GitLab
Explore
Primary navigation
Search or go to…
E
extras
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
The Openvibe Group
extras
Compare revisions
master to 221-enhance-testing
Compare revisions
Changes are shown as if the
source
revision was being merged into the
target
revision.
Learn more about comparing revisions.
Source
openvibe/extras
Select target project
No results found
221-enhance-testing
Select Git revision
106-update-classifier-s-architecture
110-power-spectrum
111-arcoeffs-update
12-expand-use-of-ctime
151-deploy-sonarqube
153-test-confusion-matrix-test
203-ci-ubuntu-20-tests-broken
207-update-keyboard-stimulator-always-detect-key-press
217-feature-add-accumulate-option-in-box-matrix3dto2d
217-feature-add-accumulate-option-in-box-matrix3dto2d-2
217-feature-add-accumulate-option-in-box-matrix3dto2d-3
221-enhance-testing
223-update-remove-useless-dependencies
223-update-remove-useless-dependencies-2
227-feature-add-asymmetry-index-metabox
234-add-generic-saw-tooth-driver-2
255-fix-share-folder-for-acquisition-server
259-add-mbraintrain-driver
261-add-brain-product-amplifier-driver
261-add-brain-product-amplifier-driver-2
262-add-biosemi-activetwo-driver
267-ui-numbers-displayed-in-scientific-format
270-float-param-increment
272-enhance-parameter-names-in-ui
278-update-connectivity-box
279-replace-subdirs-deprecated-in-test
64-update-box-connectivity-measure_MERGE
70-update-matrix3dto2d-allow-for-range-of-values
71-feature-graph-laplacian-box
71-feature-graph-laplacian-box-2
74-box-brainhero-game-box
76-feature-erd-detection
82-feature-box-z-score
Cmake-configuration-updates
CorrectReturnCode
CorrectTCPWriterHeader
DisplayCue
GDFReaderImprovement
LinuxCompilation
OpenGLFix
PhD_ICM_dev
SimpleBug
add-scenario-configuration
add-scenario-io
debugQMLSignalDispaly
development
gtk3
icm/experimental-box-welchPSD
icm/feat-matrix-average-box
master
module-xml-remove
ov-361-fnirs
papadop-fedora-changes
phd_save_feb22
qt-acq-server
qt6
validate-tests
wip-contrib-muse-reader
wip-current-change
wip-feature-crio-core-1347
wip-feature-crio-identifiers
wip-jlindgre-fix-lslexportgipsa-stims
wip-jlindgre-fix-mbt-smarting
wip-jlindgre-lsl-timestamps
wip-jlindgre-tracker
wip-jlindgre-unsupervised-p300
wip-jlindgre-vrpn-serverport
wip-remove-module-xml
wip-tmonseigne-driver-bitalino-gtelo
0.10.0
0.11.0
0.12.0
0.13.0
0.14.0
0.15.0
0.16.0
0.17.0
0.17.1
0.18.0
0.2.0
0.3.0
0.4.0
0.5.0
0.6.0
0.7.0
0.8.0
0.9.0
1.0.0
1.0.1
1.1.0
1.2.0
1.2.1
1.2.2
1.3.0
2.0.0
2.0.1
2.1.0
2.2.0
3.0.0
3.0.0-beta
3.1.0
3.2.0
3.3.0
3.3.1
3.6.0
106 results
Swap
Target
openvibe/extras
openvibe/extras
papadop/extras
adesbois/extras
fleray/extras
4 results
master
Select Git revision
110-power-spectrum
111-arcoeffs-update
221-enhance-testing
CorrectReturnCode
DisplayCue
LinuxCompilation
OpenGLFix
PhD_ICM_dev
SimpleBug
add-scenario-io
development
gtk3
master
module-xml-remove
ov-361-fnirs
phd_save_feb22
qt-acq-server
qt6
validate-tests
wip-current-change
0.10.0
0.11.0
0.12.0
0.13.0
0.14.0
0.15.0
0.16.0
0.17.0
0.17.1
0.18.0
0.2.0
0.3.0
0.4.0
0.5.0
0.6.0
0.7.0
0.8.0
0.9.0
1.0.0
1.0.1
1.1.0
1.2.0
1.2.1
1.2.2
1.3.0
2.0.0
2.0.1
2.1.0
2.2.0
3.0.0
3.0.0-beta
3.1.0
3.2.0
3.3.0
3.3.1
3.6.0
106 results
Show changes
Only incoming changes from source
Include changes to target since source was created
Commits on Source (1)
Add test on ERROR inside testing
· bd03677e
laurent-garnier
1 year ago
bd03677e
test/CTestTestfile.cmake
+3
-1
3 additions, 1 deletion
3 additions
1 deletion
bd03677e
@@ -43,7 +43,9 @@ function(validation_test TEST_PATH TEST_NAME COMPARE OUTPUT_EXT USE_THRESHOLD TH
endif
COMPARE
endif
COMPARE
add_test
run_
TEST_NAME
"$ENV{OV_BINARY_PATH}/openvibe-designer.
EXT
OS_FLAGS
"--no-session-management"
"--invisible"
"--play-fast"
TEST_FILE
-test.xml"
add_test
run_
TEST_NAME
EXT
OS_FLAGS
"--invisible"
"--play-fast"
TEST_FILE
-test.xml"
set
failRegex
[ *ERROR *
set_tests_properties
TEST run_
TEST_NAME
DIRECTORY
TEST_PATH
PROPERTIES FAIL_REGULAR_EXPRESSION
failRegex
if
COMPARE
if
COMPARE
if
USE_THRESHOLD
if
USE_THRESHOLD
add_test
compare_
TEST_NAME
"$ENV{OV_BINARY_PATH}/threshold-comparison.
EXT
OS_FLAGS
TEST_FILE
-output.
OUTPUT_EXT
TEST_FILE
-ref.
OUTPUT_EXT
THRESHOLD_VALUE
add_test
compare_
TEST_NAME
EXT
OS_FLAGS
TEST_FILE
-output.
OUTPUT_EXT
TEST_FILE
-ref.
OUTPUT_EXT
THRESHOLD_VALUE
This diff is collapsed.
