GitLab
Explore
Primary navigation
Search or go to…
A
algpath
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
Numerical algebraic geometry
algpath
e04330de
e04330de
10 months ago
GUILLEMOT Alexandre
Downloads
Patches
track tests macro
0c238ebc
tests/track.rs
+44
-1
44 additions, 1 deletion
tests/track.rs
44 additions
1 deletion
tests/track.rs
44
e04330de
@@ -3,7 +3,6 @@
use
std
path
PathBuf
#[test]
fn
track
let
path
PathBuf
from
"data/2-2_1.json"
@@ -37,3 +36,47 @@ fn track() {
macro_rules!
nasty_examples
$name:ident
$e:expr
#[test]
fn
$name
println!
$e
let
path
PathBuf
from
$e
let
mut
conf
algpath
cli
Configuration
path
Some
path
Default
default
conf
.homogenize
true
conf
.horner
true
let
mut
input_problem
algpath
cli
Problem
new_from_input
conf
.unwrap
let
mut
parametric_system
input_problem
.build_parametric_system
conf
.unwrap
let
path
input_problem
.path
for
point
in
input_problem
.fiber
let
proj_point
algpath
track
ProjectivePoint
coord
point
.clone
.into
chart
let
mbox
parametric_system
.find_moore_box
path
.clone
.into
proj_point
mut
Vec
new
.unwrap
let
_tr
parametric_system
.track
mbox
path
.clone
.into
.unwrap
// Nasty examples description :
// nasty_1: linear homotopy with a single degree 9 polynomial that has 4 close roots
nasty_examples!
nasty_1
"data/eric_1.json"
\ No newline at end of file
This diff is collapsed.
Loading
Save comment
