Commit 1d2b9ec5 authored by VIGNET Pierre's avatar VIGNET Pierre
[cmd][lib] Bump new versions
parent b7e64b49
...@@ -31,7 +31,7 @@ from setuptools import setup, find_packages ...@@ -31,7 +31,7 @@ from setuptools import setup, find_packages
from setuptools.command.test import test as TestCommand from setuptools.command.test import test as TestCommand
from sys import version_info from sys import version_info
__PACKAGE_VERSION__ = "1.0.0" __PACKAGE_VERSION__ = "1.0.1"
deps = [] deps = []
...@@ -35,7 +35,7 @@ from distutils import sysconfig ...@@ -35,7 +35,7 @@ from distutils import sysconfig
from setuptools import setup, Extension, find_packages from setuptools import setup, Extension, find_packages
__PACKAGE_VERSION__ = "0.2.0" __PACKAGE_VERSION__ = "0.2.1"
__LIBRARY_VERSION__ = "1.0.0" __LIBRARY_VERSION__ = "1.0.0"
