Commit c83ce633 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- started changing INRIA Rhone-Alpes for INRIA
- Hidden OntologyCache
parent b822794b
...@@ -17,7 +17,6 @@ ...@@ -17,7 +17,6 @@
<h2>Under development (you can contribute)</h2> <h2>Under development (you can contribute)</h2>
<p><ul compact="1"> <p><ul compact="1">
<li>Implement <tt>owlapi10</tt> as <tt>HeavyLoadedAlignment</tt> (onto)</li>
<li>Implement ontology support database store (server)</li> <li>Implement ontology support database store (server)</li>
<li>Online evaluation (server)</li> <li>Online evaluation (server)</li>
<li>Providing a <tt>DiffAlign( al1, al2 )</tt> operation and interface <li>Providing a <tt>DiffAlign( al1, al2 )</tt> operation and interface
...@@ -40,6 +39,9 @@ ...@@ -40,6 +39,9 @@
<p> <p>
<ul compact="1"> <ul compact="1">
<li><tt>OntologyCache</tt> is now local at each <tt>OntologyFactory</tt> (onto)</li>
<li>Started to put copyright notices to INRIA instead of INRIA Rhône-Alpes (misc)</li>
</ul> </ul>
</p> </p>
* $Id$ * $Id$
* Copyright (C) INRIA Rh�ne-Alpes, 2007-2008 * Copyright (C) INRIA, 2007-2008
* This program is free software; you can redistribute it and/or modify * This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by * it under the terms of the GNU Lesser General Public License as published by
...@@ -29,11 +29,6 @@ import java.net.URI; ...@@ -29,11 +29,6 @@ import java.net.URI;
import java.util.Vector; import java.util.Vector;
import java.util.Enumeration; import java.util.Enumeration;
//import org.omwg.mediation.parser.rdf.RDFParser;
//import org.omwg.mediation.parser.rdf.RDFParserException;
//import javax.xml.parsers.SAXParser;
//import javax.xml.parsers.SAXParserFactory;
import org.semanticweb.kaon2.api.formatting.OntologyFileFormat; import org.semanticweb.kaon2.api.formatting.OntologyFileFormat;
import org.semanticweb.owl.align.Alignment; import org.semanticweb.owl.align.Alignment;
import fr.inrialpes.exmo.align.impl.BasicAlignment; import fr.inrialpes.exmo.align.impl.BasicAlignment;
...@@ -41,18 +36,12 @@ import org.semanticweb.owl.align.AlignmentProcess; ...@@ -41,18 +36,12 @@ import org.semanticweb.owl.align.AlignmentProcess;
import org.semanticweb.owl.align.AlignmentVisitor; import org.semanticweb.owl.align.AlignmentVisitor;
import org.semanticweb.owl.align.Parameters; import org.semanticweb.owl.align.Parameters;
//import com.ontoprise.api.formatting.OntoBrokerOntologyFileFormat;
//import com.ontoprise.config.IConfig;
//import com.ontoprise.config.IConfig.OntologyLanguage;
import com.ontoprise.ontostudio.io.ImportExportControl; import com.ontoprise.ontostudio.io.ImportExportControl;
import fr.inrialpes.exmo.align.impl.BasicParameters; import fr.inrialpes.exmo.align.impl.BasicParameters;
import fr.inrialpes.exmo.align.onto.OntologyCache;
import fr.inrialpes.exmo.align.parser.AlignmentParser; import fr.inrialpes.exmo.align.parser.AlignmentParser;
//import fr.inrialpes.exmo.align.impl.renderer.HTMLRendererVisitor;
import fr.inrialpes.exmo.align.impl.renderer.OWLAxiomsRendererVisitor; import fr.inrialpes.exmo.align.impl.renderer.OWLAxiomsRendererVisitor;
import fr.inrialpes.exmo.align.impl.renderer.RDFRendererVisitor; import fr.inrialpes.exmo.align.impl.renderer.RDFRendererVisitor;
//import fr.inrialpes.exmo.align.impl.OWLAPIAlignment;
public class OfflineAlign { public class OfflineAlign {
...@@ -97,7 +86,7 @@ public class OfflineAlign { ...@@ -97,7 +86,7 @@ public class OfflineAlign {
Class[] cparams = {}; Class[] cparams = {};
java.lang.reflect.Constructor alignmentConstructor = alignmentClass.getConstructor(cparams); java.lang.reflect.Constructor alignmentConstructor = alignmentClass.getConstructor(cparams);
A1 = (AlignmentProcess)alignmentConstructor.newInstance(mparams); A1 = (AlignmentProcess)alignmentConstructor.newInstance(mparams);
A1.init( (URI)uris.get(0), (URI)uris.get(1), (OntologyCache)null ); A1.init( (URI)uris.get(0), (URI)uris.get(1) );
A1.align((Alignment)null,p); A1.align((Alignment)null,p);
