Commit 9610f9a8 authored by Adam Powers's avatar Adam Powers
Rolling back change that breaks build
Doesn't seem right that this should be rolled back, since it seems obvious that it's a typo, but the impact is that it breaks pretty much everything... so maybe it's not intended that evalute return an object.
parent 3574969e
......@@ -55,7 +55,7 @@ function JSONPath (opts, obj, expr) {
if (opts.autostart !== false) {
var ret = this.evaluate((objArgs ? opts.json : obj), (objArgs ? opts.path : expr));
if (!ret || typeof ret !== 'object') {
if (!ret || typeof reg !== 'object') {
throw {avoidNew: true, value: ret, message: "JSONPath should not be called with 'new'"};
