Commit fc3af516 authored by Jérôme Euzenat's avatar Jérôme Euzenat
Transfered version/license.txt to pom.xml
Updated xsdlib
parent 640e9f00
with 423 additions and 798 deletions
......@@ -76,10 +76,10 @@ with a warning:
<li>Simplified visitor patterns (impl/edoal/renderer)</li>
<li><span style="color: red;">Use</span> edoal prefix instead of xsd for comparators (edoal)</li>
<li>Integrated <tt>owl:propertyChain</tt> in OWL rendering (edoal)</li>
<!--li>Upgraded to <span style="color: green">OWL API ??</span>,
<li>Upgraded to <span style="color: green">SKOS API 2</span><!--,
<span style="color: green">Xerces 2.10</span>,
<span style="color: green">log4j 1.2.16</span>,
<span style="color: green">slf4j 1.6.4</span> (lib)</li-->
<span style="color: green">slf4j 1.6.4</span--> (lib)</li>
<li>Added <tt>JSONRendererVisitor</tt> (impl)</li>
<li>Added <tt>corresp</tt> primitive (server)</li>
<li>Added <tt>EDOALAlignment.toEDOALAlignment()</tt> (edoal)</li>
<project>
<modelVersion>4.0.0</modelVersion>
<groupId>gnu.getopt</groupId>
<artifactId>getopt</artifactId>
<version>1.0.13</version>
<name></name>
<description> (Version 2006)</description>
<licenses>
<license>
<name>GNU LIBRARY GENERAL PUBLIC LICENSE Version 2, June 1991</name>
<url>http://www.gnu.org/licenses/lgpl-2.0.html</url>
</license>
</licenses>
<url>http://www.urbanophile.com/arenn/hacking/download.html</url>
<!--distributionManagement>
<downloadUrl></downloadUrl>
</distributionManagement-->
</project>
1.0.13 (2006)
<project>
<!-- JE: from original pom -->
<groupId>com.google.api</groupId>
<artifactId>google-api-translate-java</artifactId>
<version>0.93-SNAPSHOT</version>
<name>google-api-translate-java</name>
<description>A Java wrapper for the Google Translate service</description>
<licenses>
<license>
<name>GNU LESSER GENERAL PUBLIC LICENSE Version 3, 29 June 2007</name>
<url>http://www.gnu.org/licenses/lgpl-3.0.html</url>
</license>
</licenses>
<!--url></url>
<distributionManagement>
<dependencies>
<dependency>
<groupId>org.json</groupId>
<artifactId>json</artifactId>
<version>20090211</version>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<artifactId>maven-compiler-plugin</artifactId>
<configuration>
<source>1.5</source>
<target>1.5</target>
</configuration>
</plugin>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-jar-plugin</artifactId>
<configuration>
<archive>
<manifest>
<addClasspath>true</addClasspath>
<mainClass>com.google.api.translate.TranslatorFrame</mainClass>
</manifest>
</archive>
</configuration>
</plugin>
</plugins>
</build>
</project>
<project>
<!--name></name>
<description></description-->
<licenses>
<license>
<name></name>
<url></url>
</license>
</licenses>
<!--url></url>
</distributionManagement>
<dependencies>
<dependency>
<groupId></groupId>
<artifactId></artifactId>
<version></version>
</dependency>
</dependencies-->
</project>
Copyright (C) 2007 Free Software Foundation, Inc. <http://fsf.org/>
Everyone is permitted to copy and distribute verbatim copies
of this license document, but changing it is not allowed.
This version of the GNU Lesser General Public License incorporates
the terms and conditions of version 3 of the GNU General Public
License, supplemented by the additional permissions listed below.
0. Additional Definitions.
As used herein, "this License" refers to version 3 of the GNU Lesser
General Public License, and the "GNU GPL" refers to version 3 of the GNU
General Public License.
"The Library" refers to a covered work governed by this License,
other than an Application or a Combined Work as defined below.
An "Application" is any work that makes use of an interface provided
by the Library, but which is not otherwise based on the Library.
Defining a subclass of a class defined by the Library is deemed a mode
of using an interface provided by the Library.
A "Combined Work" is a work produced by combining or linking an
Application with the Library. The particular version of the Library
with which the Combined Work was made is also called the "Linked
Version".
