Commit f77402ef authored by Jérôme Euzenat's avatar Jérôme Euzenat
First release notes
parent ccebd3ce
<html>
<head>
<title>Release notes</title>
</head>
<body bgcolor="#ffffff">
<center><h1>Alignment API, release notes</h1></center>
<h2>To do</h2>
<ul compact="1">
<li>Pass debug flag through parameters (almost done, to be checked in StrucSubsDistNameAlignment);</li>
<li>Factorize distanceAlignment, in fact the selection;</li>
<li>Implement correctly OWL-based stuff about non 1:1 alignments</li>
<li>Integrate WordNet proximity</li>
</ul>
<h2>Done but not released yet</h2>
<h2>April 19th, 2004</h2>
<p>New version featuring:
<ul compact="1">
<li>Corrected the problem of putting directly distances into strength
({get/set}Measure{1/2} are now called Strength,
new class DistanceAlignment which takes care of converting distances into strength);</li>
<li>Implemented effectively SymMeanEvaluator with a dispatch per elements;</li>
<li>Added correct 1:1 tags to all implemented OWL alignments</li>
<li>Used Object in API: no OWL in the format (all API methods which
returned OWL... now returns Objects, dynamic typecheckking of the
basic methods: maybe not the best idea)</li>
<li>Implemented parameters (align() and eval() take an additionnal
Parameters parameter, new Parameters interface and
BasicParameters class);</li>
<li>Corrected the visitor for the Renderer (now robust to subclassing);</li>
<li>Built a renderer for RDF and use it
(suppression of the write method in Cell and Alignment,
Procalign uses the same code for rendering);</li>
<li>Added a StringDistance class providing substring and editstriung distances;</li>
<li>Reviewed all catch with a printStackTraces (parser still unsatisfactory);</li>
<li>Cleaned-up traces;</li>
<li>Provided a full-fledged example illustrated with a paper;</li>
<li>Corrected StrucSubsDistNameAlignment;</li>
<li>Changed name: Evaluator.evaluate() --> Evaluator.eval();</li>
</ul>
T
<h2>April 4th, 2004</h2>
<p>This use the last version of the OWL API (090304).</p>
<ul compact="1">
<li>Added the Evaluator interface and implementation (PRecEvaluator
and SymMeanEvaluator).</li>
<li>Added a simple structural algorithm (StrucSubsDistNameAlignment).</li>
<li>Added a number of alignment based on substring distance;</li>
<li>Various improvements.</li>
</ul>
</p>
<h2>January 2004</h2>
<p>Put under CVS at Sophia-Antipolis</p>
<ul compact="1">
<li>Added a number of alignment implementations (EditDistAlignment);</li>
</ul>
</p>
<h2>December 2003</h2>
<p>First release</p>
<address>
<small>
<hr />
<center>http://co4.inrialpes.fr/align/relnotes.html</center>
<hr />
$Id$
</small>
</address>
</body>
</html>
