- Downloads
Improve performance of #pragma omp single
EPCC Performance of single is considerably worse than plain barrier. Adding a read-only check to the code before the atomic compare-and-store helps considerably. Patch by Terry Wilmarth. Differential Revision: http://reviews.llvm.org/D21893 git-svn-id: https://llvm.org/svn/llvm-project/openmp/trunk@274369 91177308-0d34-0410-b5e6-96231b3b80d8
Loading