The "Minimal Corresponding Source" for a Combined Work means the
Corresponding Source for the Combined Work, excluding any source code
for portions of the Combined Work that, considered in isolation, are
based on the Application, and not on the Linked Version.
The "Corresponding Application Code" for a Combined Work means the
object code and/or source code for the Application, including any data
and utility programs needed for reproducing the Combined Work from the
Application, but excluding the System Libraries of the Combined Work.
1. Exception to Section 3 of the GNU GPL.
You may convey a covered work under sections 3 and 4 of this License
without being bound by section 3 of the GNU GPL.
2. Conveying Modified Versions.
If you modify a copy of the Library, and, in your modifications, a
facility refers to a function or data to be supplied by an Application
that uses the facility (other than as an argument passed when the
facility is invoked), then you may convey a copy of the modified
version:
a) under this License, provided that you make a good faith effort to
ensure that, in the event an Application does not supply the
function or data, the facility still operates, and performs
whatever part of its purpose remains meaningful, or
b) under the GNU GPL, with none of the additional permissions of
this License applicable to that copy.
3. Object Code Incorporating Material from Library Header Files.
The object code form of an Application may incorporate material from
a header file that is part of the Library. You may convey such object
code under terms of your choice, provided that, if the incorporated
material is not limited to numerical parameters, data structure
layouts and accessors, or small macros, inline functions and templates
(ten or fewer lines in length), you do both of the following:
a) Give prominent notice with each copy of the object code that the
Library is used in it and that the Library and its use are
covered by this License.
b) Accompany the object code with a copy of the GNU GPL and this license
document.
4. Combined Works.
You may convey a Combined Work under terms of your choice that,
taken together, effectively do not restrict modification of the
portions of the Library contained in the Combined Work and reverse
engineering for debugging such modifications, if you also do each of
the following:
a) Give prominent notice with each copy of the Combined Work that
the Library is used in it and that the Library and its use are
b) Accompany the Combined Work with a copy of the GNU GPL and this license
document.
c) For a Combined Work that displays copyright notices during
execution, include the copyright notice for the Library among
these notices, as well as a reference directing the user to the
copies of the GNU GPL and this license document.
d) Do one of the following:
0) Convey the Minimal Corresponding Source under the terms of this
License, and the Corresponding Application Code in a form
suitable for, and under terms that permit, the user to
recombine or relink the Application with a modified version of
the Linked Version to produce a modified Combined Work, in the
manner specified by section 6 of the GNU GPL for conveying
Corresponding Source.
1) Use a suitable shared library mechanism for linking with the
Library. A suitable mechanism is one that (a) uses at run time
a copy of the Library already present on the user's computer
system, and (b) will operate properly with a modified version
of the Library that is interface-compatible with the Linked
Version.
e) Provide Installation Information, but only if you would otherwise
be required to provide such information under section 6 of the
GNU GPL, and only to the extent that such information is
necessary to install and execute a modified version of the
Combined Work produced by recombining or relinking the
Application with a modified version of the Linked Version. (If
you use option 4d0, the Installation Information must accompany
the Minimal Corresponding Source and Corresponding Application
Code. If you use option 4d1, you must provide the Installation
Information in the manner specified by section 6 of the GNU GPL
for conveying Corresponding Source.)
5. Combined Libraries.
You may place library facilities that are a work based on the
Library side by side in a single library together with other library
facilities that are not Applications and are not covered by this
License, and convey such a combined library under terms of your
choice, if you do both of the following:
a) Accompany the combined library with a copy of the same work based
on the Library, uncombined with any other library facilities,
conveyed under the terms of this License.
b) Give prominent notice with the combined library that part of it
is a work based on the Library, and explaining where to find the
accompanying uncombined form of the same work.
6. Revised Versions of the GNU Lesser General Public License.
The Free Software Foundation may publish revised and/or new versions
of the GNU Lesser General Public License from time to time. Such new
versions will be similar in spirit to the present version, but may
differ in detail to address new problems or concerns.
Each version is given a distinguishing version number. If the
Library as you received it specifies that a certain numbered version
of the GNU Lesser General Public License "or any later version"
applies to it, you have the option of following the terms and
conditions either of that published version or of any later version
published by the Free Software Foundation. If the Library as you
received it does not specify a version number of the GNU Lesser
General Public License, you may choose any version of the GNU Lesser
General Public License ever published by the Free Software Foundation.
