GitLab
Explore
Primary navigation
Search or go to…
A
algpath bench
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Numerical algebraic geometry
algpath bench
b2240f4c
b2240f4c
1 month ago
GUILLEMOT Alexandre
Downloads
Patches
correct run_entries bug with core option
d280ff5c
master
Branches containing commit
run_entries.py
+2
-2
2 additions, 2 deletions
run_entries.py
2 additions
2 deletions
run_entries.py
2
2
b2240f4c
@@ -14,7 +14,7 @@ parser.add_argument("-m", "--mem", nargs="?", const=8,
help
Maximum amount of memory used for the different tests. Should be written as <number><unit> where <unit> may be nothing, K, M or G, e.g. 100M
help
parser
add_argument
-n
action
store_true
parser
add_argument
-n
action
store_true
help
To only run benchmarks not previously done
help
parser
add_argument
-c
--core
nargs
const
default
parser
add_argument
-c
--core
nargs
const
help
Core on which the job should be ran
help
args
parser
parse_args
args
parser
parse_args
@@ -46,4 +46,4 @@ for i, pkg_name in enumerate(pkg_list):
assert
not
info
script error
assert
not
info
script error
except
except
subprocess
run
python3
run_test.py
str
pkg_path
str
Path
data_path
with_suffix
.json
--timeout
str
args
timeout
subprocess
run
python3
run_test.py
str
pkg_path
str
Path
data_path
with_suffix
.json
--timeout
str
args
timeout
args
timeout
None
--mem
str
args
mem
args
mem
None
--perf
args
perf
--core
args
core
args
timeout
None
--mem
str
args
mem
args
mem
None
--perf
args
perf
--core
args
core
args
core
None
This diff is collapsed.
Loading
Save comment
