Commit 9721397c authored by thierry's avatar thierry
Add display task count
parent 2f5ce3b7
...@@ -47,7 +47,9 @@ work_analysis<- function( df_parallel, df_task ) ...@@ -47,7 +47,9 @@ work_analysis<- function( df_parallel, df_task )
df <- df_task %>% filter( (Start>= df_parallel$Start[i]) & (End <= df_parallel$End[i]) ); df <- df_task %>% filter( (Start>= df_parallel$Start[i]) & (End <= df_parallel$End[i]) );
s <- sum(df$Duration); s <- sum(df$Duration);
taskcount <- nrow( df);
cat("Region parallel id",i," on ",p," thread(s)\n"); cat("Region parallel id",i," on ",p," thread(s)\n");
cat(" taskcount : ",taskcount, "\n");
cat(" duration : ",df_parallel$Duration[i], "\n"); cat(" duration : ",df_parallel$Duration[i], "\n");
cat(" work : ",s, "\n"); cat(" work : ",s, "\n");
cat(" efficiency : ",s/df_parallel$Duration[i]/p, "\n"); cat(" efficiency : ",s/df_parallel$Duration[i]/p, "\n");