If the Library as you received it specifies that a proxy can decide
whether future versions of the GNU Lesser General Public License shall
apply, that proxy's public statement of acceptance of any version is
permanent authorization for you to choose that version for the
Library.
google-api-translate-java-0.94
<project>
<groupId>fr.inrialpes.exmo</groupId>
<artifactId>iddl</artifactId>
<version>1.3-20100331</version>
<name>Integrated Distributed Description Logic</name>
<description>A Resonner for Integrated Distributed Description Logic - special revision of 31/03/2010 (revision 49+)</description>
<licenses>
<license>
<name>GNU LESSER GENERAL PUBLIC LICENSE Version 2.1, February 1999</name>
<url>http://www.gnu.org/licenses/lgpl-2.1.html</url>
</license>
</licenses>
<url>http://iddl.gforge.inria.fr/</url>
<!-- align api? Pellet? OWLAPI? -->
<dependencies>
<dependency>
<groupId></groupId>
<version></version>
</dependency>
</dependencies>
</project>
1.3-20100331 - special revision of 31/03/2010 (revision 49+)
<project>
<groupId>jade.mtp</groupId>
<artifactId>http</artifactId>
<version>3.3</version>
<name>Jade HTTP Message transport protocol</name>
<licenses>
<license>
</license>
</licenses>
<url>http://jade.tilab.com/</url>
<dependencies>
<dependency>
<groupId></groupId>
<version></version>
</dependency>
</dependencies-->
</project>
<project>
<groupId>FIPA</groupId>
<artifactId>iiop</artifactId>
<version>3.3</version> <!-- or is it 3.7 ?-->
<name>FIPA IIOP For Jade</name>
<description>Part of Jade implementing FIPA IIOP</description>
<licenses>
<license>
</license>
</licenses>
<dependencies>
<dependency>
<groupId></groupId>
<version></version>
</dependency>
</dependencies-->
</project>
<project>
<groupId>jade</groupId>
<artifactId>jade</artifactId>
<name>Java Agent Development Environment (JADE)</name>
<description></description>
<licenses>
<license>
</license>
</licenses>
<dependencies>
<dependency>
<groupId></groupId>
<version></version>
</dependency>
</dependencies>
</project>
This diff is collapsed.
3.3
The MySQL jdbc connectors are distributed under the GPL license
GNU GENERAL PUBLIC LICENSE
Copyright (C) 1989, 1991 Free Software Foundation, Inc.
51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA
Preamble
The licenses for most software are designed to take away your freedom to share and change it. By contrast, the GNU General Public License is intended to guarantee your freedom to share and change free software--to make sure the software is free for all its users. This General Public License applies to most of the Free Software Foundation's software and to any other program whose authors commit to using it. (Some other Free Software Foundation software is covered by the GNU Lesser General Public License instead.) You can apply it to your programs, too.
When we speak of free software, we are referring to freedom, not price. Our General Public Licenses are designed to make sure that you have the freedom to distribute copies of free software (and charge for this service if you wish), that you receive source code or can get it if you want it, that you can change the software or use pieces of it in new free programs; and that you know you can do these things.
To protect your rights, we need to make restrictions that forbid anyone to deny you these rights or to ask you to surrender the rights. These restrictions translate to certain responsibilities for you if you distribute copies of the software, or if you modify it.
For example, if you distribute copies of such a program, whether gratis or for a fee, you must give the recipients all the rights that you have. You must make sure that they, too, receive or can get the source code. And you must show them these terms so they know their rights.
We protect your rights with two steps: (1) copyright the software, and (2) offer you this license which gives you legal permission to copy, distribute and/or modify the software.
Also, for each author's protection and ours, we want to make certain that everyone understands that there is no warranty for this free software. If the software is modified by someone else and passed on, we want its recipients to know that what they have is not the original, so that any problems introduced by others will not reflect on the original authors' reputations.
Finally, any free program is threatened constantly by software patents. We wish to avoid the danger that redistributors of a free program will individually obtain patent licenses, in effect making the program proprietary. To prevent this, we have made it clear that any patent must be licensed for everyone's free use or not licensed at all.
The precise terms and conditions for copying, distribution and modification follow.
TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
0. This License applies to any program or other work which contains a notice placed by the copyright holder saying it may be distributed under the terms of this General Public License. The "Program", below, refers to any such program or work, and a "work based on the Program" means either the Program or any derivative work under copyright law: that is to say, a work containing the Program or a portion of it, either verbatim or with modifications and/or translated into another language. (Hereinafter, translation is included without limitation in the term "modification".) Each licensee is addressed as "you".
Activities other than copying, distribution and modification are not covered by this License; they are outside its scope. The act of running the Program is not restricted, and the output from the Program is covered only if its contents constitute a work based on the Program (independent of having been made by running the Program). Whether that is true depends on what the Program does.
1. You may copy and distribute verbatim copies of the Program's source code as you receive it, in any medium, provided that you conspicuously and appropriately publish on each copy an appropriate copyright notice and disclaimer of warranty; keep intact all the notices that refer to this License and to the absence of any warranty; and give any other recipients of the Program a copy of this License along with the Program.
You may charge a fee for the physical act of transferring a copy, and you may at your option offer warranty protection in exchange for a fee.
2. You may modify your copy or copies of the Program or any portion of it, thus forming a work based on the Program, and copy and distribute such modifications or work under the terms of Section 1 above, provided that you also meet all of these conditions:
a) You must cause the modified files to carry prominent notices stating that you changed the files and the date of any change.
b) You must cause any work that you distribute or publish, that in whole or in part contains or is derived from the Program or any part thereof, to be licensed as a whole at no charge to all third parties under the terms of this License.
c) If the modified program normally reads commands interactively when run, you must cause it, when started running for such interactive use in the most ordinary way, to print or display an announcement including an appropriate copyright notice and a notice that there is no warranty (or else, saying that you provide a warranty) and that users may redistribute the program under these conditions, and telling the user how to view a copy of this License. (Exception: if the Program itself is interactive but does not normally print such an announcement, your work based on the Program is not required to print an announcement.)
These requirements apply to the modified work as a whole. If identifiable sections of that work are not derived from the Program, and can be reasonably considered independent and separate works in themselves, then this License, and its terms, do not apply to those sections when you distribute them as separate works. But when you distribute the same sections as part of a whole which is a work based on the Program, the distribution of the whole must be on the terms of this License, whose permissions for other licensees extend to the entire whole, and thus to each and every part regardless of who wrote it.
Thus, it is not the intent of this section to claim rights or contest your rights to work written entirely by you; rather, the intent is to exercise the right to control the distribution of derivative or collective works based on the Program.
In addition, mere aggregation of another work not based on the Program with the Program (or with a work based on the Program) on a volume of a storage or distribution medium does not bring the other work under the scope of this License.
3. You may copy and distribute the Program (or a work based on it, under Section 2) in object code or executable form under the terms of Sections 1 and 2 above provided that you also do one of the following:
a) Accompany it with the complete corresponding machine-readable source code, which must be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
b) Accompany it with a written offer, valid for at least three years, to give any third party, for a charge no more than your cost of physically performing source distribution, a complete machine-readable copy of the corresponding source code, to be distributed under the terms of Sections 1 and 2 above on a medium customarily used for software interchange; or,
c) Accompany it with the information you received as to the offer to distribute corresponding source code. (This alternative is allowed only for noncommercial distribution and only if you received the program in object code or executable form with such an offer, in accord with Subsection b above.)
The source code for a work means the preferred form of the work for making modifications to it. For an executable work, complete source code means all the source code for all modules it contains, plus any associated interface definition files, plus the scripts used to control compilation and installation of the executable. However, as a special exception, the source code distributed need not include anything that is normally distributed (in either source or binary form) with the major components (compiler, kernel, and so on) of the operating system on which the executable runs, unless that component itself accompanies the executable.
If distribution of executable or object code is made by offering access to copy from a designated place, then offering equivalent access to copy the source code from the same place counts as distribution of the source code, even though third parties are not compelled to copy the source along with the object code.
4. You may not copy, modify, sublicense, or distribute the Program except as expressly provided under this License. Any attempt otherwise to copy, modify, sublicense or distribute the Program is void, and will automatically terminate your rights under this License. However, parties who have received copies, or rights, from you under this License will not have their licenses terminated so long as such parties remain in full compliance.
