GitLab
Explore
Primary navigation
Search or go to…
P
python-grid5000
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
SIMONIN Matthieu
python-grid5000
35930c9c
Verified
35930c9c
5 years ago
SIMONIN Matthieu
Downloads
Patches
Doc: enable SSL verification inside Grid'5000
de961118
2
2 changed files
README.org
+14
-6
14 additions, 6 deletions
README.org
README.rst
+13
-5
13 additions, 5 deletions
README.rst
27 additions
11 deletions
README.org
14
6
35930c9c
@@ -62,8 +62,11 @@ conform with the Grid5000 API models (with an 's'!)
easily test and adapt them.
- The configuration is read from a configuration file located in the home
directory (should be compatible with the restfully one).
directory (should be compatible with the restfully one). It can be created
It can be created with the following:
with the following:
- When accessing the API from outside of Grid'5000 (e.g your local workstation),
you need to specify the following configuration file:
#+BEGIN_EXAMPLE
#+BEGIN_EXAMPLE
echo '
echo '
@@ -72,10 +75,15 @@ password: MYPASSWORD
' > ~/.python-grid5000.yaml
#+END_EXAMPLE
#+END_EXAMPLE
#+BEGIN_hint
- When accessing the API from a Grid'5000 frontend, providing the username and
From a Grid'5000 frontend this file is optionnal. In all other cases the
password is optionnal. Nevertheless you'll need to deal with SSL verification
configuration file is mandatory.
by specifying the path to the certificate to use:
#+END_hint
#+BEGIN_EXAMPLE
echo '
verify_ssl: /etc/ssl/certs/ca-certificates.crt
#+END_EXAMPLE
- Using a virtualenv is recommended (python 3.5+ is required)
This diff is collapsed.
README.rst
13
5
35930c9c
@@ -64,8 +64,11 @@ conform with the Grid5000 API models (with an ’s’!)
with the following:
- When accessing the API from outside of Grid’5000 (e.g your local workstation),
@@ -74,10 +77,15 @@ conform with the Grid5000 API models (with an ’s’!)
.. hint::
- When accessing the API from a Grid’5000 frontend, providing the username and
password is optionnal. Nevertheless you’ll need to deal with SSL verification
From a Grid’5000 frontend this file is optionnal. In all other cases the
echo '
Loading
Save comment
