Commit fd430df2 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- improved presentation and provided references to edoal
parent 884d931c
...@@ -15,7 +15,9 @@ ...@@ -15,7 +15,9 @@
it as imput for further alignment methods, transform it into axioms it as imput for further alignment methods, transform it into axioms
or transformations or compare different alignments.</p> or transformations or compare different alignments.</p>
<p>This is a first format that could be extended for accomodating <p>This is a first format that could be extended for accomodating
further needs.</p> further needs. The Alignment API offers the <a href="edoal.html">Expressive and
Declarative Ontology Alignment Language (EDOAL)</a> for more
elaborate uses.</p>
<p>We describe below its source descriptions, its specifications and <p>We describe below its source descriptions, its specifications and
some implementations.</p> some implementations.</p>
...@@ -35,7 +37,7 @@ ...@@ -35,7 +37,7 @@
<p>The namespace used by these formats is <tt>http://knowledgeweb.semanticweb.org/heterogeneity/alignment#</tt>.</p> <p>The namespace used by these formats is <tt>http://knowledgeweb.semanticweb.org/heterogeneity/alignment#</tt>.</p>
<h2>Format descriptions</h2> <h2>Format description</h2>
<h3><tt>Alignment</tt> class</h3> <h3><tt>Alignment</tt> class</h3>
...@@ -44,11 +46,11 @@ ...@@ -44,11 +46,11 @@
<dl compact="1"> <dl compact="1">
<dt>xml</dt><dd>(value: "yes"/"no") indicates if the alignment can be <dt>xml</dt><dd>(value: "yes"/"no") indicates if the alignment can be
read as an XML file compliant with the DTD;</dd> read as an XML file compliant with the DTD;</dd>
<dt>level</dt><dd>(values: "0", "1", "2OWL") the level of alignment</dd> <dt>level</dt><dd>(values: "0", "1", "2EDOAL") the level of alignment</dd>
<dt>type</dt><dd>(values: <dt>type</dt><dd>(values:
"11"/"1?"/"1+"/"1*"/"?1"/"??"/"?+"/"?*"/"+1"/"+?"/"++"/"+*"/"*1"/"*?"/"?+"/"**") the type of alignment;</dd> "11"/"1?"/"1+"/"1*"/"?1"/"??"/"?+"/"?*"/"+1"/"+?"/"++"/"+*"/"*1"/"*?"/"?+"/"**") the type of alignment;</dd>
<dt>onto1</dt><dd>(value: URL) the first ontology to be aligned;</dd> <dt>onto1</dt><dd>(value: Ontology) the first ontology to be aligned;</dd>
<dt>onto2</dt><dd>(value: URL) the second ontology to be aligned;</dd> <dt>onto2</dt><dd>(value: Ontology) the second ontology to be aligned;</dd>
<dt>map</dt><dd>(value: Cell*) the set of correspondance between <dt>map</dt><dd>(value: Cell*) the set of correspondance between
entities of the ontologies.</dd> entities of the ontologies.</dd>
</dl></p> </dl></p>
...@@ -69,10 +71,26 @@ ...@@ -69,10 +71,26 @@
<h3><tt>Relation</tt> class</h3> <h3><tt>Relation</tt> class</h3>
<p>This class does not currently exists in the format (it exists in <p>This class does not currently exists in the format (it exists in
its implementation). Currently, the relation is expressed as a string.</p> its implementation). Currently, the relation is expressed as a
string. It can be a Java classname. If this class is available
under the Java environment, then the relation will be an instance
of this class.</p>
<h2>Extensions</h2>
<p>The format as implemented here supports extensions both on
Alignments and on Cells. I.e., if additional string-valued
qualified attributes are added to the objects, they will be preserved through
the implementation.
</p>
<p>
Moreover, many standard extensions have already been defined and are
<a href="labels.html">documented</a>.
