Commit 436b49bf authored by Faure Adrien's avatar Faure Adrien
typo
parent 2b023d86
...@@ -232,59 +232,60 @@ Problem ...@@ -232,59 +232,60 @@ Problem
\subsection{NixPkgs} \subsection{NixPkgs}
\begin{frame}[fragile]{Packages repositories} \begin{frame}[fragile]{Package repositories}
Package definitions
\begin{itemize} \begin{itemize}
\item Packages are source code \item Source code (in Nix)
\item Decentralized repository \item Stored in decentralized repositories
\end{itemize} \end{itemize}
\vspace{1em} \vspace{1em}
Official Git Repository: Official Git Repository: \textbf{NixPkgs}
\begin{tcolorbox}[colframe=black,colback=gray!10,coltext=black] \begin{tcolorbox}[colframe=black,colback=gray!10,coltext=black]
\center \center
https://github.com/NixOS/nixpkgs \\ https://github.com/NixOS/nixpkgs \\
\textit{A.K.A} \textbf{NixPkgs}
\end{tcolorbox} \end{tcolorbox}
\item Maintained by the community \item Community maintained
\item +10K packages \item +10K packages
\item CI checked
\item Binary caches
\end{frame} \end{frame}
\section{Experiment Reproducibility} \section{Experiment Reproducibility}
\begin{frame}[fragile]{} \begin{frame}[fragile]{Conclusion}
\begin{columns} \begin{columns}
\begin{column}{0.5\textwidth} \begin{column}{0.5\textwidth}
Why it is reproducible ? Why it is reproducible ?
\item Package = traceable dependencies \item Traceable dependencies
\item Automated package build \item Automated package build
\item fixed application source \item Fixed application source
\item pinned Nixpkgs \item Pinned Nixpkgs
\end{column} \end{column}
\begin{column}{0.5\textwidth} %%<--- here \begin{column}{0.5\textwidth} %%<--- here
Limitations Limitations
\item No kernel version control \item No kernel version control
\item Require deterministic build process \item Require deterministic build
\item Can depends on external dependencies \item External storage (github, gitlab, )
\end{columns} \end{columns}
\end{frame} \vspace{1em}
\begin{frame}[fragile,noframenumbering]
\center
Thanks.
\center \center
https://mpoquet.gitlabpages.inria.fr/nix-tutorial/ https://mpoquet.gitlabpages.inria.fr/nix-tutorial/
\appendix \appendix
