Commit c6d12a8d authored by DUCARTON Nicolas's avatar DUCARTON Nicolas
added help info
parent 06cc4542
*.un~
*.swp *.swp
docker_results/
mpi5x/
run.sh
test_sc.sh
...@@ -11,7 +11,9 @@ HELP (){ ...@@ -11,7 +11,9 @@ HELP (){
echo "\t help: print this"; echo "\t help: print this";
echo "\t check: build starpu and run tests"; echo "\t check: build starpu and run tests";
echo "\t build: only build starpu"; echo "\t build: only build starpu";
echo "\t run : run [type] located at [path] (they must be provided)"; echo "\t run <type> <path> [program] [interactive=no]: run type (script) located at path inside the container";
echo "\t if a path is provided as [program], it is first copied to the container, then the script is executed";
echo "\t this script then expects a \"test\" file to exist inside the container, and will launch it with or without gdb depending on the interactive option (no/yes)";
echo "\t\t type : script or (test (TODO))"; echo "\t\t type : script or (test (TODO))";
echo "\t\t path : path to script (or test name (TODO))"; echo "\t\t path : path to script (or test name (TODO))";
echo "\t TODO gdb interactive guest_script/host_script"; echo "\t TODO gdb interactive guest_script/host_script";