</p>
<h2>JAVA implementation</h2> <h2>JAVA implementation</h2>
<p>The Alignment API implements this format. In particular it provides tools for:
<p>The <a href="index.html">Alignment API</a> implements this format. In particular it provides tools for:
<ul compact="1"> <ul compact="1">
<li>Outputing the RDF/XML format from the API;</li> <li>Outputing the RDF/XML format from the API;</li>
<li>Parsing the RDF/XML format into the API;</li> <li>Parsing the RDF/XML format into the API;</li>
...@@ -85,22 +103,46 @@ ...@@ -85,22 +103,46 @@
<div class="fragment"><pre> <div class="fragment"><pre>
$ java -jar lib/procalign file://$CWD/rdf/onto1.owl file://$CWD/rdf/onto2.owl $ java -jar lib/procalign file://$CWD/rdf/onto1.owl file://$CWD/rdf/onto2.owl
&lt;?xml version='1.0' encoding='utf-8' standalone='no'?> &lt;?xml version='1.0' encoding='utf-8' standalone='no'?>
&lt;!DOCTYPE rdf:RDF SYSTEM "align.dtd">
&lt;rdf:RDF xmlns='http://knowledgeweb.semanticweb.org/heterogeneity/alignment#' &lt;rdf:RDF xmlns='http://knowledgeweb.semanticweb.org/heterogeneity/alignment#'
xmlns:rdf='http://www.w3.org/1999/02/22-rdf-syntax-ns#' xmlns:rdf='http://www.w3.org/1999/02/22-rdf-syntax-ns#'
xmlns:xsd='http://www.w3.org/2001/XMLSchema#'> xmlns:xsd='http://www.w3.org/2001/XMLSchema#'
xmlns:align='http://knowledgeweb.semanticweb.org/heterogeneity/alignment#'>
&lt;Alignment> &lt;Alignment>
&lt;xml>yes&lt;/xml> &lt;xml>yes&lt;/xml>
&lt;type>11&lt;/type> &lt;level>0&lt;/level>
&lt;onto1>file://$CWD/rdf/onto1.owl&lt;/onto1> &lt;type>**&lt;/type>
&lt;onto2>file://$CWD/rdf/onto2.owl&lt;/onto2> &lt;align:method>fr.inrialpes.exmo.align.impl.method.StringDistAlignment&lt;/align:method>
&lt;align:time>7&lt;/align:time>
&lt;onto1>
&lt;Ontology rdf:about="http://www.example.org/ontology1">
&lt;location>file:examples/rdf/onto1.owl&lt;/location>
&lt;formalism>
&lt;Formalism align:name="OWL1.0" align:uri="http://www.w3.org/2002/07/owl#"/>
&lt;/formalism>
&lt;/Ontology>
&lt;/onto1>
&lt;onto2>
&lt;Ontology rdf:about="http://www.example.org/ontology2">
&lt;location>file:examples/rdf/onto2.owl&lt;/location>
&lt;formalism>
&lt;/formalism>
&lt;/Ontology>
&lt;/onto2>
&lt;map>
&lt;Cell>
&lt;entity1 rdf:resource='http://www.example.org/ontology1#reviewedarticle'/>
&lt;entity2 rdf:resource='http://www.example.org/ontology2#journalarticle'/>
&lt;relation>=&lt;/relation>
&lt;measure rdf:datatype='http://www.w3.org/2001/XMLSchema#float'>0.4666666666666667&lt;/measure>
&lt;/Cell>
&lt;/map>
&lt;map> &lt;map>
&lt;Cell> &lt;Cell>
&lt;entity1 rdf:resource='http://www.example.org/ontology1#journalarticle'/> &lt;entity1 rdf:resource='http://www.example.org/ontology1#journalarticle'/>
&lt;entity2 rdf:resource='http://www.example.org/ontology2#journalarticle'/> &lt;entity2 rdf:resource='http://www.example.org/ontology2#journalarticle'/>
&lt;measure rdf:datatype='xsd:float'>0.0&lt;/measure>
&lt;relation>=&lt;/relation> &lt;relation>=&lt;/relation>
&lt;measure rdf:datatype='http://www.w3.org/2001/XMLSchema#float'>1.0&lt;/measure>
&lt;/Cell> &lt;/Cell>
&lt;/map> &lt;/map>
&lt;/Alignment> &lt;/Alignment>
