Commit f5a17d40 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- Moved types to Java 1.5
parent 886f6ddd
...@@ -55,25 +55,25 @@ import org.semanticweb.owl.align.Parameters; ...@@ -55,25 +55,25 @@ import org.semanticweb.owl.align.Parameters;
public class BasicParameters implements Parameters { public class BasicParameters implements Parameters {
/** The list of unlinked out XML_Port */ /** The list of unlinked out XML_Port */
Hashtable parameters = null; Hashtable<String,Object> parameters = null;
public BasicParameters() { public BasicParameters() {
parameters = new Hashtable(); parameters = new Hashtable<String,Object>();
public void setParameter(String name, Object value){ public void setParameter(String name, Object value){
parameters.put((Object)name,value); parameters.put(name,value);
public void unsetParameter(String name){ public void unsetParameter(String name){
parameters.remove((Object)name); parameters.remove(name);
public Object getParameter(String name){ public Object getParameter(String name){
return parameters.get((Object)name); return parameters.get(name);
public Enumeration getNames(){ public Enumeration<String> getNames(){
return parameters.keys(); return parameters.keys();
