Commit 1d9795ae authored by Florian Maurin's avatar Florian Maurin
Avoiding to interpolate several times the same point for Bezier surface
In vtkDataSetSurfaceFilter, nonlinear elements are triangulated.
For Bezier element, interpolation was performed for each corner of each triangle.
Since a triangle corner is often shared with other triangle corners, we are doing unnecessary interpolations.
The fix use the PointMap to check if a point has been already treated or not.
parent 9f94c2e7
Loading
Loading
