Commit 3fbfbea8 authored by DEBREUVE Eric's avatar DEBREUVE Eric
some refactoring
parent ccca34a1
......@@ -52,13 +52,13 @@ class extension_t(glial_cmp_t):
# soma_uid: connected to a soma somewhere upstream
__slots__ = ("scales", "end_points", "soma_uid", "__cache__")
__slots__ = ("end_points", "scales", "soma_uid", "__cache__")
def __init__(self):
super().__init__()
self.scales = None
self.end_points = None
self.scales = None
self.soma_uid = None
self.__cache__ = None
......@@ -69,7 +69,7 @@ class extension_t(glial_cmp_t):
bmp = lmp == uid
instance.InitializeFromMap(bmp, uid)
end_point_map = extension_t.EndPointMap(bmp)
end_point_map = cls.EndPointMap(bmp)
end_point_lmp = end_point_map * lmp
instance.end_points = (end_point_lmp == uid).nonzero()
instance.scales = scales[instance.sites]
......@@ -91,17 +91,3 @@ class glial_cmp_t:
def BackReferenceSoma(self, glial_cmp: glial_cmp_t) -> None:
raise NotImplementedError
def NormalizedImage(image: array_t) -> array_t:
print("This normalization does not bring anything; left as is for now to avoid the need for changing prms")
nonextreme_values = image[np_.logical_and(image > 0.0, image < image.max())]
if nonextreme_values.size > 0:
nonextreme_avg = nonextreme_values.mean()
result = image.astype(np_.float32) / nonextreme_avg
else:
return result
......@@ -65,7 +65,7 @@ class soma_t(glial_cmp_t):
bmp = lmp == uid
contour_map = soma_t.ContourMap(bmp)
contour_map = cls.ContourMap(bmp)
contour_lmp = contour_map * lmp
instance.contour_points = tuple(zip(*(contour_lmp == uid).nonzero()))
# Copyright CNRS/Inria/UNS
# Contributor(s): Eric Debreuve (since 2019)
# eric.debreuve@cnrs.fr
# This software is governed by the CeCILL license under French law and
# abiding by the rules of distribution of free software. You can use,
# modify and/ or redistribute the software under the terms of the CeCILL
# license as circulated by CEA, CNRS and INRIA at the following URL
# "http://www.cecill.info".
# As a counterpart to the access to the source code and rights to copy,
# modify and redistribute granted by the license, users are provided only
# with a limited warranty and the software's author, the holder of the
# economic rights, and the successive licensors have only limited
# liability.
# In this respect, the user's attention is drawn to the risks associated
# with loading, using, modifying and/or developing or reproducing the
# software by the user in light of its specific status of free software,
# that may mean that it is complicated to manipulate, and that also
# therefore means that it is reserved for developers and experienced
# professionals having in-depth computer knowledge. Users are therefore
# encouraged to load and test the software's suitability as regards their
# requirements in conditions enabling the security of their systems and/or
# data to be ensured and, more generally, to use and operate it in the
# same conditions as regards security.
# The fact that you are presently reading this means that you have had
# knowledge of the CeCILL license and that you accept its terms.
from brick.general.type import array_t
import numpy as np_
else:
return result
......@@ -39,9 +39,9 @@
import brick.component.connection as cn_
import brick.component.extension as xt_
import brick.component.glial_cmp as gl_
import brick.component.soma as sm_
import brick.general.feedback as fb_
import brick.processing.normalization as nm_
# from main_prm import *
import os as os_
......@@ -98,8 +98,8 @@ img_shape = image.shape
print(f"IMAGE: s.{img_shape} t.{image.dtype} m.{image.min()} M.{image.max()}")
image_for_soma = gl_.NormalizedImage(image)
image_for_ext = gl_.NormalizedImage(image)
image_for_soma = nm_.NormalizedImage(image)
image_for_ext = nm_.NormalizedImage(image)
costs = 1.0 / (image + 1.0)
print(f"NRM-IMG: t.{image_for_soma.dtype} m.{image_for_soma.min():.2f} M.{image_for_soma.max():.2f}")
