elements of a query
@@ -83,6 +84,7 @@ class MCLSimpleQuery(object):
NB: DClause: A clause coded as a list of DIMACS coded literals: <list <int>>
def
__init__
self
start_prop
inv_prop
final_prop
def
__init__
self
start_prop
inv_prop
final_prop
@param start_prop: init property - None is allowed
@@ -90,10 +92,14 @@ class MCLSimpleQuery(object):
@param final_prop: final property - None is allowed
if
LOGGER
getEffectiveLevel
DEBUG
if
LOGGER
getEffectiveLevel
DEBUG
LOGGER
debug
MCLSimpleQuery params:: start prop:
LOGGER
debug
str
start_prop
; inv prop:
str
inv_prop
; final prop:
str
start_prop
str
final_prop
; inv prop:
str
inv_prop
; final prop:
str
final_prop
# Strings forms of constraints
self
start_prop
start_prop
# logical formula or None
self
start_prop
start_prop
self
inv_prop
inv_prop
self
inv_prop
inv_prop
@@ -144,7 +150,9 @@ class MCLSimpleQuery(object):
# - Get events names in each step
# (remove the leading "%" and split the string on spaces)
# - join events names with a logical operator " and "
var_prop
join
raw_step
split
for
raw_step
in
f_sol
ic_sequence
var_prop
join
raw_step
split
for
raw_step
in
f_sol
ic_sequence
# PS: var_prop and any attribute can be [], but keep this for uniformity
if
not
var_prop
if
not
var_prop
var_prop
None
var_prop
None
@@ -153,7 +161,6 @@ class MCLSimpleQuery(object):
n_query
variant_prop
var_prop
n_query
variant_prop
var_prop
return
n_query
return
n_query
@classmethod
@classmethod
def
from_frontier_sol_new_timing
cls
f_sol
unfolder
def
cls
f_sol
unfolder
Build a query from a frontier solution
@@ -190,8 +197,10 @@ class MCLSimpleQuery(object):
# - negation of each event with "not ( event )"
# - join events names with a logical operator " or "
var_prop
join
not (
icp
for
icp
in
raw_step
split
var_prop
for
raw_step
in
f_sol
ic_sequence
join
not (
icp
for
icp
in
raw_step
split
for
raw_step
in
f_sol
ic_sequence
if
not
var_prop
if
not
var_prop
var_prop
None
var_prop
None
@@ -201,8 +210,9 @@ class MCLSimpleQuery(object):
# and force their inactivation with a negative value.
## dim_start doit-il etre ordonné ?
# 1 - Get negative values of activated frontiers in FrontierSolution object
activated_frontier_neg_values
unfolder
var_dimacs_code
name
for
name
in
f_sol
activated_frontier
unfolder
var_dimacs_code
name
for
name
in
f_sol
activated_frontier
# 2 - Get values of inactivated frontiers in the FrontSolution object
dim_start_values
dim_start_values
@@ -250,7 +260,9 @@ class MCLSimpleQuery(object):
var_prop
join
raw_step
split
for
raw_step
in
f_sol
ic_sequence
var_prop
join
raw_step
split
for
raw_step
in
f_sol
ic_sequence
if
not
var_prop
if
not
var_prop
var_prop
None
var_prop
None
@@ -259,8 +271,9 @@ class MCLSimpleQuery(object):
# Search all frontiers that are not in activated_frontier
# Get negative values of activated frontiers in FrontierSolution object
unfolder
var_dimacs_code
name
for
name
in
f_sol
activated_frontier
unfolder
var_dimacs_code
name
for
name
in
f_sol
activated_frontier
# Get list of values of inactivated frontiers in the FrontSolution object
dim_start_values
dim_start_values
This diff is collapsed.
Loading
Save comment
