GitLab
Explore
Primary navigation
Search or go to…
cadbiom
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
VIGNET Pierre
cadbiom
21acce7d
21acce7d
5 years ago
VIGNET Pierre
Downloads
Patches
[cmd][lib] switch get_shift_direction to a proper property
6a2489a1
2
2 changed files
library/cadbiom/models/clause_constraints/mcl/CLUnfolder.py
+2
-1
2 additions, 1 deletion
library/cadbiom/models/clause_constraints/mcl/MCLSolutions.py
+1
-1
1 addition, 1 deletion
...ary/cadbiom/models/clause_constraints/mcl/MCLSolutions.py
3 additions
2 deletions
2
21acce7d
@@ -576,7 +576,8 @@ class CLUnfolder(object):
Get the DIMACS codes of the input variables
return
self
__inputs
def
get_shift_direction
self
@property
def
shift_direction
self
@return: string
FORWARD
BACKWARD
This diff is collapsed.
21acce7d
@@ -135,7 +135,7 @@ class RawSolution(object):
self
unfolder
unfolder
self
shift_step
unfolder
shift_step
self
current_step
unfolder
current_step
self
shift_direction
unfolder
get_
shift_direction
self
shift_direction
unfolder
shift_direction
def
get_unshift_code
self
var_num
Get the real value of the given variable in the system (remove the shift)
Loading
Save comment
