- Downloads
Merging rr285370:
------------------------------------------------------------------------ r285370 | rtrieu | 2016-10-27 17:15:24 -0700 (Thu, 27 Oct 2016) | 10 lines Fix a crash on invalid code. The diagnostic was attempting to access the QualType of a TypeDecl by calling TypeDecl::getTypeForDecl. However, the Type pointer stored there is lazily loaded by functions in ASTContext. In most cases, the pointer is loaded and this does not cause a problem. However, when more that 50 or so unknown types are seen beforehand, this causes the Type to not be loaded, passing a null Type to the diagnostics, leading to the crash. Using ASTContext::getTypeDeclType will give a proper QualType for all cases. ------------------------------------------------------------------------ git-svn-id: https://llvm.org/svn/llvm-project/cfe/branches/release_39@286923 91177308-0d34-0410-b5e6-96231b3b80d8
Loading
