GitLab
Explore
Primary navigation
Search or go to…
O
orangefs
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
nixos-compose
HPC IO
orangefs
9d5c43ad
9d5c43ad
2 years ago
GUILLOTEAU Quentin
Downloads
Merge branch 'main' of
ssh://gitlab.inria.fr/nixos-compose/hpc-io/orangefs
parents
3a64eb35
ce61fe7f
main
3
3 changed files
nxc/my_scripts.nix
+5
-2
5 additions, 2 deletions
nxc/my_scripts.nix
nxc/script.py
+14
-11
14 additions, 11 deletions
nxc/script.py
nxc/script_ior.nix
+3
-3
3 additions, 3 deletions
nxc/script_ior.nix
22 additions
16 deletions
nxc/my_scripts.nix
5
2
9d5c43ad
@@ -26,8 +26,10 @@ in {
cd
nfsMountPoint
cd
nfsMountPoint
cp
iorConfig
iorConfigPerCluster
cp
iorConfig
iorConfigPerCluster
NB_TASKS=$1
NB_TASKS=$1
BLOCK_SIZE=$2
sed -ri "s/(numTasks)=\w+/\1=$NB_TASKS/g"
iorConfigPerCluster
iorConfigPerCluster
sed -ri "s/(blockSize)=\w+/\1=$BLOCK_SIZE/g"
iorConfigPerCluster
start_ior_nodes
start_ior_nodes
@@ -39,9 +41,10 @@ in {
NB_SLOTS_PER_NODE=$(($TOTAL_NB_NODES / $NB_NODES))
cat /etc/hosts | grep
node
| head -n $NB_NODES | awk -v nb_slots="$NB_SLOTS_PER_NODE" '{ print $2 " slots=" nb_slots;}' > my_hosts
client
mpirun --allow-run-as-root --oversubscribe -mca btl self,vader -np $TOTAL_NB_NODES --hostfile my_hosts ior -f
iorConfigPerCluster
# mpirun --allow-run-as-root --oversubscribe -mca btl self,vader -np $TOTAL_NB_NODES --hostfile my_hosts ior -f
iorConfigPerCluster
mpirun --allow-run-as-root --oversubscribe --mca pml ^ucx --mca mtl ^psm2,ofi --mca btl ^ofi,openib -np $TOTAL_NB_NODES --hostfile my_hosts ior -f
iorConfigPerCluster
gen_config_orangefs
gen_config_orangefs
This diff is collapsed.
nxc/script.py
14
11
9d5c43ad
@@ -16,6 +16,7 @@ class MyEngine(Engine):
parser
add_argument
--nxc_build_file
help
Path to the NXC deploy file
parser
add_argument
--nxc_build_file
help
parser
add_argument
--nb_cpu_nodes
help
Number of compute nodes
parser
add_argument
--nb_cpu_nodes
help
parser
add_argument
--nb_io_nodes
help
Number of io nodes
parser
add_argument
--nb_io_nodes
help
Number of io nodes
parser
add_argument
--block_size
help
File size to write
parser
add_argument
--walltime
help
walltime in hours
parser
add_argument
--walltime
help
walltime in hours
parser
add_argument
--result_dir
help
where to store results
parser
add_argument
--result_dir
help
parser
add_argument
--flavour
help
Flavour
parser
add_argument
--flavour
help
Flavour
@@ -26,23 +27,25 @@ class MyEngine(Engine):
self
nb_io_nodes
self
nb_io_nodes
self
nb_nodes
self
nb_nodes
self
flavour
None
self
flavour
None
self
block_size
None
def
init
self
def
init
self
self
nb_cpu_nodes
int
self
args
nb_cpu_nodes
if
self
args
nb_cpu_nodes
else
2
self
nb_cpu_nodes
int
self
args
nb_cpu_nodes
if
self
args
nb_cpu_nodes
else
2
self
nb_io_nodes
int
self
args
nb_io_nodes
if
self
args
nb_io_nodes
else
self
nb_io_nodes
int
self
args
nb_io_nodes
if
self
args
nb_io_nodes
else
self
nb_nodes
self
nb_cpu_nodes
self
nb_io_nodes
self
nb_nodes
self
nb_cpu_nodes
self
nb_io_nodes
self
block_size
self
args
block_size
if
self
args
block_size
else
1G
walltime_hours
float
self
args
walltime
if
self
args
walltime
else
walltime_hours
float
self
args
walltime
if
self
args
walltime
else
nxc_build_file
self
args
nxc_build_file
nxc_build_file
self
args
nxc_build_file
self
flavour
self
args
flavour
if
self
args
flavour
else
g5k-image
self
flavour
self
args
flavour
if
self
args
flavour
else
g5k-image
site
grenoble
site
nancy
cluster
dahu
cluster
gros
oar_job
reserve_nodes
self
nb_nodes
site
cluster
deploy
if
self
flavour
g5k-image
else
allow_classic_ssh
walltime
walltime_hours
60
60
oar_job
reserve_nodes
self
nb_nodes
site
cluster
deploy
if
self
flavour
g5k-image
else
allow_classic_ssh
walltime
walltime_hours
60
60
self
oar_job_id
site
oar_job
self
oar_job_id
site
oar_job
roles_quantities
serverfs
self
nb_io_nodes
node
self
nb_cpu_nodes
roles_quantities
serverfs
self
nb_io_nodes
client
self
nb_cpu_nodes
