Commit 546df638 authored by VIGNET Pierre's avatar VIGNET Pierre
[lib] CLUnfolder: Fix typos
parent 52075e7c
......@@ -217,10 +217,11 @@ class CLUnfolder(object):
self.dynamic_system = dynamic_system # symbolic clause dynamic system
# shift_step equals to the total number of coded variables
# shift_step equals to the total number of coded variables of the system
# (including inputs, entities, clocks/events, auxiliary variables)
# shift_step_init: the shift step ss (if n is X_0 code, n+ss is X_1 code)
self.shift_step_init = dynamic_system.get_var_number() # shift step of system (number of variables of the system)
self.__shift_step = self.shift_step_init # current shift/step
# About unfolder lock and shift_step:
......@@ -1225,7 +1226,7 @@ class CLUnfolder(object):
code them into DIMACS clauses constraints (__code_clause()).
__code_clause() is susceptible to add new auxiliary numeric variables
during this process if a variable is not found in __var_code_table or
during this process if a variable is not found in __var_code_table and in
__aux_code_table.
- __init_initial_constraint_0, __init_final_constraint_0, __init_invariant_constraint_0