5. You are not required to accept this License, since you have not signed it. However, nothing else grants you permission to modify or distribute the Program or its derivative works. These actions are prohibited by law if you do not accept this License. Therefore, by modifying or distributing the Program (or any work based on the Program), you indicate your acceptance of this License to do so, and all its terms and conditions for copying, distributing or modifying the Program or works based on it.
6. Each time you redistribute the Program (or any work based on the Program), the recipient automatically receives a license from the original licensor to copy, distribute or modify the Program subject to these terms and conditions. You may not impose any further restrictions on the recipients' exercise of the rights granted herein. You are not responsible for enforcing compliance by third parties to this License.
7. If, as a consequence of a court judgment or allegation of patent infringement or for any other reason (not limited to patent issues), conditions are imposed on you (whether by court order, agreement or otherwise) that contradict the conditions of this License, they do not excuse you from the conditions of this License. If you cannot distribute so as to satisfy simultaneously your obligations under this License and any other pertinent obligations, then as a consequence you may not distribute the Program at all. For example, if a patent license would not permit royalty-free redistribution of the Program by all those who receive copies directly or indirectly through you, then the only way you could satisfy both it and this License would be to refrain entirely from distribution of the Program.
If any portion of this section is held invalid or unenforceable under any particular circumstance, the balance of the section is intended to apply and the section as a whole is intended to apply in other circumstances.
It is not the purpose of this section to induce you to infringe any patents or other property right claims or to contest validity of any such claims; this section has the sole purpose of protecting the integrity of the free software distribution system, which is implemented by public license practices. Many people have made generous contributions to the wide range of software distributed through that system in reliance on consistent application of that system; it is up to the author/donor to decide if he or she is willing to distribute software through any other system and a licensee cannot impose that choice.
This section is intended to make thoroughly clear what is believed to be a consequence of the rest of this License.
8. If the distribution and/or use of the Program is restricted in certain countries either by patents or by copyrighted interfaces, the original copyright holder who places the Program under this License may add an explicit geographical distribution limitation excluding those countries, so that distribution is permitted only in or among countries not thus excluded. In such case, this License incorporates the limitation as if written in the body of this License.
9. The Free Software Foundation may publish revised and/or new versions of the General Public License from time to time. Such new versions will be similar in spirit to the present version, but may differ in detail to address new problems or concerns.
Each version is given a distinguishing version number. If the Program specifies a version number of this License which applies to it and "any later version", you have the option of following the terms and conditions either of that version or of any later version published by the Free Software Foundation. If the Program does not specify a version number of this License, you may choose any version ever published by the Free Software Foundation.
10. If you wish to incorporate parts of the Program into other free programs whose distribution conditions are different, write to the author to ask for permission. For software which is copyrighted by the Free Software Foundation, write to the Free Software Foundation; we sometimes make exceptions for this. Our decision will be guided by the two goals of preserving the free status of all derivatives of our free software and of promoting the sharing and reuse of software generally.
NO WARRANTY
11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
END OF TERMS AND CONDITIONS
BSD License
The PostgreSQL JDBC driver is distributed under the BSD license, same as the server. The simplest explanation of the licensing terms is that you can do whatever you want with the product and source code as long as you don't claim you wrote it or sue us. You should give it a read though, it's only half a page.