self
nodes
get_oar_job_nodes_nxc
self
nodes
self
oar_job_id
self
oar_job_id
@@ -55,7 +58,7 @@ class MyEngine(Engine):
def
run
self
def
run
self
result_dir
self
args
result_dir
if
self
args
result_dir
else
os
getcwd
result_dir
self
args
result_dir
if
self
args
result_dir
else
os
getcwd
zip_archive_name
f
result_dir
/results_ior_
self
nb_nodes
_nodes_
self
flavour
zip_archive_name
f
result_dir
/results_ior_
self
nb_
cpu_
nodes
_
cpu_
nodes_
self
nb_io_nodes
_io_nodes_
self
block_size
_block_size_
self
flavour
outfile
self
args
outfile
4
if
self
args
outfile
else
zip_archive_name
outfile
self
args
outfile
4
if
self
args
outfile
else
zip_archive_name
folder_name
f
result_dir
/expe_orangefs_
self
flavour
_
self
nb_nodes
folder_name
f
result_dir
/expe_orangefs_
self
flavour
_
self
nb_nodes
@@ -63,24 +66,24 @@ class MyEngine(Engine):
logger
info
Starting OrangeFS on the IO nodes
logger
info
io_nodes
join
f
serverfs
i
for
i
in
range
self
nb_io_nodes
io_nodes
join
f
serverfs
i
for
i
in
range
self
nb_io_nodes
orangefs_config_remote
Remote
f
start_orangefs
io_nodes
self
nodes
serverfs
Remote
f
start_orangefs
io_nodes
self
nodes
serverfs
connection_params
users
root
run
run
logger
info
Starting OrangeFS on the clients
logger
info
orangefs_config_client_remote
Remote
orangefs_mount serverfs1
self
nodes
node
Remote
self
nodes
client
connection_params
user
root
run
run
logger
info
Generating IOR config
logger
info
run_ior_config_remote
Remote
f
generate_ior_config
self
nb_cpu_nodes
self
nodes
node
connection_params
user
root
Remote
f
generate_ior_config
self
nb_cpu_nodes
self
block_size
self
nodes
client
connection_params
user
root
run
run
for
nb_node
in
range
self
nb_nodes
for
nb_node
in
range
self
nb_
cpu_
nodes
is_ok
False
is_ok
False
while
not
is_ok
while
not
is_ok
# Run IOR
# Run IOR
logger
info
f
Starting IOR with
nb_node
nodes
logger
info
f
Starting IOR with
nb_node
nodes
run_ior_remote
Remote
f
start_ior_nodes
nb_node
self
nb_cpu_nodes
self
nodes
node
connection_params
user
root
run_ior_remote
Remote
f
start_ior_nodes
nb_node
self
nb_cpu_nodes
self
nodes
client
connection_params
user
root
run_ior_remote
run
run_ior_remote
run
is_ok
run_ior_remote
ok
is_ok
run_ior_remote
ok
@@ -91,7 +94,7 @@ class MyEngine(Engine):
# Get the result file back
logger
info
f
Retreving the result file for IOR with
nb_node
logger
info
f
nb_node
get_file_command
f
cp /orangefs/results_ior.json
folder_name
/results_ior_total_
self
nb_nodes
_active_
nb_node
_
self
flavour
.json
get_file_command
f
folder_name
/results_ior_total_
self
nb_nodes
_active_
nb_node
_
self
flavour
.json
get_file_remote
Remote
get_file_command
self
nodes
node
connection_params
user
root
get_file_remote
Remote
get_file_command
self
nodes
client
connection_params
user
root
get_file_remote
run
get_file_remote
run
is_ok
get_file_remote
ok
is_ok
get_file_remote
ok
logger
info
f
Result file for IOR with
nb_node
retrieved
logger
info
f
nb_node
retrieved
@@ -101,7 +104,7 @@ class MyEngine(Engine):
remove_folder
folder_name
remove_folder
folder_name
logger
info
f
Giving back the resources
logger
info
f
oardel
self
oar_job_id
grenoble
oardel
self
oar_job_id
nancy
def
reserve_nodes
nb_nodes
site
cluster
job_type
walltime
3600
def
reserve_nodes
nb_nodes
site
cluster
job_type
walltime
3600
jobs
oarsub
OarSubmission
{{cluster=
}}/nodes={}
format
cluster
nb_nodes
walltime
job_type
job_type
site
jobs
oarsub
OarSubmission
{{cluster=
}}/nodes={}
format
cluster
nb_nodes
walltime
job_type
job_type
site
nxc/script_ior.nix
3
3
9d5c43ad
@@ -40,11 +40,11 @@ IOR START
repetitions=5
repetitions=5
numTasks=
builtins
toString
numTasks
numTasks=
builtins
toString
numTasks
segmentCount=
4
segmentCount=
blockSize=128M
blockSize=128M
transferSize=
4
transferSize=
summaryFile=/
/results_ior.json
summaryFile=/
orangefs
/results_ior.json
summaryFormat=JSON
summaryFormat=JSON
RUN
RUN
writeFile=0
writeFile=0
Loading
Save comment
