GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
The Openvibe Group
extras
945c04af
945c04af
Jussi Lindgren
Build: gusbamp Linux API can now be found by the cmake find script
535dc7ae
cmake-modules/FindThirdPartyGUSBampCAPI.cmake
945c04af
@@ -38,3 +38,21 @@ IF(WIN32)
MESSAGE
STATUS
" FAILED to find gUSBampCAPI"
MESSAGE
STATUS
ENDIF
PATH_GUSBampCAPI
ENDIF
PATH_GUSBampCAPI
ENDIF
WIN32
ENDIF
WIN32
IF
UNIX
# To try other versions of the gtec's library, change the number below
SET
CMAKE_FIND_LIBRARY_SUFFIXES
".so.1.14"
FIND_LIBRARY
gUSBAmpLinux_LIBRARY NAMES
"gusbampapi"
PATHS
"/usr/lib"
"/usr/local/lib"
IF
MESSAGE
STATUS
" Found GUSBAmpAPILinux..."
MESSAGE
STATUS
" [ OK ] Third party lib
ADD_DEFINITIONS
-DTARGET_HAS_ThirdPartyGUSBampCAPI_Linux
TARGET_LINK_LIBRARIES
PROJECT_NAME
ELSE
MESSAGE
STATUS
" FAILED to find GUSBAmpAPI Linux... "
MESSAGE
STATUS
" : If it should be found, see that 'libgusbampapi.so.1.14' link exists on the fs, with no further nemeric suffixes in the filename."
MESSAGE
STATUS
" : e.g. do 'cd /usr/lib/ ; ln -s libgusbampapi.so.1.14'. See gtec-bcilab/README for details."
ENDIF
SET
OV_ThirdPartyGUSBAmp
"YES"
ENDIF
UNIX