Copyright (c) 1997-2008, PostgreSQL Global Development Group
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
3. Neither the name of the PostgreSQL Global Development Group nor the names
of its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
<project>
<groupId>com.mysql</groupId>
<artifactId>mysql-connector-java</artifactId>
<version>5.1.12</version>
<name>Java Database connector (JDBC) for MySQL</name>
<licenses>
<license>
<name>GNU LESSER GENERAL PUBLIC LICENSE Version 2.0, June 1991</name>
<url>http://www.gnu.org/licenses/gpl-2.0.txt</url>
</license>
</licenses>
<url></url>
<dependencies>
<dependency>
<groupId></groupId>
<version></version>
</dependency>
</dependencies-->
</project>
<project>
<groupId>org.postgresql</groupId>
<artifactId>postgresql-jdbc4</artifactId>
<version>8.4-701</version>
<name>Java Database connector (JDBC) for Postgres</name>
<licenses>
<license>
<name>BSD</name>
<url>http://www.opensource.org/licenses/bsd-license.php</url>
<distribution>repo</distribution>
</license>
</licenses>
<url></url>
<dependencies>
<dependency>
<groupId></groupId>
<version></version>
</dependency>
</dependencies-->
</project>
mysql-connector-java-5.1.12-bin
postgresql-8.4-701.jdbc4
<project>
<groupId>org.apache.jena</groupId>
<artifactId>jena-arq</artifactId>
<version>2.9.0-incubating q</version>
<name>ARQ</name>
<description>ARQ is a SPARQL 1.1 query engine for Jena</description>
<packaging>jar</packaging>
<licenses>
<license>
<name>Apache License Version 2.0, January 2004</name>
<url>http://www.apache.org/licenses/LICENSE-2.0.txt</url>
</license>
</licenses>
<url></url>
<!-- There is a decent pom in the Jar-file -->
</project>
<project>
<groupId>com.ibm.icu</groupId>
<artifactId>icu4j</artifactId>
<version>3.4.4</version>
<name>ICU4J</name>
<description>International Component for Unicode for Java (ICU4J) is a mature, widely used Java library providing Unicode and Globalization support</description>
<licenses>
<license>
<name>ICU License</name>
<url>http://source.icu-project.org/repos/icu/icu/trunk/license.html</url>
</license>
</licenses>
<url>http://icu-project.org/</url>
<developers>
<developer>
<id>mark</id>
<name>Mark Davis</name>
<organization>Google</organization>
<roles>
<role>PMC Member</role>
</roles>
</developer>
<developer>
<id>emmons</id>
<name>John Emmons</name>
<organization>IBM Corporation</organization>
<roles>
</roles>
</developer>
<developer>
<id>doug</id>
<name>Doug Felt</name>
<roles>
</roles>
</developer>
<developer>
<id>deborah</id>
<name>Deborah Goldsmith</name>
<organization>Apple</organization>
<roles>
</roles>
</developer>
<developer>
<id>srl</id>
<name>Steven Loomis</name>
<roles>
</roles>
</developer>
<developer>
<id>markus</id>
<name>Markus Scherer</name>
<roles>
</roles>
</developer>
<developer>
<id>yoshito</id>
<name>Yoshito Umaoka</name>
<roles>
</roles>
</developer>
</developers>
<mailingLists>
<mailingList>
<name>icu-support</name>
<subscribe>https://lists.sourceforge.net/lists/listinfo/icu-support</subscribe>
<unsubscribe>https://lists.sourceforge.net/lists/listinfo/icu-support</unsubscribe>
<post>icu-support@lists.sourceforge.net</post>
<archive>http://sourceforge.net/mailarchive/forum.php?forum_name=icu-support</archive>
</mailingList>
<mailingList>
<name>icu-announce</name>
<subscribe>https://lists.sourceforge.net/lists/listinfo/icu-announce</subscribe>
<unsubscribe>https://lists.sourceforge.net/lists/listinfo/icu-announce</unsubscribe>
<post>icu-announce@lists.sourceforge.net</post>
<archive>http://sourceforge.net/mailarchive/forum.php?forum_name=icu-announce</archive>
</mailingList>
<mailingList>
<name>icu-design</name>
<subscribe>https://lists.sourceforge.net/lists/listinfo/icu-design</subscribe>
<unsubscribe>https://lists.sourceforge.net/lists/listinfo/icu-design</unsubscribe>
<post>icu-design@lists.sourceforge.net</post>
<archive>http://sourceforge.net/mailarchive/forum.php?forum_name=icu-design</archive>
</mailingList>
</mailingLists>
<scm>
<connection>scm:svn:http://source.icu-project.org/repos/icu/icu4j/trunk/</connection>
<developerConnection>scm:svn:http://source.icu-project.org/repos/icu/icu4j/trunk/</developerConnection>
<url>http://source.icu-project.org/repos/icu/icu4j/trunk/</url>
</scm>
<issueManagement>
<system>Trac</system>
<url>http://bugs.icu-project.org/trac/</url>
</issueManagement>
<repository>
<id>icu4j-releases</id>
<name>ICU4J Central Repository</name>
<url>http://oss.sonatype.org/service/local/staging/deploy/maven2</url>
</repository>
<snapshotRepository>
<id>icu4j-snapshots</id>
<name>ICU4J Central Development Repository</name>
<url>http://oss.sonatype.org/content/repositories/snapshots</url>
</snapshotRepository>
</project>
